Question about Roper REX4634KQ Electric Dryer
Dryer won't turn on
A few days ago I dried a load and now my dryer will not turn on. I have checked the electrical circuit breakers and they are alright, I'm wondering maybe if there is something that could be a quick fix or if it is something more serious
  • ucfpunter9 Nov 15, 2008
    Dryer worked fine yesterday. Today...not even an attempt to turn on when the button is pushed.
  • 370 Answers
There is a white motor in the back of your dryer near the air duct (on left) This is what is keeping your dryer from starting. You can check the part with an ohm meater. The part number (there is 2 different ones) is either a et401 or et402. You can look at the part on the internet to know what it looks like when you are fixing it. Luckily the part is inexpensive.
Posted on Nov 17, 2008
  • Justin Duby
    Justin Duby Nov 17, 2008
    I meant motor fuse. sorry for the typo
DLE9577SM Power issues. Control board?
  1. Power the dryer OFF and unplug it from the electrical outlet (You can also trip the circuit breaker if that's easier).
  2. Press and hold the START/PAUSE key for 5 seconds while the unit is without power.
  3. Turn the breaker back on, and power on the unit.
Mar 29, 2017 | LG Dryers
Are there fuses in the dryer? Not getting hot. Could it be the heating element?
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 15, 2010 | Whirlpool WED5100SQ Front-Load Electric...
Dryer - GE model DRSR483 ED2WW Worked fine a few days ago with a light load. Now, just a loud beep when I try to start it. It doesn't come on. I can turn the drum manually (slowly) - almost sounds like...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 01, 2010 | GE DBSR453EBWW Electric Dryer
Dried a load fine, next load tumbles wont dry. still cant get heat
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 02, 2010 | Kenmore 63942 Dryer
My maytag front load dryer turns on and runs,it does not blow any hot air
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Jul 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Heavy loads (e.g., jeans, etc) is tripping the circuit breaker
WOW, 10yrs was a good investment of your money. Anyhow large amp loads may be contributed to the motor or fatigued heating elements. Also the breaker can wear out if its ran loaded for extended periods. Here are a few things you can try. Check to ensure that the barrel sleeve rings are in good condition so that there would be less drag on the motor and fix the obvious. Then change your breaker out and change the electrical outlet. if your not comfortable with changing these two items DON'T DO IT.
TIP OF THE DAY--To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer. :?) DRRXR
Feb 01, 2009 | Dryers
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryer problem
ck vent system to outside also ck the vent hose behind dryer to be sure it is not being mashed flat when pushed back..while you have it out ck to see if cord connection screws are tight loose screws can cause cord to overheat and melt insulation causing short..if breaker trips immediately suspect dryer if runs for a time before kicking suspect weak breaker
Aug 09, 2008 | Whirlpool WED5100SQ Front-Load Electric...
Whirlpool Dryer not heating
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Jul 14, 2008 | Whirlpool LER4634J Electric Dryer
Roper REX4634KQ Electric Dryer Logo
304 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
