Question about GE ZICS360NMRH Monogram® 36" Built-In Bottom-Freezer Refrigerator (ZICS-360NMRH, ZICS 360NMRH)
Door on Monogram ZIR36N won't pull closed and stay shut
Does pull with authority as if grabbed by a magnet. When push totally closed it will back off and stay open about 1/2 inch.
Noticed under the bottom door hinge that there is a bar with a spring, but I don't think that plays a role in holding the door shut
    Problem Solver:
  • 18 Answers
The spring is actually a door closure , are the wheels that the bar closure mechanism goes through and attaches to the spring moving freely? It is entirely possible that a bin in the fridge is keeping the door open.
Posted on Nov 14, 2008
My GE Monogram Frig door will not stay shut, it's lost its vacuum seal!
Check the fridge for out of level. Magnets on the weather-stripping hold the door closed. If there is something stuck on the seal, or too much weight in the door in an un-level fridge it will not make good contact. Try cleaning the rubber, and removing everything from the door after leveling. A good seal will stay closed even if the fridge is off.
Feb 23, 2015 | GE Monogram ZISS480DRSS Stainless Steel
My freezer door used to **** shut now it easily pops open
What you are talking about sounds like the magnets in the door seal are weak.
Mar 10, 2014 | Frigidaire Freezers
Back door won't close
take a philips screwdriver in between where the latch grabs the part of your car its is a circular area and release the latch at the same time pull down on the screwdriver and it will pull the latch back in the correct position to be able to agai n latch to the cars part of the latch to grab to
Dec 01, 2012 | 1994 Chevrolet Suburban
Weber cabinet door won't stay shut
Try moving the catch foward there are two screws on the sides you can losen and move the catch
Feb 20, 2012 | Weber Genesis E-320
My refrigerator Door (Whirlpool Gold)does not close like it shoul
You need to bend the door, if the gap is at the top put your foot between the frig door and the bottom and push the door closed slightly. so you can check it and do a small amount at a time. till tou reach the point that the door closes tight. if the gap is at the bottom put a shoe or something about 4 to 5 inches wide. go for it you can fix this..... saw
Dec 05, 2009 | Washing Machines
Freezer side door opens when large refrgerator door is closed
no promblem when you shut one door it forces air to the other side remove the kick plate at the bottom adjust the rollers till the fridge leans back i set them so when you turn loose of the door slightly past the halfway position it shuts its self that way when it pops open it shuts its self
Feb 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Freezer door won't stay shut
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
Jan 18, 2009 | Refrigerators
Right side french door does not stay closed
I had the same problem - had my local appliance repair shop come by - simple releveling of the unit such that it is tilted slightly back re-establishes things so that the doors will cloe and pull themselves closed. The gaskets are actually magnetized. If the leveling is correct - even upon closing the left door - forcing enough pressure to push open slightly the right side - it will draw itself back in.
Nov 21, 2008 | Jenn-Air JFC2089HE French Door...
I have the exact same problem - very annoying. The only thing I found to work was to purchase one of those child safety locks. I bought the Kidco Appliance Fridge Lock S330 because it was the only one I could find that automatically relocks after you shut the door. Buy two (or more) at a time because the arm will eventually wear out and break (after several months depending on how often you use it). You can check out the product's details on eBay - that's where I purchased mine. Hope that helps.
Aug 27, 2008 | GE GTS22KBP Top Freezer Refrigerator
Freezer Door Won't Stay Shut
OK LOOSEN THE HINGE THAT SUPPORTS THE FREEZER DOOR.IT'S ON TOP AND HAS 3 SCREWS .JUST LOOSEN AND NOT REMOVE THEM.NOW LIFT UP THE DOOR UNTIL IT LINES UP EVEN WITH THE OTHER DOOR.AT THE SAME TIME TIGHTEN ALL 3 SCREWS. YOUR DONE!!!
PLEASE RATE THIS. THANX!!
Jun 06, 2008 | GE GSS25QSTSS Stainless Steel
Refrigerators Logo
294 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
