Question about Brother Office Equipment & Supplies
Brother faxes 8360P and 8000P - how do I progamme the machine to dial a 9 before each number please ? as my machines are connected to extensions on the PABX. Thanks
  • toptenor Nov 24, 2008
    Thank - I knew that - but was trying to get it to work automatically - thanks anyway,
    Scholar:
  • 78 Answers
As I'm aware you can not program a number before every number you use. However you can progam the one touch or speed dials you can enter the 9 before the numbers. On some systems thay may need 9 then a pause then the number.
Posted on Nov 22, 2008
I need driver for win7 for my brother fax 8360p
not avable from brothers as yet. keep checking windows web site for drivers.
Aug 10, 2010 | Brother FAX-8360P Plain Paper Laser
I received a brother 8360p from our other office but when i plug in the power cord to the outlet it does not turn on. I do not see an actual on/off switch either. Am i missing a step?
They don't have an on / off switch. Many fax machines don't.
Simply unplugging and re-powering up a machine will cause the power supply to fail. Not unheard of.
Nov 03, 2009 | Brother FAX-8360P Plain Paper Laser
Our fax machine is out of toner in the office and
ask if your telephone company has autoforward features on your phone line, you can auto forward all incoming calls to another fax number. you can ask your telco for the codes to activate auto-call-forwarding.
I have a brother 8360p. How do I reset the drum count
on most brother machines you just open the door and hit the clear key. It will ask if it is a new drum, select yes and bam!
Oct 14, 2009 | Brother FAX-8360P Plain Paper Laser
I have a panasonic hybrid phone system and would like to connect a fax machine, when I connect the fax to the jack, I dont get a dialtone but it goes to the intecom line. The same happens if I connect a...
Hello, you can solve this one of two ways. Try pushing a 9 when you get intercom line, you should get an outside line. So when you want to send a fax, just remember to push a 9, get outside dial tone then dial your number. Or, the second option would be to program that extension jack to auto select a line when going off hook. That will take a manual and some additional guidance. Okay, so thats for making outgoing calls. When it comes to incoming calls, you need to find out what extension the fax is connected to. You can do this by dialing another extension that has a display from the fax machine and see what intercom number comes up on the phones display. So once you know the extension number you can do one of two things. You can leave the fax off since it will most likely ring when any call comes in your office, and only turn it on when receiving a fax. When you answer the fax call on one of your other phones, and hear the beep beep beep, merely push transfer and dial the fax machines extension. That will transfer the incoming fax call to that extension and the fax machine provided you have it turned on. The other option is to break out the system manual(not user guide), and program the fax machines extension to only ring on the line you want it to, say your last line and leave the fax machine on and give out that specific number for faxes. But you do run the risk of your call traffic being heavy, incoming calls rolling over to that line or someone calling that number directly and getting the fax. I think I covered everything I can with the limited information on your application, so I hope that solved your problem.
Sep 17, 2009 | Panasonic Advanced Hybrid w/Back-Lit LCD...
Brother FAX 8360P comm.error
It could be line noise on the phone.., which allows phones to work ok, but causes problems with faxes. See this document from the brother website concerning comm.error:
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000100/000067/faq000167_000.html?reg=us&c=ca&lang=en&prod=fax2800_us&Cat=11
Would recommend having the phone company run a line check to make sure the phone line is clean of interference !
Jan 21, 2009 | Brother FAX-8360P Plain Paper Laser
Clearing memory Brother 8360p
Press quickly......MENU 2864 then press 91
Oct 16, 2008 | Brother FAX-8360P Plain Paper Laser
My Brother Fax 8360P LCD says "Printing On Line" when I start it up and the message won't go away. I can send a fax but it takes at least 15 minutes for the fax to be received at the other end.
It sounds like you have logic board problems. Take the main board out of the machine remove all power sources, batteries, etc. let the board sit 24 hrs. install board into machine. If machine works, it's fixed. If not replace main board.
Jun 18, 2008 | Brother Office Equipment & Supplies
Brother fax machine 8360p
It seems that someone has sent a large fax that has filled the memory. What they may have done is accidentally programmed one of the buttons to send to #342. This is easily done, if those keys are pressed and then an empty program button is pressed right after. You will have to remove the program from the que 1st of all, then remove the program from the button.
Jun 09, 2008 | Brother Office Equipment & Supplies
Can I divert to another number?
To diver the number itself is a function of the phone company itself via an optional service called "call forwarding". Cost is only a few dollars a month, depending on your provider. Alternatly, you can use a function called "fax forwarding". In this mode, your fax machine will accept the incoming fax into memory and then dial the predefined number of the fax machine on which you wish to receive it on. Look in your manual for "fax forwarding". If you do not have your manual you can download it from: http://www.brother-usa.com/Manuals/Default.aspx Let me know if this solves the problem or you need additional assistance Ed
May 31, 2007 | Brother FAX-8360P Plain Paper Laser
78 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
