I have a Samsung TX-T3093WH slim fit TV. When I plug it in you can hear a clicking noise from the back of the set. No lights will come on and the TV will not turn on. It worked just fine for 14 months. Thoughts?
  • Travisnxn Nov 14, 2008
    Is there a manual that I can get that shows me where the fuse is and capacitors?
    Sergeant:
    Novelist:
  • 196 Answers
It could be something short on the main board and it needs to be checked.
Posted on Nov 14, 2008
  • 1 more comment
  • mmechanics Nov 14, 2008
    check out for blown fuse .this is mostly the culprit in this types of problems.
    if the fuse is ok.then check out the power wire of the tv if that wire is cut some where or burnt somewhere the tv does get the current from the wire and remains OFF.
    if the fuse ,the power wire is ok.as u said that u hear a click it is quite possible any of the capacitors or the ics are getting hot due to short circuit everytime u ON the tv and they r slightly bursting and that is not letting the tv to become ON.
    THE capacitors may be burned or bulged and can can be easily located on the main board.
    thanks.
Is there a replaceable power supply for a Samsung TX-T3093WH TV
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Replacing the power supply with any other board; will be somewhat difficult to this set. Repair it by replacing the damaged component/s.
May 10, 2014 | Samsung TX-T3093WH TV
VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Jul 26, 2008 | Samsung TX-T3093WH TV
I'V LOST THE REAL VALUES FOR DEFLECTION SETTING IN SERVICE MENU FOR MY SAMSUNG CS-32500HEXA.PLZ HELP
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the left top left corner of the display window. It will make search easy. Some times, the ads attached with each posts both at the right and bottom, might help you to find the availability of spare parts. There are more than 690 posts to different brand TVs now.
Sep 02, 2012 | Samsung TX-T3093WH TV
The color on my Samsung Slim Fit TV suddenly blipped to pink and blue. When I turn it off and back on, it comes on with a green line across the middle of the screen. What's up?
This line shows that there is failure of vertical output stage,may be due to high supply from internal power supply of TV set,check the voltage of the vertical output stage,and after rectification of supply problem replace vertical output IC to get this problem solved.
Feb 08, 2011 | Samsung SlimFit TX-T2782 HDTV
Samsung TX-R2765 not turning on.
I have the exact same problem!! Did you ever get a solution for your problem dkwb71?
Jul 18, 2010 | Samsung Televison & Video
Service menu help for Samsung TXT3093WH
Go to ur service menu.Picture go down to reset,changes all setting to factory setting.Will reset everythings.
Mar 28, 2010 | Samsung TX-T3093WH TV
It doesnt want to turn on i tried taking out the fuse and puting it back in it still doesnt wanna turn on
Power supply board is dead.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 08, 2010 | Samsung TX-T3093WH TV
My samsung slim fit tv has a horizontal line which
hum bar. possibly related to power supply filtering. sometimes reversing the power plug will help. check cable connections for tight fit.
Sep 20, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Zapping sound when turn on
Same buzzing sound here...help!!!!!!!!!!!!!!
Apr 06, 2008 | Samsung SlimFit TX-S3082WH 30" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
