Question about Canon MP610 Photo All-In-One Printer
Ink not dry and significant smudging
Been using mp610 for 4 months no problems. now ink does not dry on photos. have changed cartridges and run some maintenance functions (not print head deep cleaning) but still same problem
when i run the head alignment functions the colours all print out correctly.using genuine paper and cartridges.
should i run the deep cleaning function or could there be some other explanation
  • jon_delaland Nov 17, 2008
    The ink still does not dry even after several hours. I have run the cleaning and deep cleaning applications and still does not fix the problem. I have noticed that there is ink smeared on the outside of the print head
    Scholar:
  • 181 Answers
There r various modes in the printer in which u have to print .and that u have to select.as you said it is printing properly on ordinary paper.the printer is perfect.the photo paper have less soaking power that ordinary paper.as the photo paper can consume ink but not so quickly as ordinary paper.
u just change that printmode and then check out how it prints.
for example the modes r ----------best mode printing.
better mode printing.
fine mode printing
normal mode printing.
draft mode printing
economy mode printing.
now i f u print in best mode it will consume lots of ink but will take lots of time to print.
if u select normal mode it will consume less ink and print quickly.
u can change the settings in printer properties.
thanks
Posted on Nov 14, 2008
Element that dries the ink on photos isn't working after replacing ink cartridges.
heating element in a photosmart printer?
have you made sure you're printing to the right sort of paper in the printer settings. it's obviously dispensing too much ink for the paper you're using.
Mar 15, 2015 | HP Hewlett Packard - Photosmart 7520...
I'm trying to print wedding invitations on my Canon MP460. I'm using a cardstock thickness of paper and have set the ink levels for "Other Photo Paper" on my Mac. The paper has been going through...
Sounds like the ink isn't having time to dry and is rubbing along paper.
Paper may be too thick. If it prints OK on normal paper (test first) but not on thick card, then it doesn't support thick paper settings.
Jan 31, 2011 | Canon PIXMA MP460 All-In-One InkJet...
My printer would not print because the cayan color was low. Once I replace printer ink the printer will only print every other line with smudges in between. What is the likely problem and fixes?
dried or leaky ink near cartridges. Be careful how you clean them. Use mfg recommended directions to avoid static (etc) problems during cleaning.
Oct 28, 2010 | Epson Stylus CX9400 Photo Printer
I have black smudges on my printouts. I using
This may be the cartridge itself, take the black ink cartridge out and check the head on it (the part that points in to the printer, usually down) and see if it is dirty or has ink smudges on it.
Mar 12, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
Canon i9900 black ink smudging
ok, What cartridges are you using, Are the Canon cartridges?
What paper are you using, is it Canon paper?
If you are to both of these it could be wise ordering a printhead, but this is mostly caused in the uk by None Canon Paper.
Please let me know what you are using?
Sep 24, 2008 | Canon i9900 InkJet Photo Printer
Hi I have just inserted a new HP ink cartridge 94 into my HP PSC 2350, as the ink was running low. I was printing photos, which keept printing with a red line throughout the picture. After inserting the...
Try opening the printer properties and cleaning the print heads (should probably be done each time a cartridge is changed), it uses some ink up but should clean the build up from running the previous cartridge dry and hopefully solve your printing problem.
Good luck.
Mar 29, 2008 | Computers & Internet
The print heads are clogged with dry ink.
Yup, thats the problem....
To keep them clean you need to almost use the printer weekly....or at least once per month min....
Try running the head cleaning utility....
You can run it as long as you have ink in your cartridges, maybe 5 times in a row....Wait about 10 minutes and try again....
With luck it will unclog itself....
Note: Your cartridge can also dry out (Yes the liquid evaporates), and leaves the pigment in the cartridge, which can further clog your machine....
As a last resort there are a few vendors on the internet where you can purchase head cleaning solution for epson cartridges....
Note; This problem is more common with printers that use pigment based ink as it tends to settle in the cartridge. Dye based ink has a shorter "Brilliance lifespan" but tends not to clog...
Feb 09, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Lexmark Z517 wont print black ink
I have a z600 that i use. If not used for about a month the ink does clog the print nozzles and eventually ink cartridge does dry out. To avoid this even if i dont have to print anything I run a diagnostics test that prints out a nozzle aligment test every two weeks.The great thing about this is that it uses very little ink.You can find this test in your software that was provided by Lexmark. This will keep your nozzles cleaned and you will notice this helps extend the life of your cartridge.
Sep 21, 2007 | Lexmark Inkjet Z517 Photo Printer
"Banding" on Prints
Do a thorough manual cleaning of printerheads (where the cartridges sit). Many printers are notorious for clogged nozzles and the ink dries on he prinheads until it becomes a bandind issue or ladders appear, smudges too. Use a proper cleaning solution and cotton buds, until most colour is gone off cotton buds. Reinsert cartridges and try again.
Aug 25, 2007 | Canon i9900 InkJet Photo Printer
Canon MP610 Photo All-In-One Printer Logo
189 people viewed this question
old marine
old marine
