Question about Xerox Phaser 8550DT Thermal Printer
Error Message I have a Xerox Phaser 8550 with Error Message 07,010,43:38611 How do I fix this?
  • 2,072 Answers
That is a problem with the print head tilt or side to side movement.First remove the right and left covers. Then on look on the left side ( looking at the machine from the front). About mid way back toward the bottom of the frams you will see a stainless steel block, about 1 inch square. See if there is ink in it. Normally you will see some yellow ink buildup in that block. There is a spring on a bracket that you have to slip off to remove and clean the block. If excessivly filled witih ink you may have to use some channel lock pliers to remove it. Soak the block in some pretty warm to hot water to slften the ink and clean the block and shafe off thoroughly. Then clean the print head shaft and remove as much loose ink as possible.
The second most likely problem is that the print head wiper blade has stuck to the print head. You then have to remove the ink loader, ( where you insert the ink sticks. Once that is removed you can access the print head/drum area. The blade is pink in color and if tacked to the print head, remove gently. Then run a couple of cleaning cycles and also the remove light stripes cycle. The blade will mostly stick if the machine it shut off improperly or there is a power failure. The clutch that drives the wipe may be bad, although far less likely.
Those are the 2 most common problems that give that code. I would say those 2 resolve that problem more than 70 percent of the time. But that code means the print head is not moving side to side or front to ack properly.
Hope this helps , it should.
Posted on Nov 14, 2008
Hey guys this is a Xerox Phaser 7750 and 7760 fan error video tutorial.
In this video you will learn how to fix the error code 48 on the Xerox phaser 7750.
Also you will learn how to fix the error codes 010-391,010-392,010-398 that are related to the Xerox Phaser 7760.
This video shows how to remove covers.
All the wires that you need to disconnect from the machine to fix these errors.
There is also another video part two that shows you how to reinstall everything back
in it’s place. Step by step tutorial hope you enjoy.
on Dec 30, 2009 | Office Equipment & Supplies
ERROR MESSAGE PHASER 8560 09,006.41:150694
9,006.41: The magenta ink melt heater is On, but ink is not dripping.
Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink cubes.
Apr 07, 2014 | Xerox Phaser 8560MFP Laser Printer
Error message Xerox Phaser 8400
The post was a little confusing. You have an 8400, correct? (not an M20)
The 07,010 error is normally a bad process motor 401-1000-80
You should also change 2 camshafts at the same time 401-1003-80 and 384-1874-80. The whole job is medium difficult and takes 2-3 hours.
Item, Inc.
May 09, 2010 | Xerox WorkCentre M20i All-In-One Laser...
7,010.43:40975 error message for the Xerox Phaser 8500 printer.
The printhead is stuck in the tilted position. Did you have a power outage or turn it off by unpuging it? Not hard to fix but you have to tear it down and rehome everything. sometimes if you turn it off and turn it back on it will find home on itself. But rehomeing it works every time. If you dont know how to do this call a service center.
Apr 28, 2010 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 error 13,327.42:31555
If you have Warranty Still, CALL XEROX!!!, That error message indicates that you have a failed temprature sensor inside the print-head, 90% chance Xerox will have to replace print-head. Print head is VERY expensive to replace out of pocket ($500-800+)
Jan 23, 2009 | Xerox Phaser 8500/DN Printer
Phaser 7300 Error Code/Message
Seems to be something to do with the Ram.
More help HERE
Jun 01, 2008 | Xerox Phaser 7300DN Laser Printer
Error message
This message is related to the on-board SRAM on the Print Engine Control Board Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Replaced the Print Engine Control Board,
Dec 19, 2007 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Oct 22, 2007 | Xerox Phaser 6100/BD Laser Printer
Xerox Phaser 8550DT Thermal Printer Logo
133 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
