Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Severe convergence/pincushion problem on green
My wife woke me up this morning to tell me that while they were watching TV, the color alignment screwed up. I went down to find that the green gun image is warped severely, but mostly on the bottom half of the screen. The top right corner is distorted, the center is pretty well lined up, but on the bottom, the bottom of the green image is warped up around 6 inches, in a curve centered just to the left of center. Since the normal convergence adjustments only apply to the red and blue (you're supposed to align them on green), there's nothing you can do. This happens for all inputs on all video modes, so it isn't likely to just be a settings loss. I can get to the service menu, but I'm supposing this is a hardware problem and there is no use trying to tweak it back into alignment. I know which end of a soldering iron to use, but due to time, it is unlikely that I will attempt the fix myself. Assuming it is the convergence chip set (and does this seem like the case?) how much should a repair shop charge to fix this? If this price is too high, I'll likely buy a new TV. If I do that, then I would likely want to try to fix this one (either as a backup or to sell). Any idea or suggestions?
  • Christopher Palmer Dec 03, 2006
    Actually, I found the answers myself and fixed it. You can read all about it here:
    http://cmpalmer.blogspot.com/2006/11/fix...
  • diddly4 Sep 21, 2008
    The color blue has shifted to the left a few inches uniformally across the screen. I tried adjusting the convergance but it doesn't help. I am assuming I need to replace a part, what part and how difficult is it to do?
I had the same issue, except the blue gun went nuts. i replaced the two convergence amp chips (20 bux, shipped) and its back to perfect!
Posted on Jul 15, 2008
  • 65 Answers
Projo tvs dont have pincushion problems this product needs a couple of resistors and two stk packs depending on who you go to 300-400
Posted on Dec 09, 2006
I turned My tv on and the top of the screen has red, green, and blue swirl lines, and the rest of it looks like watching a 3D movie without glasses, and the picture looks as if you took out the screen and...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or pictures look like 3D?Yes,than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
Aug 11, 2011 | RCA D52W19 52" Rear Projection Television
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
How do you make a pincushion adjustment. Picture is OK in center but out of focus as it spreads out in all direction with a bow shape at bottom. All colors appear to be present. Can you help?
This is not adjustable,have dead parts.The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment anywhere in the pictures,have colors pictures shadows or 3D pictures look alike?The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts,must replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 23, 2010 | Hitachi 53UWX10B 53" Rear Projection...
The green projection tube is mis aligned. it was
maybe convergence problem. Contact tech support with this #4 display
Jun 03, 2010 | Hitachi 57SWX20B 57" Rear Projection...
Occasionally the picture snaps into what looks like a pincushion.
it is infact pincushioning.. these tv's have a maze of boards.. try to contact manufactuer about pincushion pcb also try to auto converge colours if you can.
Dec 14, 2009 | Mitsubishi WS-55807 TV
Hitachi 50gx30B Pincushion problem
Please let me know in which direction the picture is distorted. Does it bow in from the top and bottom or left and right?
Thanks,
Dan
Mar 06, 2009 | Hitachi 50GX30B 50". Rear Projection...
Mitsubishi vs 5071
Usually this problem is caused by bad convergence ic's. These hold the three colors in alignment. They are better to be replaced as a set of two or three chips and must be soldered/desoldered into the circuit board. Most shops charge 200.00-375.00 to do this repair. I hope this helps. Most bow problems are from convergence or pincushion circuits.
May 21, 2008 | Televison & Video
PHILLIPS BIG SCREEN TV IS BUTTERFLIED
Are the colors out of alignment and unable to converge back? If so its the convergence ICs need replacing. If the convergence isnt out of alignment you have whats called a pincushion problem. If you would like a link to where you can obtain the service manual for this model let me know.
Mar 17, 2008 | Televison & Video
Pincushion Picture on a big TV screen!!!
The set has 3 IC's(one for each color)strictly dedicated for the aligment of each color,if one them does not align is because is going bad or is already bad becuase picture can not be adjusted,the IC's can be identify because they are mounted on a heat sink and have the markings STK--- ---,they are all the same and need to be replaced with an exact replacement.If you are familiar with tv service you can replace them,sometimes the new ones need to be aligned from the service menu,you will need the service manual,soldering and unsoldering will be involved,If you are not too familiar be safe and seek the assistance of a servicer.
Nov 03, 2006 | Sony KP-46WT500 46" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
320 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
