Apple iMac G5 Desktop Logo
Posted on Nov 14, 2008
UNABLE TO OPEN ANY PAGE
I HAVE 3 COMPUTERS AT HOME. ONE OF THEM IS WIRELESS, THE OTHER TWO ARE NOT. OCCASIONALLY, MY WIRELESS HAS NO CONNECTION AND I CAN'T OPEN ANY PAGE. HIS HAPPENS WHILE THE SIGNAL FROM THE ROUTER IS VERY STRONG AND IT ALWAYS IS.
I CAN ALWAYS CONNECT TO THE INTERNET IF I USE MY OTHER TWO DESKTOPS, WHICH ARE CONNECTED (ETHERNET) TO THE ROUTER.
THIS PROBLEM WITH THE WIRELESS ALWAYS FIXES ITSELF, HOWEVER, IT IS VERY FRUSTRATING.
I USE AN AT&T 2WIRE ROUTER AND I HAVE A MAC COMPUTER.
ANY SUGGESTIONS?
THANKS.
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Nov 19, 2008
Anonymous
Contributor
Level 1:
Answers
20
Questions
0
Helped
19453
Points
34
Is it actively connected when this happens? You said the wireless signal is strong so i guess it is. In your airport menu, there is an option for "interference robustness" that may fix the problem.
Anonymous
Level 1:
  • Contributor 55 Answers
  • Posted on Nov 14, 2008
Anonymous
Contributor
Level 1:
Answers
55
Questions
0
Helped
32096
Points
80
You may want to check the wireless security settings ie. (WEP / WPA /WPA2...etc) on the router, certain settings don't always work well with the macintosh, try changing them and that should help your problem.
The internet said that they can not bring up your web page.
Internet Explore Cannot Display the Webpage
As you browse the Web with Internet Explorer, you may occasionally encounter an error message about the browser being unable to display the requested Web page.
If your browser is unable to display a page, the issue lies somewhere along the path from your computer to the remote website. In some cases, you can resolve the issue by troubleshooting your computer or Internet connection. Internet Connection Issue
If Internet Explorer is unable to display any pages at all, see if you are able to browse the Web on another computer.
If none of the computers in your home can browse, the problem is related to your Internet connection.
In some cases, you can resolve an Internet connection issue by unplugging the power connections for your broadband modem and router temporarily.
If you are still unable to browse, contact your Internet service provider for further assistance.
Malicious Software
If you are unable to browse the Web on your computer but can browse on other computers, the computer itself has an issue. In some cases, this can mean that your computer is infected with malicious software.
Download an anti-virus program on another computer and run it on the affected computer to troubleshoot the issue.
User Error If you receive an error in Internet Explorer when you attempt to browse to a single website, but other websites work, check to make sure that you are entering the address of the website correctly.
By default, Internet Explorer searches the Web for a close result if the address you entered is not associated with an actual website. If you have disabled this feature and enter a website address incorrectly, Internet Explorer displays an error message.
Remote Website Issue
If you are unable to browse to a single website and are certain that you have entered the website address correctly, it is likely that the website itself has a problem.
You can wait and attempt to view the website again later, or search for the website on Google or another search engine and click the "Cached" link to view a recent cached copy of the website.
http://help.expedient.com/browsers/
http://windows.microsoft.com/en-US/Windows7/Tips-for-solving-problems-with-Internet-Explorer
Conntection problems
1. physical connection
ISP modem to> router yellow port> router grey port to ur computer
2. modem light on the router should be solid and the internet light also.
3. if not u need to configure ur router
4. open the ie or firefox in ur computer which is hardwired to the router
5. type 192.168.2.1 i the address bar it will lead to belkin router page
6. if the modem light flashes on the router then in the belkin page on the left side click on the restore factory default
7. it will ask for the login password leave it blank click on submit
8. then click on the restore default
9. in the rite upper right corner it has to say connected
10. then disable the wifi protected setup by clicking on it on the left side
11. then u will be good to go with the wired and the wireless connection
1helpful
2answers
I am unable to set up my Linksys WRT150N router security. I am using a Mac Computer OS X v10.5.8. I can access the internet using the router but only through an unsecure connection. When I go to change the...
Is there any computer connected to the router ?
If not then you will need to connect the computer
to the router.
Do not change any wireless settings on the router
with the wireless computer.
you will need to connect the computer to the
router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the
router.
Now once you change the network anme and security
on the router, you will need to connect to the
wireless network on your wireless computers.
Click Here for step by step instructions
Unable to connect to Wireless Network Connection (DELL D600)
could you open the command prompt and type ipconfig and tell me what you get..
2answers
Cannot Communicate from Computer to Computer
A connection from USB adapter directly to USB adapter may or may not be possible. Borrow a wireless router from someone and use it to test supporting connections to your two computers. I think you will find this a much easier way to proceed. Routers can be had for $40 or less. Shop around.
Good Luck
Gus
Unable to open any page
I think it's better to have this case isolated, since it's happening regularly, I think. Does it say the computer got disconnected from the wireless or does is still have the right address after it stop going online via wireless?
Maybe there is an interference that is causing this issue.
No internet connection with laptop computers in home
Good day!
If your Desktop computer is hardwired to the router and your laptop computers can't connect wirelessly, it could be your wireless computers are not synchronized with your router by not having the same settings as the router.
You can use the desktop machine to access your router web interface (setup page) to check the wireless settings such as SSID (Network Name-> Name of your wireless signal shown on your laptop computers), channel and security (wether it is WEP or WPA encryption)
The channel and network name will be automatically detected by the wireless computers. If you have an encryption/security on the router, you need to type the password on the wireless computers for them to authenticate.
Try these and post back if there's any progress
Router disconnection
1. Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
2. You will get a login page. Leave the password blank. Click Submit .
3. On the left side of the page, click Channel and SSID below Wireless .
4. The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel like 11. Click Apply Changes .
5. Click Logout in the top right hand corner.
6.Then reconnect to your wireless network.
Remote pc cannot access wireless
You can do a reset on your router. All computers must be must be getting its connection from your router. Your wired computer must be getting an ip address from the router(example is 192.168.1.x). You can then access the router page using your browser by typing the default gateway(example 192.168.x.1). This will take you to the router configuration page. You can set up the wireless network and your wireless network can now support more than 2 wireless computers.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
