Question about Scotsman Cooled Modular Contour Cuber Air Condensed 975lbs
The scotsman ice machine makes ice fine, but
Once the bin is full and the machine cuts off it will not start again by itself . I can put it in freeze mode it will automatically come on and work fine until it fills up again and cuts back off
  • bjmrfixit Jan 23, 2009
    when the ice bin is full it shuts off and has to be manually restarted....any one know what I am dealling with?
  • Beto Flores
    Beto Flores May 11, 2010
    sounds like a controller problem...mdoes the bin full light stay on after you femove ice.
I have a machine of scotsman MV 21 how i adjust the qube size
Posted on Jan 12, 2009
Once full, ice melts and then doesn't start making ice again until bin is completely empty
There should be a temperature sensor (thermostat) close to the top of where the ice comes out of. This determines the height of the ice in the bin by controlling a call for cooling/making ice. This thermostat may be sticking, or is not sensitive enough to read the drop in temperature of the depletion of ice.
Feb 27, 2015 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman ice machine water runs continually never shuts off. It will make ice but really racks up water bill. It is as if the float never senses the reservoir is full. What is my problem?
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
Jan 12, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
Not makeing ice
There could be over 50 things that will not let that machine make ice so help me out. when in freeze mode is compressor running, is condenser fan running, is water pump running, check condenser coil to make sure it's not full of dirt if so blow it out, cut machine off if water sump tray is full of water and you can still here water coming in at all check water flote to much water coming in all the time will not let water freeze. Fell evaporator plate while running if warm to touch could be hot gas valve letting hot gas in to plate in freeze cycle. you need to call a service company
Jan 08, 2014 | Scotsman Kitchen Appliances - Others
Scotsman ice maker cme1356 remain on harvest
Check bin full sensors make sure that the wires are making good contact on the board and make sure they are working run your hand between them you should see the bin full light come on the board if not replace the bin full sensors. If the light comes on then replace the board.
May 25, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My scotsman model 506as 1f, serial no. 06021320015994. Was running fine until i had it sent in to a local shop for routine check up during the normal winter down time for the machine. When i started using...
Have you pulled the cover off so you can see the code it is giving really need to know it. sounds like either low charge or hot gas valve not opening during harvest. I really need the code to be able to help you out.
Jul 07, 2011 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Should a scotsman ice machine automatically stop making ice once the bin is full
Yes, all ice machines have a means of automatic shut down when the bin is full. What is the model number of your machine and your bin?
Dec 16, 2010 | Scotsman Ice Machine, Cuber, 1930 lb....
Scotsman 500 cm3 ice machine
Remove all molex connections and check for corrosion. Clean the connections and retry.
Jul 17, 2008 | Scotsman Ice Maker 600LB CM3 30inW...
Scotsman Cooled Modular Contour Cuber Air Condensed 975lbs Logo
647 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
