Question about Casio OC500 Oceanus watch
Changing the band on my casio oceanus 500 wristwatch
What tool do I need to swap the ******** my casio oceanus wrist watch and where can I buy it. It is not a flat screw and not a philip. It is a hex.
  • Anonymous Dec 30, 2008
    same problem can some one help
If its an OC500, I just figured it out. There are two sides of the pin visible. One has a dimple and one is completely smooth. Use a small phillips or a punch that is the same diameter as the pin and push on the side with the dimple. The pin pushs in only about 1/4 inch and the smooth side protrudes from the other end. Pull or pry on the smooth end to extract it. The pin is actually 2 parts so be careful not to lose the dimple side piece.
Posted on Dec 15, 2009
I am trying to figure out how to shorten the wrist band on my Casio Edifice EFA-119.
mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
Aug 03, 2010 | Casio Edifice EFA109-7AV Wrist Watch
Casio F91W-1 Wrist Watch- backlight color
You can change the backlight on a casio wristwatch by holding the Light button, but only if it has an LED light in the side of the screen such as yours does. There is Light Blue, Red, Pink, Blue, Green LEDs in the side of the screen and you can change between them. There is also an option that flashes between all the LEDs when you press the button.
May 06, 2010 | Casio F91W-1 Wrist Watch
To change battery
If you don't have the proper tools I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry2_bing.gif store can change the battery and renew the gasket for you.
Apr 10, 2010 | Casio OC500 Oceanus watch
Where can we buy replacement watch bands for this watch Casio DW-9052
You can buy genuine Casio watch bands from www.tiktox.com
Check out there website first.You can order online,or give them a call.
Make sure you have measured the shoulder correctly when ordering a new watch band.Your watch model number will help in the search on their website.
Apr 07, 2010 | Casio DW9052-1V Wrist Watch
How can I change the battery in my Casio Oceanus Oc-501? What battery does it take please and do I need to reseal the back?
I dont recommend anyone change their own battery unless they have the proper tools to open and close it! If the case back unscrews then you need a case wrench...if it pops off with a knife then you will need a case press to close it or else risk breaking the crystal! Most require equal pressure around the entire edge of the case back! Save yourself time and frustration and possible damage and take it to a reputable watch repair shop!
Jan 19, 2010 | Casio Oceanus Watch OC503
WHERE CAN I BUY A BAND FOR THIS WATCH GW500A
On Amazon.com. Search for
Casio Factory G-Shock GW-500
Dec 20, 2009 | Casio G-Shock GW500A-1V Wrist Watch
Broken wrist band
The easiest is to bring it to Wal-Mart, or another store with a watch section in their store, if you buy a new wrist band, they;ll put it on for free. If you're feeling DIY, pull the watch band to the side, untill the metal bar inside is ejected form the slot in the watch, from there, insert the new band's bar into the slot, and voila!
Nov 15, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
I NEED A WRIST BAN A CASIO OCEANUS 0 C 500
i just found some on ebay... i need one too! $24.95 plus shipping though.. not cheap. just search "oc-500 band"
Feb 02, 2008 | Watches
Casio Baby-G BG-460
You do not have to take the watch apart to replace the band. You will need a spring bar tool to do this.
Jan 26, 2008 | Casio Baby-G BG169-2V Wrist Watch
Casio OC500 Oceanus watch Logo
1,062 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
