PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Motherboard replacement Fujitsu Siemens Ami...
By scooby_66 on Nov 14, 2008
Hi, all can anyone help me with this problem I'm trying to remove my motherboard as it's dead. I am able to remove the bottom two covers the plastic ones then there is a metal plate that conceals the rest of the board and the dvd-rom it's here were I fall down. If anyone has any informationregarding removal of this it would be really appriciated
thanks in advance for any help
Comments:
Nov 14, 2008
- Hi thanks for the information but how I remove the steel plate that covers the Dvd rom ?
thanks
Nov 14, 2008
- Hi again , thanks for the info can you please tell how to remove the steel which covers the dvd-rom
thanks for your help
Nov 14, 2008
- I've tried pulling gently on the dvd-rom but it's well fixed in, there does not appear to be any hidden screws.
Thanks for your help
Nov 14, 2008
- The base comes in two halfs one side houses the batt, memory, processor, Hdd the other holds the dvd-rom and I assume the chipset and graphics card, it's this part that that's not moving. One side will lift but not much, and I don't want to force it, i can see into this area and can see that the plate appears to be attached somewhere above the dvd-rom
thanks
Nov 14, 2008
- Threr are holes but nothing large enough to house a screw they're about 2 - 4mm in diameter and there are no screw heads visible. It does appear to be fixed at the dvd-rom although not directly to it, as there is the base of hte rom then this steel plate ? hopes this helps
Nov 14, 2008
- Many thanks for your help I really appriciated you took the time with this
Dec 09, 2008
- Thanks for the reply, how do i remove the dvd rom ? will it just pull out or is there something i should remove first
thanks
Best Solution
posted on Dec 09, 2008
Very Helpful)
mbe71
Rank: Apprentice
Rating: 100%, 3 votes
hi there , just removed that metal plate here, you need to pull the cd rom right out, then right on that opening of the cd rom you will find a screw, also, there are four others on the corners of that metal bit to be removedthen, just lift it up, job done, hope this helps..
Comments:
Dec 10, 2008
- Hi there, yes, the dvd rom just pulls out, on mine there was just a push in conector on the back of the rom.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 14, 2008
Helpful)
leecom72
Rank: Guru  Computers & Networking  Expert
Rating: 89%, 2644 votes
look for any hidden screws, look where the external monitor connects to see if there are any "nut" type screws the motherboard will come out just be patient with it
Comments:
Nov 14, 2008
- have a look underneath the laptop for a hidden screw, or on the top near the steel plate, get a pin and manually eject the tray on the cd/dvd ( you'll see the hole on the font ) and pull gently intill the device slides out
Nov 14, 2008
- is there a release catch underneath the plastic base that is spring loaded ?
Nov 14, 2008
- does the metal plate above the cd/dvd have holes on it? if so get a torch and look beneath the plate for hidden screws
Nov 14, 2008
- have a look on line for the disassembly or sevice manual, i have looked everywhere and had no luck, you may have to contact fujitsu siemens for the service manual and they will probably want paying.
Sorry i couldn't help any further
Good luck
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
wont to know if theres any way i could reset my labtop cause i can not get into my windows due to... (More)
Answer
what is the easiest to install/use and best router for a dell inspiron laptop?
Answer
Please give me the URL for my new LG laptopPlease give me the URL for my new LG laptop manual. I... (More)
Answer
My laptop won't charge properly.  Sometimes if I hold the end of the charger in the hole in... (More)
Answer
Monitor will not display. I have hooked laptop to another monitor to try to diagnose problem. ... (More)
Describe your PC Laptops problem:
Select a Category:
Related Products & Issues:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in Baltimore, MD
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
