Question about Hitachi (HL01114) Remote Control
Hitachi VTFX 600 c VHS
Hi am trying to change the speed from SP mode to LP Mode for recording a Tape - anyone Know How Does anyone have the Remote code for the VHS so I can go in and change the tape speed Thanks Duz
  • 66552 Answers
SOURCE: I am trying to find out the 4 digit remote code for my Hitachi TV
Try these codes.
0088 0059 0142 0060 0072 0004 0009 0091 0001 0012 0061 0137 0139 0141 0179 0227
Posted on Apr 07, 2012
0 characters
1 Points
Wheni push input, i get the options but no arrow i push will move down to option to play vhs
not enough info , if your trying to change the tv input , make sure you select tv on the universal remote first , you either need to keep pushing input til it moves down to your desired input , or use the arrow key to move it down to the input. some require you to hit enter or ok to select , others just wait a second , it should change. if your getting the options menu when your hitting input , then the remote is not compatible with your TV / VHS / DVD...
If you get the input to change and your successful , make sure you hit VHS in order to call a command , if its still in tv mode , your only going backwards , make sure whatever your trying to control , the remote is selected to that device ... Good Luck ..
The Cable Guy .... hope that helps !!!
Mar 12, 2015 | RCA RCR314WR Universal Remote Control For...
I can't find a code for my BOSE Solo on the Dish network Hopper remote. Can anyone help?
Don't go and search for IR codes as you'll waste your time. Use the learning method. Take your bose remote and put it on a flat surface and point it toward the little square receiver on the dish remote (located on the top left side). Then press the "aux" mode button on the dish remote until all the mode buttons light up and the aux mode light starts to blink. Then press the record button on the dish remote for 3 seconds until the aux mode button lights up and stays lit (it then stays lit during the whole learning program). On the dish remote press the button you want to learn but don't hold it down (I started with the up volume) . Then press the corresponding button on the bose remote but hold that down until the aux mode button blinks once and comes back on (if the mode button blinks three times the dish remote did not learn the command and you should try changing the batteries on the dish remote if it happens repeatedly that it fails to learn). Program the remaining commands by repeating the process of pressing a button on the remote, then pressing and holding the corresponding button on the bose remote. Don't be afraid to do it with the mute and the power buttons too. During this process if you don't press a button for more than 30 seconds it will time out and nothing will be recorded and you will need to start again. To end the programming press the aux mode button. When you are using the bose solo using the dish remote you just need to remember to press the aux mode button first so it flips to command the bose solo.
Dec 30, 2012 | DISH Network IR Remote Control
Receiver will not respond to remote
Woody Danforth,
Make sure the remote is in SAT mode, and try again. If it is, it sounds like the remote may just need to be re-addressed to the receiver. Access the system information screen. On the bottom if a 'Primary Remote Address' and a 'Secondary Remote Address'. Note the number listed.
With the remote in SAT mode, press the record button three times, and see if the remote address number changes. If not, hold the SAT button until all lights on the remote come on. Once they do, let go and SAT will be blinking. Enter a number between 1 and 15 (different from what's already listed) and press Pound (#). Press record 3 times again, and the number should change to the one you chose.
If it did, try the functions again and see if it is working, if it's still having problems let me know!
Tommy Faust
DISH Social Media Representative
Nov 11, 2012 | DISH Network IR Remote Control
Have a Hitachi Video Brain CLU-570PR. When I try to record vhs to a panasonic omnivision vhs, it records picture perfectly but NO sound. On an older TV I had to move the TV/VTR button to VTR to record,...
Hi, did the remote come with a manual?if it does,that means you will see the user's guide for the remote about the instruction and the different functions it has.
Also i guess the remote is not a universal remote or the reote is not the exact one for your system.It might not work properly with it...All buttons will not function properly..
Check those and get back to me..
May 05, 2011 | Remote Controls
Im trying to program my remote so all my compents will work on one remote but dish network doesn't have the code for my polaroid vhs/dvd player. The model no is dvc 2010. If anyone has the code please post...
Try these steps for progamming the remote, if this doesn't help there is a compatibility issue.
  1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate (about 3 seconds), then release.
  2. For AUX mode Power Scan ONLY: press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device, then press *.
  3. Press and release the Power button.
  4. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
  5. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
  6. To verify the code works try several different functions for that equipment.
Daniel Busa
DISH Network Customer Service
Jan 18, 2011 | Polaroid 1720-7 Remote Control
How do i get my JVC remote to get video to run in LP instead of SP when manually recording?
Usually you can change from SP to LP by pressing the record botton again. It works with some brands & models but not all. You will need to specify the JVC model # for exact instructions.
Oct 02, 2010 | JVC Remote Controls
I just brought universal remote control it an 8 way diital slx rc050 i can get it to pair with my accousic solutions sp 101 amp have you got any codes that would work for this please
try this if you need the manual let me know. (PLEASE rate if it was helpful)
If you are programming the remote for a brand/model that is
not listed in the Popular Brand List or the Direct Code Entry
(e.g. Wharfedale, Acoustic Solutions etc), it is recommended
that you use the Learning Mode (go to section 4).
Follow the steps below to program your remote using the
learning function.
1. Press and hold the device key you wish to learn for 3 secs.
The LED turns ON when the key is pressed but turns OFF
after 3 secs indicating that the key can be released.
2. Release the Device key, LED turns back ON.
3. Press and release the RECORD key, the LED turns off
when the key is pressed and turns on after release, the
remote is now in the learning mode.
4. Press and release the key on the RC050 that you want to
learn to, the LED will blink once and then remain ON with a
lower brightness to indicate it is ready to learn.
5. Face the head of RC050 to the head of your original
remote control, leaving a gap of 5cm (2”).
6. Now press and hold the original remote key (the teaching
key), do not release this key until the LED on the RC050
this indicates an error. Repeat steps 4-6 to correct the
7. LED remains on, repeat steps 4-6 for other key functions to
be learned.
8. Press and release EXIT key to exit learning mode at any
time, the LED turns off.
9. If no keys are pressed for more than 15 secs while in
this mode, the remote exits the mode and the LED turns
good luck
4. Learning Mode
Dec 18, 2009 | Remote Controls
Turn off control mode from telvision Hitachi
Easily as this:
Push both recording bottons, turn off tv form remote control, and switch it off from plugg for 1 minute. No more text on the screen!
Thank you
Aug 27, 2008 | Hitachi CLU-4324UG Remote Control
Remote Controls Logo
Top Hitachi Remote Controls Experts
Joseph Hoffmann
Are you a Hitachi Remote Control Expert? Answer questions, earn points and help others
