I only have the camera for two months. At first the flash worked well for night pictures but now all night or indoor pictures are dark. No matter how i change the settings i cannot get the pictures to lighten up. Any suggestions?
-   my prom pictures are extremley dark.I can only see my teeth and my boyfreinds in the pictures how can i lighten them i tried everyhting any help? pleaseee -   Guest
Aug 02, 2008
-   I have the Canon Powershot. Indoor pictures come out darker when using the built in flash as aposed to using NO flash. I purchased a very expensive soft-box (strobe flash) because someone suggested that maybe the built-in flash was not enough. Well, the pictures are now DARKER then ever when using the strobe flash. Help! -   FranksDC
Mar 06, 2008
-   made sure the flash was working--what now?-   Guest
Jan 16, 2008
-   My camera is also a year old and I used to be able to take beautiful indoor pictures with the flash, but lately the pictures turn out dark or black when I use the flash-   Guest
Best Solution
posted on Jun 03, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Chuck it away, and buy a Pentax. I've had nothing but problems with my A350. Appalling piece of kit where batteries can go 2minutes after replacing them. Disgraceful shoddy kit.
the culprit is in the flash (electronic) section. Replacement of the module or repair on a component level can be done in Authorized Panasonic Service.
I had the exact same problem and decided that rather than throw it away which would be second.... I took the back off to see if there was anything i could do. What happened was my cats knocked it over one day and you will see inside there is a battery that is right below the circuits for the two buttoms that control flash and picture. I gave it a little push tighter up to the circuits (they weren't making proper contact) and then after a successful trial shot, put it back together and it is working perfectly. It's amazing to think that a forced movement inside of this device will completely set it off. And I can't even imagine how much money I saved. Knowing full well we don't often get 100% honesty when taking a device in to be fixed. :)
In the menu under the the 2nd option, you can adjust flash settings. Under flash control, I switched to the pre-flashttl option and was able to take pictures with the flash after having the same problem.
I keepgetting a large blurred spotin the middle of thepicture when taking pics inside-I have tried...
(More)
I keepgetting a large blurred spotin the middle of thepicture when taking pics inside-I have tried all types of lighting,etc. and it still occurs. ALso how do I turn off backlight? Fro indoor shooting whcih of the setting (camera, heart, flower,etc shoudl I be using?
I replaced the battery and sometimes I turn it on and it indeed does turn on and other times I turn...
(More)
I replaced the battery and sometimes I turn it on and it indeed does turn on and other times I turn it on and it does nothing, It's not the battery.
