Question about NEC ND-6650A DVD RW Dual Layer Burner
NEC ND-6650A DVD RW does not recognize DVD
Hi, I had a problem reading DVDs sometime back. It was a conflict with teh Roxio software. I uninstalled it and it started working again. Lately I tried to backup data on a DVD and the drive seems to recognize the DVD as a CD. Thanks for your help.
  • the_sarpo Feb 15, 2008
    my laptop's fujitsu-siemens and it's NEC ND-6650A DVD RW does not recognize DVD and see it as a CD and its blank. have the same prolem. ople tell me about a firmware but there's no firmware for this model of NEC.
  • Anonymous Dec 23, 2008
    i cant find drivers
    Problem Solver:
  • 6 Answers
Refer to http://support.microsoft.com/kb/891894 for solutions to the infamous I/O error. Hope that helps.
Posted on May 10, 2008
Disc
It may be a conflict with another program. Roxio is a little tempramental about other software.
You can try another Burning software to check the drive is not faulty.
You can try a free program like IMGburn.
If that program works i would uninstall roxio, run a registry cleaner. I like CC cleaner's built in registry cleaner.
Then re install roxio and check the roxio site for any updates
Jul 11, 2010 | Roxio Easy Media Creator 10 Suite
Tip
Microsoft Visual C++ Runtime Library error when starting Roxio creator
Hi.
I have had several questions from users getting Microsoft Visual C++ Runtime Library errors when starting Roxio Creator 2010 and previous versions.
After the error prompt, the software will close down.
The problem is caused by a system error , and this sometimes is causedby Microsoft self installing update, that confuse settings of installedsoftware.
Microsoft Visual C++ Runtime Libraries are part of the operativesystem, and this kind of Run time errors are commonly caused whenapplications try to access resources that are allocated for otherprocesses.
A new Roxio installation did not fix the problem, because the newinstallation will still keep the registry settings from oldinstallation.
If the problem started recently you can try the following:
Uninstall Roxio.
Do a System Restore to a date before the problem started.
Reinstall Roxio.
See: How to install System restore.
If that does not fix the problem you can also try the following;
Uninstall Roxio
Create a new user with administrator privileges
Log in using the New User account
Install Roxio again.
If the problem was bound to local user settings, this will fix the problem.
If the problem is still there, then the most efficient way to proceedis by doing a new Windows installation, using a Windows setup disk or arecovery disk for your computer.
Do a full backup of your data before reinstalling Windows.
See:Install, reinstall, or uninstall Windows
The solution does not apply only to Roxio, but can fix the same problem on different software.
Regards.
on Feb 26, 2010 | Computers & Internet
Purchased roxio creator 2010 in store and roxio 6 & 5 on line
Uninstall the software, and try to get a refund.
Then, access http://www.MajorGeeks.com
and download the _free_ "Ashampoo Burning Version 6" software. It's great software for burning both data and audio CDs and DVDs, and it is _free_ to use.
Apr 07, 2010 | Roxio Easy Media Creator 10 Suite
Error: unable to read certificate file . I am unable to remove software, install or repair it.
This is what I got from a forum
1. Fix registry permissions
a. Click on "Start" choose "Run", then type "regedit" and click "OK".
b. In the Registry Editor, click on the "+" next to "HKEY_Local_Machine".
c. Now click on the "+" next to "Software".
d. Right-click on the key (folder) called "Roxio" and choose "Permissions".
e. Make sure that "Administrators" and "System" have checkmarks for "Full Control" - "Allow".( This does not apply in win2000!)
2.
f. If you had to add those checkmarks, click on "Apply".
g. Click on "Advanced".
h. Put a checkmark in "Replace permission entries on all child objects with the entries shown here that apply to child objects".
i. Click "OK".
j. Click "OK" again.
k. Now close the Registry Editor
If this does not work, then download the Revo uninstaller and uninstall Roxio from that. Try to install once again and I think it should work fine.
Nov 17, 2009 | Roxio Easy Media Creator 9 Suite (227100)...
TRYING TO INSTALL FROM BOUGHT DISC ROXIO CREATOR 9 WILL NOT
Instead, for *FREE*, access http://www.MajorGeeks.com
and search for "AShampoo Burning 6", download it, and install it.
It is FREE software for burning CD/DVDs.
Oct 19, 2009 | Roxio Creator 2009 Ultimate for PC
Philips spd3600cc17 no longer will burn dvds
Three thing to try here, 1. uninstall drivers and reinstall, 2.uninstall (if neessasary) Roxio and Nero, and reinstall. try the first two if still nothing let me know, I will walk you through the next solution that might work.
Jun 22, 2009 | Computers & Internet
Installation and operating failures to save or burn.
When you install the program, it provides an Ignore button to avoid the conflict? It's strange that you must uninstall one software to use the other one.
May 12, 2009 | Roxio PHOTOSUITE 5 PLATINUM CD for PC
Roxio Easy VHS to DVD install causes PC to hang up.
Do you have any other conflicting software or any other Roxio software? Any other Roxio or Sonic software will cause errors with Easy VHS to DVD.
It's also recommended to download the Service Pack from the Roxio.com site.
Mar 28, 2009 | Roxio Easy VHS to DVD for PC
Drive does read audio cd but not dvd.writer also can't burn any.
If you have Roxio or Sonic installed, sometimes the configuration will get corrupt.
Uninstall all application software that relates to any CD/DVD burning, and try the following:
Download the following FREE burner....it is the best burning software I have ever used and it is FREE!
ALWAYS set the burn speed very LOW....4X for CD's and 2X for DVDS and you will never go back to the other burners again!
The BEST options for using InfraRecorder is to burn data discs, burn Disc images and to create Disc images.
I trashed Roxio and Sonic because they are too memory dependent and they contradict each other's configuration...
Tall Tiger
35 years experience....
Feb 17, 2009 | HP Computers & Internet
Should i uninstall other burning programs on my computer?
Hi dbarbosa63
I would suggest uninstalling the other software. I have had more than enough instances ehare roxio and other software had conflicts. Remeber to restart after unstallinf the other software to get the drivers they may have used out of the system before installing the roxio.
Regards
Go-Tech
Dec 16, 2008 | Computers & Internet
NEC ND-6650A DVD RW Dual Layer Burner Logo
695 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
