Question about E-Machines eView 17f3 17" Flat CRT Monitor
Display the contrast setting automatically comes on screen and increases it up to max. and some times fade away automatically. when it appear it does not remove by exit button also no any menu button work.
    Brigadier General:
  • 6,966 Answers
Hi again,
It would seem that you posted your problem several times. As stated in my proposed solution in your other postings:
Unfortunately, an HCL HCM782M monitor is an unknown model. However, on similar instances and occurrence of this problem, it would seem that the controls are damp. Specifically, it would be the internal contacts of the buttons. Pls check if you can dis-assemble, remove the board/control/buttons and perform cleaning. Pls pay particular attention to the rubber pads or the small buttons themselves. if I may ask, any recent continuous rain? If yes, this may have contributed or caused your problem.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 16, 2008
Screen starts fade away
You can try to increase the contrast of the display.
Press Menu.
Press F:System
Press F1:Contrast.
Use the right arrow to increase contrast. If there is no change, the calculator may be damaged. But do a calculator reset just in case
Mar 24, 2014 | Casio FX-9860GII SD Power Graphic...
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
My tv is about 2 years old. It just started burning old images into the screen and they slowly fade away but its very annoying.
Removing burn-in takes time. The best practice is to avoid creating the images.
Whatever the image is coming from has been left on screen for an extended period of time. The TV should be turned off or the source turned off when not watching.
You may find some relief by lowering your contrast (which I am suspecting is still at or near 100% as they come from the store). Bring contrast down to, say 60. Use brightness or backlight to brighten the screen if you think it is too dark with the contrast lowered. (Best picture quality is near 50, the center of the scale.)
Jun 13, 2010 | Televison & Video
Low screen display contrast
Adjust the display contrast by pressing and releasing the 2ND key, then pressing and holding the Up key to increase the contrast or the Down key to decrease the contrast.
May 29, 2009 | Texas Instruments Office Equipment &...
My dell latitude D830 display colors have faded.An
I would check your graphics card control panel. You may have (or someone else) set the contrast or some other setting to low or high. If you are using nvidia you can run the optimization wizard.
Mar 12, 2009 | Dell Latitude D830 Notebook
Adjust screen Contrast
<Fn> +
Contrast up Increases the screen Contrast
<Fn> +
Contrast
down
Decreases the screen Contrast.
This will help you achieve this adjustment.
Feb 23, 2009 | Acer Aspire 3000 Notebook
Brightness display comes on by itself and won't turn off
1. Adjust the LOT screen preset.
2. Trace the G1 path , LOT to neck board. Sum times diode are capacitor problem.
3. LOT sarounds one 10Mf / 450 V capacitor bad
Oct 14, 2008 | HP mx705 17" CRT Monitor
Ti84 plus, screen problem
  1. Press and release the gold [2nd] button. Verify that the blinking up arrow appears in the display.
  2. Press and hold the blue up or down arrow key to increase or decrease contrast, until the display is to your liking. Be alert: the display will change quickly.
The calculator will remember your contrast setting; you don’t have to adjust it every time you turn the calculator on.
Mar 10, 2008 | Texas Instruments TI-84 Plus Calculator
E-Machines eView 17f3 17" Flat CRT Monitor Logo
198 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
