Question about Brother MFC 420CN All-In-One InkJet Printer
I still have the`unable to clean 46' even after following the
Error message on page 67 of the USER'S GUIDE.
The DCP-540CN is approximately 14 months old.
  • johnhatcher6 Nov 24, 2008
    Hi dahaka,
    The printer is a Brother DCP-540CN not a MFC-420CN and the error message is 'unable to clean 46'
  • 1,879 Answers
Issue with the maintenance function. The machine has a mechanical problem (can't move print head or other parts related to printing. Check for any obstructions. Disconnect the machine from the power for
several minutes, then reconnect it.
If the issue shows up again, warranty or service.
Posted on Nov 18, 2008
  • Brother Master
  • 19,396 Answers
Give us details on the error message.
  • 94 Answers
It means that there is a mechanical problem on your printer. Try to unplug the power cord on your printer (without turning off the power button on the printer). Wait for a couple of minutes then reconnect the power cord.
    Brigadier General:
  • 3,614 Answers
Try uninstall completely the printer driver
restart the pc and install again the driver.
Keep us updated
    Sergeant:
    Champion:
  • 347 Answers
Hello Johnatcher6,
What is the error message that your printer shwows?
  • Santiago Vallejo
    Santiago Vallejo Nov 24, 2008
    Hello John,
    Disconect it for several minutes, and conect it back.
    Theerror shoulddisapear,
    if it dosent, let me know,
    Dahaka
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
printer is flashing "CLEAN UNABLE REFER TO 46- TROUBLESHOOTING AND ROUTINE MAINTENANCE IN USER'S GUIDE..BROTHER 2480C
Feb 23, 2013 | Brother Multi-Function Center MFC-3360c...
Dcp-165c clean unable trouble shooting and routine maintenance chapter in user's guide 46
for non fax models ie I have DCP 165C you say press ...... press up arrow four times then press 8 then 0 etc ... but I have no numbers to press!
Jul 15, 2012 | Brother DCP 165C Compact Color Inkjet...
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Clean unable 46
C D WORLD NAGPUR 09960014121
HI ALL HOW TO CLEAN DCP ERROR CODE 46
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Apr 09, 2010 | Brother DCP 165C Compact Color Inkjet...
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
DCP-110c is showing machine error 46. I have followed instructions as per cene765 solution #1 withput success. I get as far as 'maintenance 80 display. Pressed 'mono start' many times but still displays...
Many thanks - I fixed the error 46 by following the helful solution provided below.
mydcp110c
Rank: Apprentice
Rating: 86%, 8 votes
Hello!
Here is the "Unable to Clean" (code 46) solution:
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Solution no. 1. (DCP-110C):
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times.this should all be done as short a time as possible, around 3 seconds.
Dec 11, 2009 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Mar 24, 2009 | Brother DCP-330C All-In-One InkJet Printer
Brother DCP-115C USB Printer
plz search this forum for error 46 or "unable to clean". It has been written many times ;-)
May 14, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP-110C printer/copy/scan/photocapture
so please tell us, what does the display tell you? Is it unable to clean? If so search for "unable to clean" or Error 46. This is explained a thousand of times here...
Mar 16, 2008 | Brother DCP-110C All-In-One InkJet Printer
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- ready to print
Jan 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
81 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
