Question about Concord Camera Eye-Q 4060AF Digital Camera
Batteries problem.... Battery was running low I've changed and try different brands, but still nothing, the camera (concord eye q 4060 AF), keeps on shutting off after 30 seconds ....My boss wants me to figured this out but i'm far from being an expert, pleaseeee help me !!! thank you!!!
A power saving feature on this camera allows one to set the camera to shut itself off after a certain amount of time. One of these settings is 30 seconds... You might want to check. "The camera has a built-in power saving feature that turns the camera off after 30 seconds of inactivity (default setting) to conserve battery power. The auto off time setting can be changed in the set up menu. Changing the Auto Off Time Setting: 1. Set the camera to Camera Mode. 2. Press the Menu button to display the main menu. 3. Press until the Setup is highlighted. 4. Press to enter the Setup submenu. 5. In the Setup menu, press to highlight ?Auto Off Time?. 6. Press to enter ?Auto Off Time?. Press to highlight the time you want. 7. Press the OK button to save your selection."
Posted on Jun 13, 2009
Try rechargable NiMH batteries. They are specifically designed for today's technology, and last much, much longer than traditional batteries. It doesn't matter about the brand -- Energizer, Rayovac, Duracell, generic -- I've found that they all tend to last about the same amount of time in my digital camera. But I only use rechargable ones anymore.
Posted on Nov 30, 2008
How long do the batteries last when shooting video with Eye-Q 3042 AF camera, using standard batteries?
What you call standard batteries, could be the worst battery there is.
Try using NiMH rechargeable batteries. Even alkaline batteries reform worse. And never use manganese (Zinc-Carbon) batteries. They not only can't deliver enough power on the right voltage long enough. They easy start leaking and can damage the camera.
keep up to this:
Always be sure the batteries are charged and suited for your device.
Check contacts of the batteries and in the battery compartment of your device. Dirty or oxidised contacts can be cleaned with a dry cloth, or a cotton swap. Never use sharp tools to clean contacts or anything in or on electronic equipment.
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
Aug 18, 2014 | Concord Camera Corp Cameras
Concord 3042 af needs sd memory card
You need to find a standard, 512MB maximum SD card (NOT a SDHC or SDXC). Source: user manual. Good luck!
Oct 05, 2012 | Concord Camera Eye-Q 3042AF Digital Camera
Acer Travelmate 4060. Dead. Flashes power/battery led once when I hit the power button then nothing
Try removing the battery and plugging the machine in as if you were going to charge it, then try starting it up.
If it doesn't start up, check the connections on the adapter. If everything looks fine then theres a possibility that you have a broken adapter.
Mar 30, 2010 | Acer Aspire 4520-5582 Notebook
How to turn flash off on concord Eye-Q 4060 AF??
Press the joystick toward (>) repeatedly until the desired indicator (flash lightening bolt)appears on the LCD.
To do this, I checked the manual. The manual is available at the following address:
(note, you will need to enter a captcha (numbers that appear) to download this manual.) Let me know if you have problems downloading this, as I have a copy.
May 21, 2009 | Concord Camera Eye-Q 4060AF Digital Camera
Concord eye q 5062 AF Camera
Taken from the concord website and I quote
"Special Note:
Concord cameras are incompatible with the Windows Vista operating system. Please do not download or use the drivers listed on this site in a Windows Vista operating environment."
Look here for more info
Sorry i couldnt be of more help
Aug 25, 2008 | Concord Camera Eye-Q 5062AF Digital Camera
Concord eye_Q 4060
do not have a solution as the spares or service centres are not available in Australia,
very frustrating as its a good camera ,its stuck on the night portrait mode ,the reset to original setting wont work due to the toggle not responding on the upward movement ,thanks anyway ,Mike
Jul 03, 2008 | Concord Camera Eye-Q 4060AF Digital Camera
Low battery indicator
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Jun 17, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Concord eye 4360z
I suspect it has died on you. and there will not be a repair option Dee
Jun 06, 2007 | Concord Camera Eye-Q 4360z Digital Camera
Concord Camera Eye-Q 4060AF Digital Camera Logo
100 people viewed this question
Top Concord Cameras Experts
Michael Galve
Michael Galve
Are you a Concord Camera Expert? Answer questions, earn points and help others
