I have unpluged it and also pushed the reset button several times. Lamp doesn't seem to be the problem. It has don this before in the past. But simply unplugging it has worked this time???
Green Timer/Power light blinking and cannot get any response from remote or buttons on TV, will not turn on. Reset button does not resolve problem and turning power off to unit has not solved problem either. Return power to unit and same situation.
Check the power supply for bad capacitors usually they are swallen,if not check the DM board for bad capacitors too. they are (4) 1000uf/16volts. 105 degrees.you have to replace them with 1000uf/25volts.105 degrees. now i don't know if you have the ability to disasemble the tv to get to this boards,if you don't just call the repairman. and tell him about this caps,ok.
The fuse on the main board is mostly blown this causes this problem.
if the fuse is perfect then the problem is of the main power supply board the capacitors on the boards are either loose and needs to be tighten.
or the capacitors r blown or bulged up and needs to be replaced.
start from checking fuse on the main board.
thanks.
the board gets this types of problems due to moisture collected on it and immediately when u start the tv due to that moisture it gets short and looses.
also due to heavy electricity passed from the tv at certain period when the tv was on and board could not handle that extra current and gets short.
thanks
