Question about Microsoft Windows XP Home Edition
Trying to reinstall windows xp and not letting me
I uninstalled windows xp and reformatted the c drive and a drive and its not letting me reinstall windows xp
  • sljw2006 Nov 20, 2008
    first time using this disk bought from walmart i now have a different problem i got it to start installing and a guy on here told me that the cd was a bad one because it wanted me to skip some files so i returned the cd and got a new one and now that i stopped it in the middle of installion when it boots up and says press any key to boot from cd i press it and it says setup is inspecting your computers hardware configuration and then restarts and if i dont press any key it says ntldr is missing press ctrl alt del to restart what do i do from here
  • 26 Answers
Since the system restarts during the inspecting hardware piece of the install some piece of hardware on the machine is causing a problem. You can try removing all cards, for example the Ethernet card, the sound card, if you have a dial up modem, unplug anything from the ports of the computer other than the monitor keyboard & mouse. You want to get down to only the motherboard & if you have a separate one a video card. Then install windows. Once you have windows installed you can add your cards back into the machine. If this does not work then sounds like a bad motherboard. Which if it is an XP machine not worth the money to fix it, so buy another one. Often your local thrift shops will sell used ones with XP on them for not to much. Or your local Walmart or computer store will be happy to sell you brand new.
Posted on Jun 04, 2014
    Scholar:
  • 53 Answers
Do you have a XP installation disc? do you have a valid product number? (sometimes the product number is located on a sticker, depends if you brought the PC ready made)
Lastly how many times have you reinstalled the OS? if you have a OEM product code I think the limit of reinstalling the OS is 5 times, after then you have to speak to MS. although you have to have to reach the activate windows screen before this becomes an issue.
Posted on Nov 14, 2008
My kingston 8GB cannot open ( Message Show- The semaphore timeout period has expired) please help me. TQ
It sounds as if you have a faulty USB drive, depending on your Operating System, MS Windows / Linux, uninstall the USB drivers under device manager which could be found in the control panel on Windows XP/Vista/7, restart the computer and reinstall the driver's if they don't install back by themselves. But before you start try using your thumb drive on another computer. If you get the same problem, try to reformat the thumb drive, but before you do, be aware that all your information will be lost, and will not be able to be recovered without the appropriate recovery tools.
Feb 02, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Dell 6400 hangs and then crashes
Try replacing or upgrading your RAM it sounds like your PC is overworked and the bsod is probably a result of data loss due to low ram
Aug 18, 2008 | Computers & Internet
Uninstall Vista
you cannot uninstall vista from control panel.
Aug 15, 2008 | Computers & Internet
When i last install Adobe Photoshop its ok... but after i reformat and try to install its ok also... but when i run... IT says Direct3d not supported... on the last reformat the directX is working fine...
It's important to let me know the operating system installed on the system with the system configuration. I will be glad if you can at least reply my post with those info.
I guess you are running windows Xp with the chipset which doesn't support Direct X 10 or newer version. Or in other words, windows vista or windows 7 with incompatible chipset for directX newer version.
First uninstall the currently installed DirectX and reinstall Direct X 9. You have to uninstall the currently installed direct x properly, and it's also important to clean the registry after it's uninstalled. After it's removed, restart your computer and reinstall Direct X 9. That'll definitely fix your problem.
If you need my further help, let me know with the details i've mentioned above so that I can help you better and with easiest instrucitons/methods.
Good luck.
Thanks for using FixYa.
Aug 30, 2010 | Adobe Photoshop CS for PC
How to reformat a computer?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Jul 19, 2010 | Microsoft Windows XP Professional
My laptop had been working fine, then the last
Hi yes try this, if no joy come back to me.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing ESC button, or delete in some machines. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Jul 10, 2010 | IBM ThinkPad A30 Notebook
Application error when trying to open futura
Futura installation integrity might be damaged, you need to uninstall everything Futura related, reboot pc and install from the beginning.
If you already did reinstall Futura but still get the error, you may launch troubleshooting utility and send its report to Singer.
Mar 23, 2010 | Singer CE-200 Quantum Futura Computerized...
HDD Reformatting
why not reinstall sp3 again for windows xp if it freezes then it might be looking for files that don't exist anymore. If the virus attatched itself to your files they may have been removed when you ran your virus software. you don't need to format to reload windows. Just simply do a clean reinstall on C drive.
Oct 23, 2008 | Microsoft Windows XP Professional With...
Can't reinstall windows xp
hmmm its seems your HDD is of SATA interface and XP is not able to detect the HDD interface. you can solve this problem by making SATA Disabled in BIOS setup.
Try to make disabled SATA from BIOS, and then make install.
If any problem... Ask me
Thanks
Iqbal
Apr 05, 2008 | HP Compaq Presario C304NR Notebook
How to install XP in toshiba Satellite L45-S7423 laptop
You cannot uninstall Windows Vista, but you can reinstall your previous operating system, which then replaces Windows Vista. To reinstall your old operating system, you must have the original installation disc. Back up your programs and files, insert the installation disc into your computer, and then reinstall the old operating system. To regain the hard disk space used by Windows Vista, reformat the disk during the reinstallation process. After reinstalling your previous operating system, reinstall your programs and files.
Feb 29, 2008 | Microsoft Windows XP Professional
Microsoft Windows XP Home Edition Logo
93 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
