Question about Whirlpool Refrigerators
Interior of door vandalized with cigarette burn inside top shelf
Is there any way to repair burn inside top tray of inside refrigerator door.
  • 833 Answers
There are plastic patch kits available at automotive supply stores.  Perhaps they could help.
Posted on Nov 14, 2008
I have water standing on top shelf of refrigerator and it looks like condensation refreezing on the top of freezer.
Door not closing well, the heat come inside the freezer and
make condensation, check the door rubber gasket is not damage to verify door close well.
Feb 09, 2017 | Refrigerators
For right hand side door plastic egg holder clear plastic on "top shelf"
What's the problem with the egg holder? Please be specific.
In any case, to replace interior of a refrigerator is not easy. Must find proper parts, disassemble and reassemble door. Some time ago I had problems with plastic parts of the door and the repairman I called simply could not do the job because parts were not available
http://www.repairclinic.com/Shop-For-Parts/a4b2/Frigidaire-Refrigerator-Parts
Refrigerator Parts and Accessories Frigidaire
Refrigerator Egg Tray eBay
Aug 31, 2015 | Refrigerators
GE side by side refrigerator main light bulb stays on even when door is shut firmly.
There is a switch just inside the door in most on the roof of the fridge, make sure it is not damaged.
Jul 02, 2017 | Refrigerators
Vegetable crispers and deli tray freeze food.
This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try: If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf. If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper.
Feb 15, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
Inside top of the refrigerator, top panel would freeze and then thaw out,dripping water on the shelfs and down into the vegtables trays
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 09, 2011 | Whirlpool Refrigerators
Extreme rise in refrigerator temperature
You probably have a bad light switch or the door may be sagging. interior lights are definetly staying on with door closed.
Feb 16, 2010 | Refrigerators
Water inside refrigerator
Even though it doesn't seem like it's coming from your freezer, morre than likely that's where it's coming from. At the back of the fridge there will be a drip tray that actually catches the water from the thawing freeze. One way to avoid access water is to simply turn down your freezer and fridge. Usually if they are number 0-10, both frigde and freezer should be set on the 5 level.
Aug 31, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
105 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
