FixYa.com
Tags:
EliteGroup P4VXMS  Motherboard
South Bridge
posted by melolvr on Nov 20, 2006
I have a P4 1.6ghz custome computer that has recently stopped working. I took it to a repair shop and they noticed the smell of something burning and discovered that the "south bridge" chip was extremely hot and had a scorch march on the top.
They said that the motherboard was shot and that I had to get a brand new one which by the time it was all over, would be cheaper to buy a new computer.Whith that said, my question is:
Is there another board that I can use the same processor and memory that I currently have (Intel P4x266-8233) to save some money,as it is very tight right now.
Your help is greatly appreciated!
M~
Comment by melolvr, posted on Dec 01, 2006
I am just a little confused because I was under the impression that it was a 423 socket. When i removed the heat sheild to remove the processor it says on the locking assembly that it is a 423 pin socket. so does that mean that it is a 423 socket? and if so does that mean that my current processor will only fit in a 423 socket motherboard?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 30, 2006
FixYa! (100)
Rumburak
Rank:Master Master
Rating: 85%, 47 votes
you can use any mainboard that supports your CPU and memory, look for a board that has same memory slots, most likely DDR memory and supports the voltage your P4 needs. Most likely, (double check by searching the code on top of the cpu in google or wikipedia), your cpu is a socket 478, code name Willamate.
Once you have that, look up motherboard manufacturer websites and search by the socket 478 and make sure the memory is the same type DDR or even older SDRAM. (try Gigabyte.com.tw, MSI.com.tw, DFI.com.tw, ASUS.com)
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 04, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
problem of sound driver
This Problem Also Relates To: HP (D7580-60003) Motherboard HP (D9896-69007) Motherboard ASUS 865G (MBAS-P4P800VM) Motherboard ASUS P4BP-MX P4 Prescott/845GV/FSB 533/V/A/LAN (MOTAS26) Motherboard ASUS P5B-E Motherboard ASUS P5VD2-MX SE Motherboard ASUS P5VD2-VM SE - Motherboard - micro ATX - P4M890 - LGA775 Socket - UDMA133, Serial ATA-300 ...
Can you Help with these Motherboards problems?
Motherboards
PCC266 = PC400?
is PC400 compatible with VIA... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
