Question about GE GSL25JFPBS Side by Side Refrigerator
No water at the door
The water in the door stopped working. I seem to recall a switching noise from the rear of the unit when it use to dispense water, but now it doesn't do anything when the lever is pressed, only the light comes on. The ice dispensor works but not the water. What do I need to do? Thanks
  • 3 more comments
  • ben fogerty Nov 29, 2006
    The water solenoid in the rear allows water to be discharged when the door lever is pressed and the hose is disconnected from solenoid. However, there is no water at the door once hose is connected. Evidently there is a blockage in the line between the door and the solenoid. Where would it most likely be? Thanks, Ben
  • Arod12 Nov 26, 2007
    Had the same problem--door was then left open accidentally and water was fixed. Now, 3 months later, same problem. Will try and leave it open and see what happens.
  • sumitra Dec 08, 2007
    The water does not come anymore from water dispenser. The ice dispenser works. I tried fixing this by removing the ice and then setting the temperature to zero. The water dispenser then worked. But after using for almost 6 months or so, the water dispenser is not working again. What could be the cause to this? I will again try setting the temperature to zero and see.
  • anna751 Feb 12, 2008
  • Anonymous Mar 23, 2008
    water in the door freezes up . I can thow it out with a hair dryer but it will only last a few day's .
  • 237 Answers
If the solenoid valve doesn't click anymore then it's either bad or not activating anymore. Check that the switch behind the water lever is not broken or has fallen loose inside the door panel. You may be able to put a finger up there and try to push it without using just the lever. (sometimes slamming glasses into that lever over time breaks the switch attaching pins causing the switch to fall off inside). Take the front panel off and visually check that switch itself to see if it is still being held in place. Activate it by hand (not the lever method) and see if that water solenoid valve clicks again and water flows. If you have no water to both the Ice Maker and door dispensor at all (clogged filter?) check the main water line for clogs/debris, etc. If you are making ice still then water is at least getting to the ice maker and that means only the door water valve or switch is bad. The link below may help you "see" inside with the different diagrams, etc. http://www.partselect.com/MultiModels.aspx?ModelNum=GSL25JFP&searchTerm=&RefineSearch=0
Posted on Nov 24, 2006
  • Marc Wilson
    Marc Wilson Dec 27, 2006
    The blockage is usually near the 90 degree bend just before the dispensor due to frozen line. A quick check is to leave the door open for a few hours to thaw the "possible" frozen line. If it works after a few hours of thawing then you know the line was frozen inside the door.
Send to the junk yard
Posted on Jul 01, 2008
Water Dispenser on GE Profile Bottom Freezer Refrigerator Not Working
When you press the water dispenser button, do you hear a noise like water is trying to come as usual. If so then your problem might be frozen chill water tank or failed chill water valve. If you don't hear the regular noise then the problem might be with the dispenser unit.
Nov 26, 2013 | Star Manufacturing GE Profile PFSS5NJX...
Cool water switch seems to be faulty, no water but ice maker seems to be working how do I get access to switch?
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Jan 12, 2011 | Refrigerators
My whirlpool suddenly stopped dispensing water.
most fridges stop dispensing water when you open the door. Find the door switch and make sure fridge interior light goes on/off when you manually press door switch. This would show you that the door switch was faulty.
If the water connection to the appliance is one of those watts flood-safe water lines, it may have stuck shut. I've seen this happen when the house water pressure is too high.
Does it still make ice?
If so, then the water connection is good, and either the switch in the water dispenser has failed or the water shutoff valve for the water dispenser has gone bad.
Some models have a problem with the water line getting frozen, such that simply leaving the light on in the water dispenser compartment overnight and/or manually defrosting the unit can get it working again.
Nov 02, 2009 | Refrigerators
The water dispenser on my beko ap930 has stopped working can anyone offer any help,the piping all seems to be ok,could it be the valve ?
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. If it's not and you can hear to valve click, there is a valve our water supply problem. If you don't hear the click, it's a dispenser switch problem. If it's normal, disconnect it at the bottom of the freezer door and try again. It it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Sep 15, 2009 | Refrigerators
Water Dispenser not working
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice and water dispenser stopped working
Welcome to the computer world. When depressed, the paddle actuates a switch attached to the bracket above. The switch sends a low voltage signal to a small circuit board mouted right behind the display. A computer chip on that small board communicates with another chip on the main control board mounted in the rear wall. Your situation could be a bad actuator switch, a broken paddle tab, possibly a bad door switch (the fresh food doors must be closed to dispense), or a bad electronic control.
Jun 05, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Kenmore Refrig. door water disapenser
check the switch on the water despensor , solinoid valve or the water supply to the fridge
Apr 13, 2009 | Refrigerators
In door water dispenser won't work
Stop.....did you check the filter....also did you check to make sure your resivoir is not frozen..(its located in the refer side behind the crispers
Apr 02, 2008 | Whirlpool 26.6 cu. ft. Side-by-Side...
Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water/Ice Dispenser is not working
Some models need the filter inplace to pass water. First check it again with a new filter in just to be sure the filter isn't clogged. Next... do you hear any click or such noise from the rear of the unit when you push the water dispenser? The solenoid valves may be bad. Also check the valves at the back of the frige to see if the filter screen isn't clogged blocking water from getting into the frige all together. Let us know what you find and post again.
Dec 20, 2006 | Amana ASD 2624 Side by Side Refrigerator
GE GSL25JFPBS Side by Side Refrigerator Logo
656 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
