Question about Brother HL-2040 Laser Printer
Paper Jamb in Brother HL 2040 Printer
How do I remove the paper without forcing it to come out?
  • 1 more comment
  • mooshka22 Dec 26, 2008
    I have the HL 1240 someone has given to me. Every paper it prints jams. It appears to print, and go thru the fuser but then crinkles up and stays inside the printer.Any ideas?
  • John Dec 29, 2008
    Once it start with half printing, then paper jam in the cartridge with first a kracking sound of gear.
    Then, the second time NO MORE PICK UP.
    Toner refilled full.
  • gromo003 Feb 10, 2009
    paper is jambed and I can't get it out
Inside the printer their is a roller and if you turn the roller then it should feed the paper through it fairly easily. it may seem like you are turning really hard but it will work.
Posted on Nov 16, 2008
My printer hl 2040 keeps saying there is no paper but there is enoughin the tray
You have problem with sensor for detecting paper. Try to clean it. Remove paper and put inside again. Possible of restarting of printer can help. Electronic for sensor have wrong information.
Aug 25, 2011 | Brother HL-2040 Laser Printer
When I turn on the printer the light paper flashes
The paper light flashing because there is some paper inside the printer. Open the front cover and remove the cartridge and look inside for the jammed paper. Remove the jammed paper and insert the cartridge , closed the front cover and switch on the printer.
It will help you to solve the problem.
Jul 22, 2010 | Brother HL-2040 Laser Printer
I have a paper jam in my printer. The paper is
You will have to open the Printer door and pull the paper out if you are lucky it will pull out in one piece if not you will have to get all the pieces out before it will operate again. When pulling out go very easy with it and move your fingers down with the paper to apply force at the closest point to where the paper pulls into printer.
May 13, 2010 | Brother HL-2040 Laser Printer
I have a Brother HL-2040. The "paper light is on & won't print.
Sounds like a paper jam. There's a flap at the back of the printer-once open you should be able to see if the paper is stuck there. (Exactly the problem I had yesterday-I didn't spot it at first and it nearly drove me mad! :)
Good luck,
Nov 13, 2009 | Brother HL-2040 Laser Printer
This is a paper jamb problem. There is a piece of torn paper stuck in the paper path that is stopping the printed page from exiting properly.
Sep 30, 2009 | Brother HL-2040 Laser Printer
I have paper stuck in my Brother HL-2040 but cannoy see it. How do I open up printer to get the paper out?
there should be latches on back side and on the bottom side of the printer. when you unlock it and open you will be able to see the paper.Usually if you open cover just as to remove cartridge you should see paper jammed
Sep 23, 2009 | Brother HL-2040 Laser Printer
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Mar 25, 2009 | Brother HL-2040 Laser Printer
Brother HL-2040 Flashing Paper LED
Try send one paper manually, then it will pick up paper from the try automatically.
Feb 06, 2008 | Brother HL-2040 Laser Printer
Paper Curling with Brother HL-2040
Replace fuser assembly/have fuser unit replaced if you have tried fresh quality paper from a unopened ream. The first versions of these had the fuser and exit assembly modified by brother to help eliminate excessive curl last 9 digits of serial number are higher than D5J760210 have already been modified, if lower ie D4Z99999 need to get mod. fitted.
Jan 10, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
152 people viewed this question
James Cagle
James Cagle
Jim Keysor
