Question about Garmin StreetPilot C330 GPS Receiver
Garmin c330 gps will not turn on
I have a Garmin c330 GPS. When I turn it on, either nothing happens or the Garmin display comes up and then immediately shuts down unless I hold the power button, even then it does not go any further with the display. Do I need a new battery or is this thing broken?
  • 14 more comments
  • PATTY57 Nov 14, 2008
    Was workign fine for 2 hours and then the face went black does not charge in the car charger.........does not charge withthe USB Cable.
    Brand new jsut received it on Tuesday..HELP
    HELP
  • mary1975 Nov 19, 2008
    My gps will trun on briefly and then shut off. I did by a new charger and it still does the same thing. Any thing else I can look for to fix this?
  • draggio Nov 20, 2008
    Garmin 330 will not come on. Blank screen.
  • thegaudios Nov 20, 2008
    Screen just went blank and the unit wont turn on, not even with the charger attached.
  • Anonymous Nov 29, 2008
    Garmin turns on and then goes off. Is it the battery, or fuse?
  • tantanlai Dec 03, 2008
    My Garmin C330 could not turn on today but it worked well for one and half year.
  • Anonymous Dec 03, 2008
    i have the same problem, wont stay on when blue screen comes up
  • christinejne Dec 06, 2008
    Same problem. I've had it for a year. Should I buy a new one or can it be fixed?
  • tomklessig Dec 08, 2008
    Nothing happens when I turn on the power
  • rshekaran Dec 11, 2008
    Garmin Pilot will not turn on and sometimes turns on for few secs and goes off.
  • tmckennie Dec 12, 2008
    I have the same problem. I turned my Garmin StreetPilot c330 on and it stayed on for less than 5 seconds and now it does nothing. I have checked the power source and it works with no problems. What should I do?
  • svogin1 Dec 14, 2008
    I have the problem cannot get the unit to turn on
  • Anonymous Jan 28, 2009
    my garmin comes on then turns off
  • Anonymous Feb 21, 2009
    Garmin c330 gps will not charge in vehicle. I have tried it in 3 vehicles. The Garmin strictly runs on its battery. When the battery power runs out the unit goes down.
  • Praskash Feb 21, 2009
    Garmin Pilot will not turn on. I have tried it on two different vehicles.
  • carrie_brian Apr 29, 2009
    Will not stay on shuts off in about 5 seconds. Please help
Try this just worked for mine
1.Under the face plate by the Garmin Logo.Use your thumbnail to remove the plate.
2.Press the reset button.
Information located on page 28 of the owners manual if you need a diagram.
Posted on Jan 28, 2009
Posted on Dec 07, 2008
I have a garmin c330 gps i bought last december and now ot won't come on and stay on. is battery bad?. can i recharge? and if so, how? i have an 05 honda pilot and had all plug ins checked and they work,so it's not that.
Posted on Nov 16, 2008
Will not stay on
Posted on Nov 25, 2008
My garmin c330 will only work with a usb port connection and when i unplug it it goes dead again,, do i need to replace a battery inside somewhere?
This is very possible, if when you press the power button on the unit and it is not connected to anything and nothing happens
Jan 04, 2010 | Garmin StreetPilot C330 GPS Receiver
My garmin C330 won't power up nothing happens when I plug it in
Have you checked the fuse in the end of the cigarette lighter adapter? If not unscrew the metal end of the adapder, this will expose a fuse, replace it and try it again.
Hope this is of some help
Ed
Jun 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Gps will does not work
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Feb 22, 2009 | Garmin StreetPilot C330 GPS Receiver
Street pilot c330
It took a nap...
Feb 21, 2009 | Garmin StreetPilot C330 GPS Receiver
GARMIN PROBLEMS
Had the same problem. Called Support. They answered immediately - a HUMAN, no recording, speaking American English - walked me through some tests, diagnosed a defective battery, gave me info on returning unit, I had it back in a flash. This is a classy outfit, and the Garmin C330 is a superb piece of equipment, has been flawless since.
Call 1-800-800-1020
Aug 29, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 cracked screen
You can buy a new C330 now for $125 - $175. It would probably cost that much to repair the old one, I would replace it.
Jul 07, 2008 | Garmin StreetPilot C330 GPS Receiver
How to charge garmin c330 gps from computer
The unit came with a USB cable. Plug this into the GPS (when it is turned off) and it will come on and the unit will charge while showing an image of the GPS connected to a computer tower.
Mar 19, 2008 | Garmin StreetPilot C330 GPS Receiver
Dos not come on.
Does it come on at all, or you get nothing when you press the button? How long are you trying to charge it on the computer? Try charging it for about 10 hours on the computer. Sometimes this can help.
Jan 18, 2008 | Garmin StreetPilot C330 GPS Receiver
GARMIN C330
I'd suggest buying from a dealer that knows the product they are selling. Just because you didn't do that doesn't mean the GPS isn't exactly what it is suppose to be.
Nov 19, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
1,313 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
