Question about Kenwood KDC-715S
Kenwood KDC-715s problem.
My Kenwood KDC-715s will not operate. The problem is the faceplate began to move and stopped. It opened and stopped at the halfway point and that is where it has stayed. It is in the correct position for removing the faceplate, so I did remove it and the backing plate moved back to the home postion. So it does have power. I reinstalled the face plate and it opened back up to the half way position and stopped. All the contacts are clean. This unit has been in servce since 2001' for about 30,000 miles in my car. I hate to think this is a throw away unit but as usual it would most likely be more cost effective to replace the unit instead of sending it out for repair. Any ideas on what the issue is or what to look for? Thanks, Rich.
  • 4 more comments
  • Rich Cote Dec 21, 2006
    Update on this problem.
    I purchased the service manual for this unit from user-manuals.com. Its a pretty good manual but it does not give instructions on how to service it. It does have incredible detail in the exploded view diagrams and if you are mechanically inclined and have a bit of patience you can pretty easily figure things out. I've taken it apart as far as the whole front plate drive assembly and it looks like a tiny switch might be the culprit.
    I'm almost sure the problem is with the PS1 switch.
    Part# S68-0829-05
    I will need to spend more time on it to test this individual switch. I've been taking pictures along the way to record my progress.
    If anyone is interested I can E mail pictures. Just let me know.
    I will post back later with my results. Although it may be after the holidays.
    P.S.
    Woodchuck, if you are reading this I hope you didn't scrap your deck yet. I think we can save it. Or if you like I can take it off your hands. $$$?
  • Rich Cote Dec 22, 2006
    Repairguy.
    Thank you for your comment. As it turns out, after further testing, you are 100% correct. I will try to order the flexible cable. I do have another question in regards to installing this cable. Where it passes through the shaft with the torsion spring, do you know how much tension should be preloaded on the spring? When I removed the cable the shaft unwound and I did not notice how many turns it rotated. Seems wierd to have that cable go through the shaft and get wounded. Seems like a stress point and a guaranteed failure over time.
    Any thoughts would be appreciated. The service manual isn't much of a service manual as far as describing procedures on how to do something. It basically just gives specifications. I would think that somewhere along the line there must be more inforamtion.
    Thanks for your previous reply.
    Rich.
  • Rich Cote Jan 05, 2007
    Update.
    I was able to buy the flexible printed circuit, part# J84-0106-12 for $12.00, and I was successfull in fixing this unit. It wasn't as easy as I had hoped but it really isn't that difficult. It does require a fair amount of patience and time. I spent a number of hours over the past month studying this unit and gathering information as well as a few tools. I also purchased another used KDC 715s just in case I wasn't successfull in my repairs. Now I have two fully functional KDC 715s head units. Sweet!
    If anyone else has this same problem with this model feal free to contact me. I will gladly help in any way I can. I have many digital pictures that I took along the way. Thanks to all who replied on this.
    GRTPUMPKIN.
  • Rich Cote Jan 24, 2007
    jscott2two.
    What do you mean? "Could you send me what you sent the first guy?"
    What kind of help do you need? Are you refering to a disfunctional KDC 715s?
    Let me know as I have successfully repaired two of these so far.
    grtpumpkin.
  • ThePlayer Sep 01, 2008
    Hi Guys
    Thanks your information has been very useful. Looking at the head unit, I guessed it may be the flexible printed circuit as it is the weakest link. I have order the J84-0106-12 . If you have any pictures os service manual you can send me to help me fit it, I would be most greatful. This is a real design issue of the unit.
    Regards
    AC
    acurtis_@hotmail.com
  • SOCCERJOC Jan 03, 2009
    I also have a 715s. With a problem! I was warming up my truck thanks to all the snow we had in Or. anyway the unit was on and playing just fine. We I got back in my truck (15- 20 min later) it was not working anymore!? It will not turn on or stay in the appropriate position. Can someone please help me before I go totally NUTS!
    Scholar:
  • 119 Answers
The kenwoods with the motorized face platesdevelop one problem with time. the flexable ribbon cable between the main unit & the face plate. as the face open & closes, over time wares out the cable. problem consists of face plate not opening/closing, display missing & and/or some or all buttons not working. note these can also be intermittent problems. typically the part number is located on the cable itself on the side where it pluggs into the main board. since you have a service manual, you should verify it in the manual. good luck.
Posted on Dec 21, 2006
I don't have a solution for you, but my KDC-715s developed the EXACT same problem a few days ago. I've emailed Kenwood tech support for advice. If they say it has to go to a repair depot, I'll be scrapping it and buying something else. If that happens, I'll have a perfectly good 10 disc changer and cables available for cheap, if you are interested! If Kenwood DOES have a useful answer, I'll post it here. They say it usually takes them a few days to respond.
Posted on Dec 05, 2006
  • MIke Andrews Dec 11, 2006
    Kenwood tech support didn't offer much in the way of useful suggestions. They said try the reset button or take it to a Kenwood authorized service center. I scrapped it and bought a Sony that sounds just as good, and cost less than half as much. It will even play wma and mp3's, which the Kenwood would not do. It also comes with a wireless remote! No more Kenwood products for me.
I have a kenwood excelon kdc-x869.the gears striped on the faceplate when my knee hit the faceplate.installed new gears but cant get switch in right position to operate right.
The gear which moves the lever that opens and closes the face position sensor switch needs to be installed correctly. The best way is to have face horizontal and try to position the gear so the lever closes the switch.
Jul 07, 2011 | Car Audio & Video
Need to get the security code for Kenwood KDC-608OR
ok I just found this info online and they say it came from the service manual for that stereo so I hope it helps:
You will need a Kenwood RC-410 remote control. This remote works on KDC-519, KDC-X859, KDC-319, KDC-4019, KDC-MP919, KDC-X759, KDC-419, KDC-X459, KDC-MPV619, KDC-MPV7019, KDC-2022, KDC-2022V, KRC-435, KRC-535 and KDC-X959
To reset the code do the following:
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
Above information source = http://techbybucky.blogspot.com/2008/01/how-to-reset-security-code-on-kenwood.html
Jun 19, 2011 | Kenwood Car Audio & Video
Need wirering diagram for my kenwood hdc-715s.
You can get the wiring diagram on the link below page 42.
http://manual.kenwood.com/files/B64-1603-10.pdf
Good Luck
Nov 21, 2010 | Kenwood KDC-715S
I purchased a car with a kdc x492 kewood and faceplate, the faceplate was missing what other kenwood faceplates are compatible with this one.
the best you can do is try to find the same model of your kenwood. there is no replacement faceplate w/ other kenwood product..
May 28, 2010 | Kenwood KDC-X492 Car CD/ MP3 Player
I have the same problem that the Grtpumpkin solved.
you have a bad flexible cable. it needs to be replaced. unless you are good at soldering i would not recommend you replace it yourself, as the connector needs to be unsoldered from the old cable and resoldered on the new one.
Aug 24, 2009 | Kenwood KDC-715S
Need a user manual plzz
Please click HERE to download Free copy of user manual of Kenwood KDC-715S
Website will require any of your email address to start download file.
Feb 14, 2009 | Kenwood KDC-715S
Faceplate is stuck on protect
hi sounds like you have a speaker issue,
try disconnecting the speakers and reconnecting them one at a time.
either that or the power output stage is faulty
Mark
Nov 15, 2008 | Kenwood KDC-715S
Manually opening a Kenwood motorized face
hi if you pop off the top cover you should see a motor on the right hand side, with a flexi cable connected to it, if you unplug the Flrxi from the pcb, you can then use a pp3 (9v) type battery to power up the motor. this will be much esier than manually moving the gears.
be sure to remove the flexi first otherwise you WILL damage the motor driver.
Regards
Mark
Jul 23, 2008 | Kenwood KDC-715S
My stereo
Here is the manual from Kenwoodusa.com
Wiring info begins on page 42
http://inform3.kenwoodusa.com/manuals%5CKDCX715.pdf
Best of Luck.
Nov 14, 2007 | Kenwood KDC-715S
Kenwood KDC-715S Logo
636 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
