Question about HP Office Equipment & Supplies
My printer deskjet f2100 is showing a paper jam (red light showing on control panel) how do i fix it?
  • tobutt1 Nov 17, 2008
    Thankyou very much for your reply,it was extreamly helpfull,and my problem is now solved!!
  • 1,031 Answers
Folow the steps below 1. Check for and remove any paper stuck in the paper in tray
2. clear the paper jam from the back of the printer
a. unplug the AIO
b. Press in the tab on the left side of the rear door to release the door. remove the door by pulling it away from the AIO
c. gently pull the paper out fo the rollers
d. clean the rollers with a lint free cloth that is moist with distilled water
3. Lift the front cover and slowly remove any jammed paper
a. unplug the power cable
b. if necessary pull the input tray down to open it. then lower the print cartridge door
c. gently pull the paper out of the rollers
d. close the print cartridge door
e. plug the power cable
4. Verify that the print cartridge carriage can move freely
b. check to see if the print cartridge carriage can move freely from one side to the other.
c. remove the print cartridges
d. gently move the print cartridge to tyhe far right of the printer
e. remove the paper from the paper in tray, but do not remove the drawer
f. remove the rear acces door
g. with your fingers rotate the rollers "up" three full rotations
h. close the rear access door
i. replace the print cartridges
j. plug the power cable
k. turn the power on
5. reload and test the printer
hope this helps
Posted on Nov 14, 2008
  • Starnley Johnwells
    Starnley Johnwells Nov 15, 2008
    pls appreciate by rating it as fixyaa
Printer blinking red and showing letter E
Error description:
The Attention (red) light is blinking. There are six possible causes that will display the Attention light pattern:
-Paper out
-Door open
-Print cartridge missing
-Paper jam
-Paper sensor jammed
-Duplexer error
Solution :
After the cause of the problem has been addressed, pressing GO will cause the printer to attempt to recover from the cause of the error. If the printer is unsuccessful, it will continue to display the Attention message until the cause is remedied.
Pressing JOB CANCEL will cancel the print job and the printer will return to the Ready state (Ready light on) unless there is a paper jam still in the printer or the print cartridge is not in the printer.
For more details visit the link below :
Resolve Printer issue
Jun 09, 2011 | HP DeskJet F380 All-In-One Printer
Printer hp deskjet 840c blinking green and red light why
Depends which red blinking light. I assume the red light is the resume light. The green light is the power light. If the Power and the Resume light are blinking alternately, then you have a paper jam somewhere in the printer. remove the paper jam and you should be fine.
Mar 18, 2011 | HP DeskJet 840c InkJet Printer
Go to print and status say paper jam, checked rollers and inside, but no jam
i lost my cd of Hp Deskjet F380 and i want to install now to my cp, secondly it use to show me red light blinking saying paper jam while there is no paper jam inside the printer for now she is not working
Nov 23, 2009 | HP PSC 1210 All-In-One InkJet Printer
Try reseting it meaning kill the power for an hour or so then re start it plugged in. If nto it is the geas, that are almost impossible to fix.
Aug 11, 2009 | HP DeskJet 9650 InkJet Printer
Hp deskjet F2100 series
how do I clear a Printer HP deskjet F2100 series.? As it doesnt come out very well.
Nov 02, 2008 | Office Equipment & Supplies
My HP Deskjet F2100 All-in-one printer/scanner will not print a photo which is only post card size at less than A4 size when I use photo paper. It prints the correct size when I use plain paper.
just leave your paper type as Plain Paper,
and if your printing out a 5R size photo or photo sizes not exceed on Letter size paper, just leave the paper sizes using Letter,
print on both sides set as OFF.
then just customize the printing quality for a good printing result.
then load or place your photo paper properly on the paper tray to avoid jam.
Aug 24, 2008 | HP Office Equipment & Supplies
Paper jam in HP Deskjet F2100 all-in-one. Flashing light indicates trouble with cartridges 21 22, but can't get at them because they are stuck at sides. Cartridges newly installed.
Thank you. Problem solved. Original cause was my inexperience: learning new tricks at age 88 isn't easy. I simply manhandled the paper jam and it worked.
Jul 03, 2008 | HP Office Equipment & Supplies
I control panel under pinter it says paper yam
in this case , what iLL do is to "REBOOT" , UNISTALL EVERYTHING that has to do with the HP printer , I mean everything ,after deleting all driver of printer , go to START , click SEARCH , and write " hp deskjet 3740" click search , if something shows , delete it , then install the drivers again ,
this is in case you havent found the solution for this particular issue , hope this helps , AJ
May 13, 2008 | HP DeskJet 3740 InkJet Printer
My hp deskjet 1280 printer is not coming on
well..sometimes when a paper jam occurs, it shuts the whole system down..
you may wish to remove the s/w for that printer through control panel
go here for updates drivers
re install the s/w
run test page, calibrate and clean cycles.
Mar 27, 2008 | HP DeskJet 1280 InkJet Printer
126 people viewed this question
Ben Johnson
