Question about Sony CDX-3100 CD Changer
Sony CDX-3100 - Unit keeps resetting
Hi, I wonder if you can help - I've just taken my Sony CDX-3100 head unit out of my old car and fitted it into a new one. The unit worked fine in my other car, no problems, but since I refitted it, it no longer stores any of my EQ settings or stored radio stations. I set everything up, but next time I switch the ignition back on, the CD gets ejected and all the settings and memories are reset to default.
I followed the instructions in the manual - when I installed it, I pressed the small reset button but this doesn't seem to have done any good. I have unplugged the unit, re-plugged it, then pressed reset but with no joy.
Any help gratefully received
Cheers
Dan Trussler
SOURCE: Problem with stuck magazine....
I have used what Listener85 posted and the advice was spot on.The rubber mounts were tricky getting back on but persistance payed off. Thanks a mil, u saved me £100!!! Dan, Cambridge, Uk
Posted on Mar 20, 2007
SOURCE: CDX changer has power but doesn't want to eject after flat battery
i resolved this myself in the end.
I unplugged the audio & power cables whilst the stereo and engine was running.
Then plugged back in.
I turned the engine off and stereo off as well.
I then unplugged audio and power again from the back of the CDX, left it unplugged for 10 minutes whilst the engine was still off.
I then plugged the leads back in and turned the engine on. the stereo recognised the CDX, but stayed on displaying "CD Checking". I switched to radio for 20 seconds, turned back to CDX and it selected CD 1 and has been good ever since.
I'm rather pleased with myself!
Steve
Posted on May 15, 2008
  • 4 Answers
SOURCE: Sony CDX-GT720 No Memory!
OK. Here's the deal. There are two "power" input lines. A RED and a YELLOW. RED should be connected to your vehicles' ignition or key switch. YELLOW should be connected to a "constant" power supply directly from the battery.
If you have a test light, you should be able to find both at the fuse box. Just clip the alligator clip to the frame somewhere or to the edge of the cigarette lighter and probe the fuse box turning the switch off and on respectively. (test lights are very inexpensive, about 4 or 5 bucks at the auto parts store).
Hope this helps.
Posted on Jul 05, 2008
  • 597 Answers
SOURCE: Sony CDX-M600R car radio CD: Radio does not work,
Don't know if you have an external antenna or one mounted in windshield but you should be able to find the coaxial heading towards the back of the radio. Make sure that it is plugged into the radio.
Posted on Jun 01, 2009
  • 3 Answers
SOURCE: Reset button on Sony 10 Disc CD changer
there is a reset button the the converter box that all the wires go into.
Posted on Aug 25, 2009
I have a Sony CDX-GT310 FM/AM Compact Disc Player with detachable faceplate. The unit still plays fine, but the display on the faceplate quit working. I've tried resetting the unit as well as cutting...
check the connectors between the faceplate and the unit carfully they can get damaged with constant removing/refitting if not the faceplate and/or unit is faulty
Dec 09, 2017 | Sony CDX-GT310 CD Player
CDX-S2200 fitting to old golf
haha, yea sorry about that must have clicked the wrong button... if they spliced that old sony harness to the factory harness and did not cut the factory plug off then you can go to you local bestbuy or car audio store and get an adapter for your factory harness... but, if you have the tools and the time, its faster and cheaper just to hardwire on the new one... as for an adapter to convert the old sony to the new sony plug... ive never seen an adapter for that...
May 02, 2010 | Sony CDX-S2200 CD Player
MEX-BT5700U, no sound in speakers in CD source, tuner source OK.
What many people do on this model is connect the remotes wires improperly. Use the solid blue wire for the amp and the blue with white stripe for the connection to the car.
Dec 06, 2009 | Car Audio & Video
How to hook up a head unit to an amplifier,when the head unit has no RCA plug ins? It was done before in my old car now i cant remember how.
Here is a link to owners manual for Sony CDX-GT300.
http://www.docs.sony.com/release/CDXGT300.pdf
Here is a link to installation instructions. It looks to me that there are front and rear line out RCA connectors on the back side of your head unit. (Unless, this is not the model of your head unit)
http://www.docs.sony.com/release/CDXGT300_Installation_Guide.pdf
There are devices that are capable of converting speaker level output to line level (RCA) output. I know Scoch is one brand, and here is a link to others.
http://www.electronixwarehouse.com/car/accessories/line-converters.htm
Hope this helps.
Nov 03, 2009 | Sony CDX-GT300 CD Player
System keeps resetting on sony cdx-m730
i have the exact same problem mate, did you find out how to stop this? if so could you let me know? Cheers
gaspanic88@hotmail.com
Apr 15, 2009 | Sony CDX-M730 CD Player
Distortion on speakers from CDX-M630
sounds like you have a faulty head unit
Sorry
Mark
www.blueice-electronics.co.uk
Nov 23, 2008 | Sony CDX-M630 CD Player
Hi i have a older cdx-65 cd changer
IT WILL NEED A SERVICE, POSSIBLE THAT ONE OF THE SWITCHES IS FAULTY
oops caps lock was on sorry :)
Mark
Nov 04, 2008 | Sony CDX-656 10-Disc CD Changer
CDX A55 Error (Err-99)
Hi in most casses just unplugging it will reset the unit.
but this unit is very old and to be honest is probably ready for he knackers yard.
they did suffer a few problems....
Reagrds
Mark
Apr 09, 2008 | Sony XR-C5100 CD Changer
Sony cd changer cdx-646...no card remote commander to release security code
Hi the CDX-646 is not coded. it must be your head unit thats coded.what model is the head unit?
you can get your code @ www.carradiocode.co.uk
for 33.50 if its one of the models listed you will nedd the remote comander tho.
Mark
Feb 24, 2008 | Sony CDX-646 10-Disc CD Changer
Car Audio & Video Logo
56 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
