Question about Dryers
How do you replace the drive belt on Whirlpool dryer?
The drive belt has come off the motor. The tensioner wheel has come loose and is laying on the bottom of the dryer box.
How do you replace the drive belt and attach the tensioner wheel?
    Scholar:
  • 66 Answers
What is the model number of the dryer.
Posted on Nov 14, 2008
How do you install the belt to the belt tension wheel?
If the model number you listed this question under is correct, changing the drive belt involves the following steps (skip down to step 6 for instructions on how to route the belt on the belt tensioner and motor pulley):
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. Release the belt tension, by pushing the idler pulley (tensioner) to the right (away from the belt) and remove the old belt from around the drum.
If the belt has broken, this may sometimes cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt and re-install the pulley, follow these steps:
6. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
7. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
8. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and push the wheel to the RIGHT while pulling the belt over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for WHIRLPOOL and refer to diagram H (This model is manufactured by Whirlpool).
Replacement parts (if required) can be ordered on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number for a replacement belt is 341241. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also include helpful exploded view diagrams that can help you locate and properly identify the parts you may need. you can view a diagram of the belt and tensioner under the "Cabinet Parts" section.
NOTE: If you still have the Teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The Teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assistant may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run.
Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them. If you have any questions about this repair, please post back and let me know. I hope this helps you.
Aug 27, 2010 | Kenmore 74602 Gas Dryer
Need to replace drum belt
Most dryers have a tensioner pulley that the belt needs to go around to keep it tight. The belt goes around the motor pulley and the drum, but it goes around the tensioner pulley in a way that would keep it tight (you also need to release the tension on the tensioner to get the belt around it) If there's not a tensioner pulley there has to be some other means of putting tension on that belt, look around the the other pulleys that the belt goes around.
May 07, 2010 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
The pulley and brcket fell off it's position laying in the bottom of the dryer don't know how it goes ?
If you are referring to the tension pulley that keeps the belt tight on the drum, just follow these steps to reinstall:
1. Make sure the drive belt is looped around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belts. A replacement pulley can be ordered on line at any of the following websites:
repairclinic.com
The part number is 691366 (if needed).
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate around the dryer door opening) so that I may be able to confirm your dryer configuration. I hope this helps you.
Feb 13, 2010 | Whirlpool Dryers
Belt drum replacement
If this is a Whirlpool manufactured dryer (which inlcudes Kenmore, Roper, Estate, Kitchenaid, and Frigidaire), just follow these steps:
a. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
b. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
c. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and locate diagram H.
NOTE: It is normal for the idler pulley to come loose when there is no belt tension.
If your dryer is not manufactured by Whirlpool, or if you simply aren't sure, please post back with your model number so I can give you more accurate information. I hope you find this helpful.
Sep 01, 2009 | Dryers
Belt came off tensioner, and tensioner off unit.
Here is the tensioner diagram you need, for most any dryer.
http://www.applianceaid.com/images/belt-config.JPG
First clean and lubricate the axel of the wheel with some spray silicone. Try not to get it on the wheel outer surface.
Then locate the slot in the bottom of the cabinet floor. The wheel should line up with the drive wheel at the end of the motor shaft.
Place the tang of the tensioner in the slot.
Press the wheel wayyy back passing a loop of the belt BELOW the tensioner wheel and loop it over the end of the small drive wheel.
Release tension on the tensioner and the wheel will pull it taught.
Aug 13, 2009 | Whirlpool Dryers
Whirlpool model WGD5300SQ dryer belt is off, roller is laying loose, is there a diagram?
If the belt slipped off, this will cause the idler pulley to come loose. This is normal with no tension on the pulley to hold it in place. To re-install, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H. If you still have questions, please let me know. I hope this helps you.
Jul 18, 2009 | Dryers
The Belt Tensioner came off of my Whirlpool WED5300SQ0 Dryer
Jul 14, 2009 | Dryers
Need to install drive belt- lady kenmore dryer..loop designation
The belt probably broke first, which caused the idler pulley to come loose. This is normal. With no tension on the pulley it will commonly fall over. To re-install, follow these steps:
1. Loop the new drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. If this is a Kenmore dryer, it will be manufactured by Whirlpool. Refer to diagram H. If you still have questions, please let me know. I hope this helps you.
Jun 25, 2009 | Dryers
Dryer belt broke and the wheel tying the belt to the motor somehow come loose and was laying on bottom of dryer when I went to replace the belt, need schematics to figure out how to put wheel back in...
Below the motor pulley is two sets of parallel slots and some notches running perpendicular to them. Look at the tensioner, the piece that is laying on its side. Notice opposite of the roller is a flat surface with flanges that line up to the holes below the motor pulley. Ok? Alright now we want to scoop the front into one of those notches and it will hold. Now the belt goes over this roller on the tensioner first pushing slightly away from the motor pulley causing enough slack to loop it around the motor pulley so it goes over then around. Have someone hold the drum and steady so you can reach in, ps make sure the dryer is unplugged.:)
Ok here is a site I use to get illustrated, Look it over and punch in your model so you can see roughly how to get er done. Notice item 53 this is on my dryer, use www.apdepot.com.
Sep 29, 2008 | Dryers
Fitting tumble dryer drive belt
Looking from rear of dryer,one spring on motor is for tension,therefore put belt around drum(groove to the drum surface).Then rotate the motor firmly clockwise tensioning the spring,take belt from right of drum over tension wheel then put grooves of belt on shaft of motor.Release motor to tension spring,job done !!!!!
Mar 28, 2008 | Dryers
Dryers Logo
128 people viewed this question
Top Dryers Experts
