Question about Acer Aspire 5315 Notebook
Sound problems sound not play and not display the sound icon on task bar.
  • jane112587 Nov 16, 2008
    from windows vista i change my operating system to windows xp on my acer 5315, everything is fine except for the sound. i can't hear any sound from my laptop at all.
  • 903 Answers
Try going to device manager and see if the audio device is still there. Go to control panel>system>device manager (if using vista) or control panel>system>hardware>device manager if using xp. Right click the + sign next to audio and click on properties. Then click on update driver. If this does not help go on the link below for drivers.
Posted on Nov 14, 2008
    Problem Solver:
  • 17 Answers
Well, the driver is not installed properly.. you must install it first so that u can use your cam.. f installed already, check your connections and make sure your cam is detected by your computer
There is no sound in my system
Pls check if sound icon is seen in your task bar near time display,if not then add sound driver if it is present then check whether it got mute by mistake
Apr 14, 2013 | Dell E198FP 19" LCD Monitor
Sound is not
1) Check the task bar sound icon mute active or not (Tick mark view on mute box)
2) Sound icon not in task bar check device settings.
3) Go control panel > System > Hardware > Device manager
4) Sound, Video, game controllers view problems.
5) Re-install Sound card driver.
Mar 26, 2011 | Computers & Internet
Windows Media Player cannot play the file because there is a problem with your sound device. There may not be a sound device installed on your computer, it may be in use by another program, or it may not...
Go to your speaker icon in the bottom right corner of the task bar and click on it.A slider will be seen click on slider and slide up the volume.Does this cure it?Has the icon got a red cross on it?This means it's not on restart the computer.Go to(win 7) Start,Control panel,Hardware and sounds,click on this.You will see Auto play and Sound,check these two items out to see if this is the reason for your fault.
Aug 12, 2010 | Computers & Internet
All of a sudden the sound went out on youtube. the videos play just fine but with no sound
1. check your volume on the video screen in Youtube
2. check the volume control in the Windows setting ( task bar>> lower right hand part of the screen)
3. you may inadvertently muted the sound.
4. uncheck the box next to the volume if you see a check mark ( Window xp)
5. For Windows 7 click the speaker icon in the task bar and then click "mixer" you should now see a speaker Icon click on the icon then you should see a tab labeled "levels" you will see s microphone, aux etc. with an icon either muted or on.
6. If you hear no sound after that then try updating the drivers for you soundcard. This will require you to go into the "device manager".
Mar 23, 2010 | Office Equipment & Supplies
I can no longer get the sound on my quick play.
go to the control panel of your laptop, click on the sound and audio devices icon, on the volume tab de-select the mark from the place icon on task bar. And then select it again and click apply and then ok
Jan 25, 2010 | HP Pavilion dv9000z Notebook
I can't get my sound to work
The first thing to check are the speaker plugs. Depending on the options of your tower there could be up to six different plugs on the back of the tower. Usually the green colored plug is for audio out. Also check all the connections on the speakers for anything not plugged in correctly.
Next right click the speaker icon in the task bar. The task bar is located in the lower right hand corner of the display. A small window will open giving you 2 choices. Left click "Adjust Audio Properties". If you cannot locate it in the task bar then left click the "Start" button, left click "Control Panel" then double left click the "Sound and Audio Devices" icon. Make sure the "Mute" check box is not checked.
If you still have no sound then click on the "Hardware" tab on the "Sound and Audio Devices" window and left click the "Properties" button. This will open another window.
In this window under "General" tab check to see if it says "This Device Is Working Correctly". If not click the "Driver tab on this window. You will be given a choice to "Update The Driver" . Clicking this button will check for any updates to the sound driver.
If you still are without sound your problem may be a bad speaker wire or cable.
I hope this helps.
Oct 14, 2009 | E-Machines eMachines Desktop PC
I dont have volume icon in my task bar. sound r working. just icon iz not there when i ''select show icon in task bar it says that '' volume control programe not installed
Are you using WinXP?
Is so open
First window opens make sure the checkbox is checked that says
"Place Volumn Icon in Taskbar"
Jul 18, 2009 | Computers & Internet
I have an acer t671 tower. it recognises a speaker but the sound does not come out
your sound drivers may not be correct.
Do you have a volume icon in your task bar.
If not then go to control panel then sounds and audio device.See in there if you have the option to show icon in task bar.If the colour is faded and you can't change the options then it probably is a sound driver problem So you will need to reinstall your driver
Jan 10, 2009 | Acer Aspire™ T180 PC Desktop
I was given as a gift a acer aspire 3002CLi laptop and i must of muted the sound and i dont know where the volume control is please help.
hi, you want mute the sound ok, it's easy. After you enter the windows see the task bar it contains more icons and application .In the corner of the task bar you can see the clock or time display before that more icons there you see the sound icons it's like the speaker . Double click it the volume control comes select the first options volume bar and select the option mute all.if you could not get the icons from the task bar . then goto
  1. start menu
  2. control panel
  3. sound and volume controls
  4. select the sound control tab
here you can get the voume control tab . after all these process you cant get it please inform
Apr 28, 2008 | Computers & Internet
No sound on my laptop?
Start --> Control Panel --> Sounds and Audio Devices.
Make sure it is picking up the sound card and tick the box to show the icon in the task bar.
Click apply then open the sound control from the task bar and make sure nothing is muted.
Nov 27, 2007 | Emagic EMI 6|2m External Sound System
Acer Aspire 5315 Notebook Logo
126 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
