Problem for Proscan PS27500 27" TV
TV won't turn on
My TV won't power on either with the remote or with the manual power on. I hear a clicking noise and it appears that the TV is turning on and off. After several times it stops. Never actually see a picture.
Comments:
Dec 06, 2006
- I took it to a technician and he said the set has a bad transformer (high voltage) and that it would cost $200 to replace/repair. It's not worth it at that price. Any cheaper alternatives? It's a shame. I've had the TV a few years but haven't used it that much as it's in our basement. I'm contemplating reaching out to the manufacturer to complain.
Same Problem
Feb 27, 2009
-   I have the same problem with my 42" Samsung, it takes 10 minutes to turn on. It makes a clicking noise and then a red light flashes 4 times, and it turns off without turning on, 1/99 times it actually turns on. Problem just started recently
-   Guest Feb 23, 2009
-   I have the same problem with my 20" inch tv. I have no idea what happened or if it's even the same problem; today I accidentally sat on the SATELLITE remote, and then the tv (which cannot be controlled itself with the satellite remote. Only the satellite box on TOP of it would ever be affected by me sitting on the satellite remote, and yet the satellite box still works fine) the television turned OFF! We have tried EVERYTHING to fix this, especially since it doesn't make sense that the tv turned off immediately when i sat on the Bell ExpressVu remote! My TV is a Toshiba, and we've had it for a couple of years, but I don't understand this! It's really upsetting me, actually!
And again, when i go to manually turn the TV on, it makes a clicking sound as if it were turning off and on, and yet nothing is showing up on the TV. Not even a flash or a light, just the clicking noise. And so far, it hasn't gone away like some of your other TVs have. What's up with that?!?! Can anyone help please?! -
funkydoodle Feb 15, 2009
-   i have same problem-
s0teh Feb 03, 2009
-   My Supra TV won't turn on at all. I had it imported to England from Dubai. It worked fine for 2 weeks. Then I went to turn it on to connect the VBox (cable) and it will not turn on. I turned it 90 degrees when I moved it from one side to get a look at the back to draw a diagram to get the correct cable cord, but didn't do anything else. What happened? It's a 26 inch LCD Flat-Screen. Very nice piece so I don't want to/cant afford to buy another. Pls advise. -
laurallday Dec 23, 2008
-   I have the same problems to with my sharp tv.
-   Guest
Best Solution
posted on Feb 19, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Rix20601-
how hard is it to repair the high voltage board? i'm hoping to locate a fuse somewhere, but i fear those days are long gone.
Solution #2
posted on Aug 08, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
my tv won't turn on either.
Solution #3
posted on Feb 15, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My TV won't power on either with the remote or with the manual power on. I hear a clicking noise and it appears that the TV is turning on and off. i bought this t.v sharp 29" model 29l-fg1sf from dubai, u.a.e, using it in india from 12th feb 2007 today is its 4th morning since the time i started using it...it is showing the same symptoms what you allhave mentioned above...i don`t know what to do??? can any technician help me...
Solution #4
posted on Jan 03, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Guess what, my samsung slimfit tv wont turn on too, press the button and theres a slight clicking noise, just doesn't come on
Sounds to me like there could be a fault with all the tv's they made, but i have rang comet where i bought it from and as expected as it has ran out of standard 1 yr guarantee, they wont do anything unless i pay £150 for engineer to come out!
Solution #5
posted on Nov 22, 2006
Rank: Apprentice
Rating: 91%, 12 votes
Was this helpful?7 people thought this was helpful
Solution #6
posted on Jul 27, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
hi i have just got a 37" lccd and i wont turn on for s*#t it id digihome dose any 1 nw ho to fix this
plz
Solution #7
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have the same issue with my emerson model 2704. While inspecting the circuit board i noted that the HV transformer was set incorrectly at the factory cracking the circuit board. A fix was applied using solder to close the broken ciruit and it had fell off. I resoldered the circuit and it works fine now.
Solution #8
posted on Mar 10, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hello everyone!!
I've had thesame problem with my Sumsung TV set I've contacted the technician hes said that it'll cost me about $200 to get my tv back alive!!!! So I've decided to check it myself and see what's up it was the fuse I've replaced it with a new one bing my tv is working like brand new it costed me $3.14 wow try it you'll see :) good luck!
Joseph.M.
Solution #9
posted on Dec 01, 2006
Rank: Apprentice
Rating: 86%, 3 votes
Unfortunately, this is not a solution. I bought the same set in Jan. of 04 and I have the same symptom that first occured on 11/18
in the morning. After numerous attemps to power on the set, it statrted working again. It worked for about a week with no other issues, until 11/24 when it started doing the same thing again. I unplugged set from the wall for 5 days, tried again and it worked fine for two hours. Then the screen went blank, audio OK. Turned set off and it hasn't worked since. :>( Is the set going to turn into a money sucking peice of electronics? I'd be interested to hear from mpbbuzz if he was able to get the set repaired.
Was this helpful?1 person thought this was helpful
Solution #10
posted on Jul 15, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have had several TVs of various makes and models whose fault is that they try to turn on but can't.
I still have one in my closet from years ago! Now, my little GE portable has crapped out, too! We are not amused!
In my opinion, it is a fault that is purposely designed into the TVs by the manufacturers!
They know that the cost of repair is too prohibitive and most people will just junk their old TV for a new one.
I think it is dispicable! But, that's our consumer society for you.
Solution #11
posted on Feb 16, 2007
Rank: Apprentice
Rating: 85%, 4 votes
well i got the same prob but by looking closly at the fuse u see a be be looking wire on each end connecting a thiner wire im gonna try a bugger fuse low amperage aka "thin fuse wire" could be the prob hey its worth a try
Solution #12
posted on Feb 23, 2007
Rank: Wiz
Rating: 83%, 57 votes
first thing to do is to test the flyback testing flyback has a service charge (P50) and if the flyback is o.k the problem of your unit is in the Horizontal output. i suggest to change it. a leaky H.transistor is a part which is located HV section wich let the unit turning on.
Was this helpful?2 people thought this was helpful
Solution #13
posted on Dec 04, 2006
Rank: Apprentice
Rating: 75%, 5 votes
this is the same problem i'm having so this is obviously not a solution but i didn't know how to ask what it would actually mean to get this high voltage section fixed and how much does something like that cost. is it possible to just buy parts and use common sense to fix or do u really have to take it into a shop... thanks
Was this helpful?3 people thought this was helpful
Solution #14
Rank: Apprentice
Rating: 74%, 4 votes
You weren't listening to his question. He already was told by a technition that the set had a problem with the transformer. You simply reiterated what he already had been told. His question was whether anyone KNEW OF A CHEAPER ALTERNATIVE solurtion.
By the way my Tv has just begun having the same problem,. It must be a common fault. Typical Sony!!!
Solution #15
posted on Jun 27, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
**** my balls
Solution #16
posted on Dec 06, 2006
Rank: Apprentice
Rating: 40%, 1 votes
"An idea from the origin of the problem"
I have the same problem on a 25 inches T.V. What I remember before the problem began is that T.V. had a problem with the Sleep function, the problem was that once you had activated the sleep button, it was not possible to cancel the function until next time the T.V. was turned off and on again, but never with the ciclic function Sleep that normally gives you determinated options until it gets cancelated.
With te time it got worst because if the button Sleep was pressed the function only was presenting the Red label that means that you only have a minute before i tuns off.
My supposition is that the function sleep is having an effect of turning off the T.V. as soon as you tun it on.
Now I am trying to contact a technician to fix the problem I hope he can cancel the Sleep function and fix it.
I hope it helps.
Solution #17
posted on Mar 23, 2009
Rank: Apprentice
Rating: 100%, 1 votes
Capacitors in the power supply can cause this fault if you can replace them it may cure the problem. I had the same problem and changed it myself and i have never done this sort of thing before. The Capacitor cost only £2.10 in total and guess what? my TV's working!!!!!!!!
Solution #18
posted on May 21, 2008
Rank: Apprentice
Rating: 100%, 2 votes
The noise is probably the power supply in hicup mode or safety mode, that's what happens when a fault develops in the set which loads the power supply down. All you have to do is get a multi meter and go round measuring things like Resistance to earth from collector of line out transistor this should be at least 10kohm , then measure the various diodes that can be found in the power supply... hope this helps.
Solution #19
posted on Feb 07, 2009
Rank: Apprentice
Rating: 97%, 9 votes
Open it up and look at the capaciters near where the power plug attaches to the circuit board. If any of them have a bulgeing or pushed out top it needs to be replaced. get the numbers off the side and get new ones from radio shack, just a buck or two a piece. You'll need to solder to do this.
Was this helpful?8 people thought this was helpful
Solution #20
posted on Aug 02, 2009
Rank: Apprentice
Rating: 80%, 5 votes
all you need to do is buy a brand new tv and trade the parts then bring the tv back the next day and say my brothers friend is giving me a tv so you want to bring it back it worked for me ok so it should for you ok you get your money back and a good tv!!
Solution #21
posted on Dec 16, 2008
Rank: Apprentice
Rating: 75%, 1 votes
how to change high power transformer
Solution #22
posted on Nov 09, 2009
Rank: Apprentice
Rating: 0%, 0 votes
I have same problem with a samsung. it just shut off and now it will not turn back on. You hear a clicking noise and a red power button flash three times and the screen kinda flickers like it is trying to turn on, but never actually does.1 year and two months just over the warnty.
Solution #23
posted on Sep 05, 2009
Rank: Apprentice
Rating: 0%, 0 votes
take of the front speaker cover then shake it a little bit to make sure theres not a short then try.
Solution #24
posted on Jul 30, 2009
Rank: Apprentice
You guys are lucky, I've had mine for 6 months. We shut it off last night, and that was that. Won't come back on!
Solution #25
posted on Aug 09, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem but with a Toshiba. For a while i had this problem every morning but if i unplugged it and left it alone for a few hours came back and plugged it back in it would work fine until tomorrow, but today thats not even working. any help would be very much appreciated.
Solution #26
posted on Mar 04, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
rix20601,
Thanks for the soulution. I bought the same TV and it has the same exact problem as this. my kid turned it on and off until it wouldn't turn on anymore. I thought the front panel block was enabled but apparently it wasn't. Anyway, your suggestion only helps confirm what a few people I've talked to havve said. Thanks again -Mike
Solution #27
Rank: Apprentice
Rating: 0%, 0 votes
After about two years of continual stable use, I too developed the same problem. It occured after a lack of use for months, damp/dusty environment = clicking sound when trying to turn on tv. Repeated attempts to turn it on would eventually work. Fortunately in my case it developed over time and just got worse after each extended lack of use, until eventually it wouldn't turn on ever, it would only click. Using your information, I removed it from the damp environment, opened the back and used compresed air to clean the inside components. Initially no change in status. Repeated attempts to turn it on, however, did produce results. It is now day two and the problem is still there, although it is getting better. The longer it is on and more it is used the more stable it is becoming. I currently believe that one of the components collects moisture and the heat of use/attempted use, dries the area of the short. However, I also believe that the component retains more moisture than just in that area and that it is improving with more use due to a cumulative drying process.
Solution #28
posted on Mar 02, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
It Would be cheaper if you order the Flyback transformer youself and replace it yourself cost would be 60bucks
Solution #29
posted on Mar 01, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same issue with mine. It was the transistor, resistor and a cap located where the A/C input is on the board. The "power on" circuit I guess. Cost was about $110
Solution #30
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem with my TV. It's like it'll turn on but then it shuts off right away and I never see the picture. Sometimes if I manually press the power button over and over (I mean OVER and OVER) it'll turn on but the past couple days that hasn't worked. I think it's time to throw it out (I've had mine for quite a few years and it's more trouble than it's worth for a 13 inch TV).
Popular Solutions for Proscan PS27500 27" TV
Questions and Unsolved Problems for Proscan PS27500 27" TV
Do you recommend Proscan PS27500 27" TV?
when i click in put on my tv, it won't go into in put
my philips magnavox 32inch flatscreen wont turn on!
I have a 32" inch tv that is less than a year old. The sound will come on, but not the picture....
(More)
I have a 32" inch tv that is less than a year old. The sound will come on, but not the picture. What can I do?
My television is a 42" Emerson. I went this morning to turn it on to watch the news &...
(More)
My television is a 42" Emerson. I went this morning to turn it on to watch the news & it turned on for about 4 seconds then turned off. H ow do i fix it?
kishu lcd151 cannot get bbc2 no bbc2 in auto memory
10 Other Users Have The Same Problem - Continued
Comment by Daaling, posted on Dec 01, 2008
Our Samsung 40-inch flatscreen HDTV, our one indulgence for entertainment purposes, has just gone loopy in the same manner y'all describe--Clicking like it's coming on, but just blinks the indicator light at us and nothing, then turns itself off. We opened it up last night to check for dustiness, but nothing. We're not sure what to do now and are very disappointed--we saved up to buy this thing one year ago this week.
My fiance is very handy with computers so we're hoping there's a fix we can try at home but not really sure where to begin assessing what we need.
Comment by Guest, posted on Nov 09, 2008
why wont it tern on
Comment by Guest, posted on Oct 05, 2008
my tv wont turn on its a piece of **** so help me you fool!!!
Comment by GillesM, posted on Apr 21, 2008
HI,
I have the same problem with my Proscan PS36800HR and my repairman tells me he cannot get parts from RCA. What can we do?
Thanks,
Gilles.
Comment by faithandhope, posted on Mar 31, 2008
I have a Sony Wega 24" tv....5 years old...excellent reception and picture..all of a sudden it won't turn on...red light blinks for awhile and then a click is heard and it apparently is turning itself off. I have been advised to dump it.....costs over $200 fix. "Starter box" or something like that shot. I cannot believe a set of that integrity would last only 5 years. Looking for an answer.
