Question about IBM ThinkPad T23 2647 Notebook
IBM T23 Thinkpad battery does not charge
I noticed you responded to a battery question on Fixya. I have an IBM T23 Thinkpad where my battery went down in power percentage when running on battery, but when I plugged it in to charge back up, the battery indicator goes to green (like the battery is charged up) but when I turn power on to check battery status, it never increases in any battery power percentage. I know the external charger itself is working because it supports running the machine just fine..... it is just the battery charging that just stopped functioning.... almost like there is a blown fuse going to the battery from the charger. You mentioned to change the bios battery in your response to another person's question. Do you feel this is the case here? If so, could you give a brief description as to why? Would the bios battery actually halt the main battery charging for some reason?
Thanks,
Norm
  • 5 more comments
  • Anonymous Nov 25, 2008
    I have the same problem. Can anyone help?
  • Norm Roller Nov 26, 2008
    Since 11/14, (when I wrote my original note on this), I have done more investigation and testing. So now, I can answer my own question here and maybe help some others with a similar problem.
    Battery
    To make sure that I had a known good battery, I ordered a new battery. I found that the system would not charge the new battery either. To verify the new battery was good, I even put the new battery into a friend's T23 and it charged up to 100% just fine there. I then put the new charged up battery in my T23 and it ran the system fine and discharged fine while running the system, but when I attempted to recharge this new battery in my system, it would not recharge. The ac adapter would just maintain the level it discharged to but would not recharge it. Just to verify that the battery recharged fine, I again put the new battery in my friend's T23 and it would recharge there back up to 100% just fine. End result of this testing is that I have a good battery that will not charge in my system.
    AC Adapter
    To verify that it was not the ac adapter, I put my new battery that was discharged down to around 80% into my T23, and plugged in my friend's charger, it did not do any charging. I also clicked on the battery % icon on the bottom task bar and brought up the Battery Information window. The battery information window showed a normal amount of battery discharge for both current and wattage when the ac adapter was not plugged in, but when the ac adapter was plugged in and it was put into the charging mode , there were no bars for current or wattage. The only thing that showed any reading was the voltage bar that was around 12v. To give it one more test, my friend also had a 2nd IBM portable ac/dc combo adapter. So tried that one too with the same results as above. So...... 2 known good ac adapters that charge batteries just fine in my friends Thinkpad does not charge a known good battery in my machine. End result of this testing is that the ac adapter is not the problem.
    Conclusion
    I have a problem with the charge/recharge circuits in my T23 Thinkpad. Unfortunately, I am told fixing this problem involves replacing the motherboard.
  • Anonymous Dec 02, 2008
    Same issue. Charge current zero, voltage indicates about 12.3V. Battery tests fine in different T23 and T22.
  • kelgone21 Dec 10, 2008
    same problem exactly
  • Anonymous Dec 14, 2008
    I have a very similar problem in Lenovo X60. Status shows as "Plugged in and Not Charging". Wondering if there's a fix somewhere.
  • Norm Roller Dec 18, 2008
    Thanks for your input, but I have resolved the situation as I described in my note above. It ended up being a bad motherboard where the recharge circuits were blown out. Thanks.
  • Anonymous Dec 18, 2008
    Hi
    I have an IBM t23 Thinkpad laptop, the battery was good ,But thebios battery was halt, so after each shut down,I have to readjust the system time, I replaces the bios battery with new one, but the result was the same, I leftthe laptop without operation or charging for 2 weeks, I surprised that the main battery life be very short(5min) after full charging,(100%charging),
    I dont know what is the problem< but i will try to revive the battery
    by cooling, and I will tell you the result,
    omed
    kerkuk
    Iraq
If you have some electronic skills and are not afraid to open up your laptop then I might have a solution for this. It could be a known problem in T23 where one component is loosen from the mainboard and in that case it can be fixed with a soldering iron. Other possible cause is blown fuses. But to confirm this you have to remove the keyboard and do the check.
Posted on Mar 11, 2009
    Sergeant:
  • 177 Answers
I think you have a battery problem and that is why it is not charging properly. Its need to be recllibrated. Try this
Run your laptop of the battery until the whole battery power comes to zero. When it does the laptop will shut down automatically. Now connect the charger and try to recharge the battery. Don't turn on the laptop, just switch on the charger.
Wait for about two hours, and start your laptop. If you see the same thing as before, then you might need to change the battery.
Posted on Nov 26, 2008
Sorry to hear that, but you can get some informations in mylaptopbattery.co.uk, good luck!
Posted on Dec 26, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 77 Answers
First put the dead laptop battery in a zip lock.
Then put the zip into refrigeratory and keep it in freezer for 14 - 15 hours.
Afer waitinf for a long time, take the dead laptop battery out of refrigeratory .
Using clean and soft cloth to dry the battery and get the battery to room temperature (about 20° - 25°)
In the end fully charging and discharging the battery for 3 - 4 cycles.
Now you would see that your dead battery holding up charge for 1-2 hours.
See the detail video in metacafe.com
View more info in : http://www.laptops-battery.co.uk/blog/revive-dead-laptop-battery.htm
Posted on Dec 18, 2008
    Problem Solver:
  • 8 Answers
If you need ThinkPad T23 accessories, pls visit:
Laptop battery: www.all-batteries-shop.com/battery-pack.php/188-1-ibm-battery
Laptop ac adapter: www.all-batteries-shop.com/adapter.php/963-13-ibm-adapter
Posted on May 09, 2009
T23 laptop. Put in new battery. WIth battery in
poor battery contacts or dead battery cell doing this flickering
replace the battery if contacts are clean inside the computer
Jul 06, 2010 | IBM ThinkPad T23 2647 Notebook
In my IBM T23 Thinkpad battery is fully charged showing green light constantly but not able to switch 'ON' after pressing the power button. What should I do?
try to switch it on with power cord still plug in it, if it do boot-up, you have to replace your baterry, if not somethings wrong with your laptop
May 06, 2010 | IBM ThinkPad T23 2647 Notebook
Spilled water on thinkpad t23 kybd
Hi, let it dry for a good few days, then try , hopefully it will; be ok.
Anthony
Jan 30, 2010 | IBM ThinkPad T23 2647 Notebook
Display drivers for IBM Thinkpad t23
Drivers for Vista are not available.
You can find all drivers for Windows XP{ and older clicking below:
IBM Thinkpad Driver Download models T22, T23
Direct link below:
T23 Video driver, v12.90.90
Mar 03, 2009 | IBM ThinkPad T23 Notebook
I need ibm thinkpad t23 vga drive
Direct link to Video driver below:
Dec 22, 2008 | IBM ThinkPad T23 Notebook
IBM Thinkpad T23 Won't Start
do you have a hard drive install??
laptop need a hard drive to start up. the one time start up you see before is just a accident.
as far as battery not charge, that is the porblem you run into, when you get laptop from ebay (taking chance).
you also need to download all of the drivers from IBM for the laptop.
Dec 10, 2008 | IBM ThinkPad T23 2647 Notebook
Video controller driver for other device in my IBM thinkpad T23 notebook
In most laptops with S-video connector, the Screen Resolution must initially be lowered down to match the capacity of the TV. This page might give you additional insights.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 30, 2008 | IBM ThinkPad T23 Notebook
Power-on password problem!
The power on password is stored on an EEPROM chip and removing the BIOS/CMOS battery won't help.
You need to read the EEPROM chip to get the password.
GOTO
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
for solution to your problem (you need to construct an interface hardware and install two programs on a working computer)
Have fun
ChrisH
Dec 28, 2007 | IBM ThinkPad T23 2647 Notebook
Power problem
then the battery is not holding charge try leaving power cable in and switch on
Aug 22, 2007 | IBM ThinkPad T23 Notebook
IBM ThinkPad T23 2647 Notebook Logo
4,897 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
