Can't get into HP Solution Center to scan a document.
  • 1,879 Answers
Close HP Solution.
Click Start, Accessories then click on Scanners and Camera Wizard.
Posted on Nov 14, 2008
Hp 6210 officejet all in one ... want to test scanner only. Took 16 hour tech assist to download (software was not provided by work associate). Ink cartridges do need to be replaced. Want to test the...
yes, you can test the scanner without inks.
use the hp solution center c01810967.gif installed on the computer Double-click the HP Solution Center icon (c01810967.gif ) on your desktop
  • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
  • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
      Click Scan
Jun 05, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I want to scan to my documents and the scan only scans to photo essentials. What do I do?
How are you scanning it ? From HP Solutions Center or HP Director ?
Try this step.
Open HP Director or HP Solution Center.
Under Settings you will find Pictures/Document Scan
Below you will find option like File Type : Choose JPEG or PDF
Save it.
IF this does not work, the best option for you is to uninstall HP Photosmart Essentials from Add/Remove programs ( or Control panel - Programs and Features )
But however, by default the pictures/documents are still saved in MY Documents - My Scans folder even if the Photosmart essential pop-up after you scan
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Mar 28, 2011 | HP Photosmart 4180 All-in-One Printer
F4480 how do I scan?
How to Scan in Windows without Using HP Software
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02459304&tmp_task=useCategory&lc=en&dlc=en&cc=us&site=null&lang=en&key=null&product=3742086
Scanning with HP Solution Center Software in Windows
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02453257&tmp_task=useCategory&lc=en&dlc=en&cc=us&site=null&lang=en&key=null&product=3742086
Mar 27, 2011 | HP Office Equipment & Supplies
How do i scan a document?
Visit to the given link and download the manual. The detail procedure is given in the manual... http://www.retrevo.com/support/HP-J4580-Multifunction-Printers-manual/id/20067ag014/t/2/
Hope this has helped you.. Please rate the answer.. Thanks...
Jun 25, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do I scan a picture from my HP (Printer*Scanner*Copier on to my PC
To scan a picture follow the following steps :
1. Click on start then click on All program
2. Click on the HP , and then click on HP Solution Center 3. If you want to scan a photo then Click the on-screen Scan Picture "button" in HP Solution Center.
If you want to scan a document without document then Click the on-screen Scan Document "button" in HP Solution Center.
4. Set the option to prompt for settings each time you scan, and then click OK
5. At last click on Scan.
and save your file.
Regards
Ashly
Feb 25, 2010 | HP Photosmart C4180 All-In-One InkJet...
How doI scan something?
To scan something from your printer to the computer you should have the hp solution center installed in your computer double click and open the solution center place the document or the picture that you wnat to scan on the glass bed of the printer (the text content should face towards the glass)
now click on the scan document or scan picture button on the hp solution center a window will come up click n the scan button then a window will come up showing the preview of the scaned document or picture click finish to finsh the scan
now you can view your scan by going to the MY SCAN folder in MY DOCUMENTS
Jul 30, 2009 | HP OfficeJet J4580 All-In-One Laser...
How do i scan a document and then email it
If you haven't done so, install the cd that comes with the HP Officejet package. Once correctly install, you should go to "All Programs" and locate "HP Solution Center" Click on HP Solution Center, click "Settings", click "Scan settings and preferences", choose either "scan document" or "scan picture" If word document then under File type: locate "PDF(*.pdf) If document is a picture then under File type: locate "JPEG image(*.jpg), click ok. Step 2 Choose between Scan Picture or Scan Document, click accept Step 3 your file is locate under "My scan" Hope that helps
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet & Vista compatability
Have you tried to use HP SOlution Center when scanning and save the scanned document to .pdf? try this solution.
Note: HP Director and HP Solution Center has more likely the same settings
CLICK HERE TO VIEW: DOCUMENT
Thank you so much.
adonscott
Feb 20, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Problem with c6180 when used with mac/leopard
Follow below instructions to scan more than one pages to a single document :
1. Open HP solution center.
Click Start - All programs - HP - HP Solution center.
2. Click Scan document - Click Accept.
Computer will ask "Would you like to scan another page?" Say Yes and scan the other side of the document by following onscreen steps.
Thanks
Dec 22, 2007 | HP Photosmart C6180 All-In-One InkJet...
Scanning
Hi, Let me help you with this... Please install be sure that the full feature HP software is installed in the computer to use the scan function. You can direcly scan from HP software by following the below steps: Click on start button in the computer Then click on All programes >> HP >> HP solution center Once the Hp solution center is open click on it and then in the screen you will see buttons in left pane like scan picutre, scan document Just click on any of the button as per your requiremet and then in the next screen select the type and location you would like to save the scanned image or you will receive the image of the scanned document or picture and in the bottom there will be a accept butto just click on it to save the scanned image Here is the link that has all the instructions to scan settings in HP solution center: ===================== http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00769700&cc=us&lc=en&dlc=en&product=1146336&dlc=en&lang=en ====================== Here is the link that has all the instructions to change the advance settings in HP solution center. ====================== http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00529110&cc=us&lc=en&dlc=en&product=1146336&dlc=en&lang=en ====================== Hope the information is helpful to you Regards Barret.
Sep 11, 2007 | HP Photosmart C3150 Printer
32 people viewed this question
jasbo
jasbo
