Question about Sharp CD-ES600 CD Shelf System
Error code CD01
I have a Sharp CD-ES600 CD Shelf System and i get this error code (CD error 01) and all the f changers are lit up on the display when there is no cd's in it. Please help.
  • 54 Answers
SOURCE: Error code H5 01
It means you have had 5 jams in a row in the fusing unit. Open the left side door of the copier (roll the finisher out of the way if you have one). Open the green handle on the top of the fusing unit and carefully remove all of the pages stuck in there. You can use the green wheel at the back to turn the rollers if need be. If you have no jam, then someone already removed it and you just need to reset the code. to reset the code, push P * Clear * on the numeric pad. when it says enter simulation number, enter 14 and push the Start button for black and white copies. The machine will reboot and your code should be gone.
If you keep getting jams, you may have knocked the Fuser exit sensor arm out of place.
Please don't forget to rate your answers.
Posted on Dec 22, 2007
zair
  • 82 Answers
SOURCE: Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Posted on Mar 29, 2008
  • 4234 Answers
SOURCE: ER message for CD, Sharp GX-CH150
The optics assembly is having a problem. Either it can not read the disc at all or the disc is not spinning. In any case, the unit will require service. If you can reach the lens, try cleaning it using a cotton swab and alcohol. That may resolve the problem. If not, update this. Please try to see whether or not the disc spins and report that as well.
Thanks,
Dan
Posted on Apr 07, 2008
SOURCE: CD problem in Sharp Micro Component Shelf system XL-HP515
Compra un disco limpiador de lentes laser y puede que esto solucione tu problema ya que puede ser solo suciedad en el lente.
Posted on Apr 09, 2008
  • 148 Answers
SOURCE: Service Mode On Sharp SF2530
A little rusty on this machine, but try this.
This code means you have had to many paper jams in the fuser without removal. Make sure all is clear in the fuser and exit sections.
Then on the control panel you will press a series of buttons as follows.
Press the Clear, Press interrupt, Press Zero, Press interrupt, Enter # 14, Press start, That should reset the machine...
Hope that helps...
Lbcoaster
Posted on Jul 02, 2008
CD changer won't open. Mechanical Error on display
There is a small hole just above the door on most CD changers. Unwind a small paper clip and GENTLY push it into the hole. This should release the door, and let you look inside. Don't force it because you could damage it more than it is already.
Jun 15, 2012 | Yamaha GX-700 Shelf System
Reset
Just unplug the system from AC mains wall socket, and replug it after 3 minutes or so. This is the reset process to your set.
Mar 09, 2012 | Sharp XL-DK225 Shelf System
THE SYSTEM SHOWS ME ER-CD01 AND ALSO THE PLAYER WONT PLAY THE CD, IT DOESN'T EVEN READ THE CD
this is a standard reset so if its a problem with the programming this should do the trick if it does not either your cd or laser lens is no longer doing its job properly
turn on the set-press the on stanby button,allow the set to enter demo mode. now press the power button while pressing the stop and eject button,clear all will display
hope this helps
Robb
Apr 23, 2010 | Sharp CD-MPX850 Shelf System
The cd player stopped working what should i do
the first thing you got to do is clean the laser lens
Oct 22, 2009 | Sharp CD-ES600 CD Shelf System
CD CHANGER DOSE NOT OPEN AND AN ERROR CODE APEARS
If an error occurs ond the trey does not eject, the problem is most probably that the cd is crammed in the wrong way. So now you need to force eject the trey. This will not do any damage to your device, so even if this is not the problem, you should be able to get out the cd that is stuck.
There is a little hole near the eject button, you need to push a pin into the hole untill you feel there is a resstance. Then gently pull out the trey while holding the pin in the hole.
This should work perfectly. Please rate this.
Best regards
Sep 29, 2009 | Sharp Multi-System Mini Component System...
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Cd won't open
First find out what the error code means.
Dec 29, 2007 | Sharp CD-BA2600 CD Shelf System
CD Changer MEC ERROR
i have the same problem!!!
do anybody knows how to fix it??
thank you very much
Oct 26, 2006 | Sony DHC-ZX50MD Shelf System
Sharp CD-ES600 CD Shelf System Logo
80 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
