Home | Drills / Drivers | Charger not charging
Drills / Drivers
Problem for Drills / Drivers
Generic problem for all Drills / Drivers
By michaeltgree on Nov 14, 2008
I have a Ryobi 18v cordless drill model HP1802m, and I am trying to determine if my batteries are bad or the charger is bad. When I place the battery in the charger only the green and yellow lights are lit and after several hours the is no charge in the battery. What could the problem be?
Clarification Request
Posted by Loringh on Nov 14, 2008
Michael, How old is the drill? the battery? Did this not change just happen or have you noticed a gradual shorter life on each charge. If you know someone with a volt meter you can check the charger output. Just plug the charger in and measure the volts on the terminals of the charger. It should measure at least 18 volts DC.
Loringh
Same Problem
Dec 07, 2008
-   I also have a ryobi lithium battery/charger.When I put the battery on the charger it blinks red for testing.It does this for hours before it takes a charge.What should I do ?
-   Guest
Best Solution
posted on Dec 04, 2008
Very Helpful)
danny_murray
Rank: Guru
Rating: 86%, 32 votes
Does this happen to both batteries or just one if it is both then i would suspect the charger is bad and not the battery
Comments:
Dec 04, 2008
- Does this happen to both batteries or just one if it is both then i would suspect the charger is bad and not the battery
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Drills / Drivers
Questions and Unsolved Problems for Drills / Drivers
Answer
what is the best impact driver
Answer
I have a walter drywall screw gun model 6343. the bit holder releases the bit and it is very... (More)
Answer
lost power pack for recharging wagner 16.8v classic pro
Answer
Why is the red light always flashing, even without a battery in the charger?
Answer
I don't have the instruction booklet for the 'Work Export' drill model EYO73174 (HL-DT300). Can you... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Drills / Drivers:
Top Drills / Driver Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Drills / Driver Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
