Refrigerators
Problem for Refrigerators
Generic problem for all Refrigerators
Freezer down
By nad3221 on Nov 14, 2008
seems cold but not freezing, last night popsicles melted, I thought the kids left door open, most ice in ice maker still solid
Solution #1
posted on Nov 14, 2008
Not Rated)
FIX IT RIGHT
Rank: Guru
Rating: 87%, 240 votes
CHANCES ARE THE DEFROST HEATER HAS GONE BAD LOOK IN THE BACK OF THE FREEZER ON THE REAR WALL DO YOU SEE ICE BUILD UP? IF SO TAKE A HAIR DRYER AND MELT THE ICE.MAKE SURE THE FREEZER IS UNPLUGGED.NOW REMOVE SCREWS TO GET THE COVER OFF AFTER REMOVING THE COVER CHANCES ARE YOU WILL FIND THE COILS FROZEN OVER.USE THE HAIR DRYER AND DEFROST THE COILS CLEAN OF ALL ICE.NOW THAT THE ICE IS GONE YOU NEED TO OHM OUT THE HEATER WITH A VOLT OHM METER YOU CAN BUT ON AT ANY HARD WARE STORE OR EVEN AT WAL-MART. WITH OUT KNOWING THE BRAND OF FREEZER I CANT TELL YOU IF IT IS A CAL ROD ELEMENT (LOOKS LIKE YOUR OVEN HEATING ELEMENT OR A GLASS TUBE. IF IT IS THE GLASS TUBE YOU SHOULD BE ABLE TO SEE THE WIRE ELEMENT INSIDE IF YOU CANT REPLACE ELEMENTS/S WITH THE DEFROST THERMOSTAT. IF IT IS THE CAL ROD YOU MAY OR MAYNOT SEE WHERE IT IS BROKEN YOU MAY HAVE TO OHM IT OUT BUT AGAIN REPLACE THE THERMOSTAT ALSO. BUT SINCE YOU HAVE THE UNIT DEFROSTED THIS WILL GIVE YOU ABOUT THREE DAYS UNTIL YOU NEED TO DEFROST IT AGAIN IF YOU HAVE TO WAIT ON PARTS BUT REMIMBER TO PUT REAR COVER BACK ON OR IT WONT COOL
GOOD LUCK
Was this helpful?
Yes
No
Popular Solutions for Refrigerators
Questions and Unsolved Problems for Refrigerators
Answer
I am thinking of buying a used 2005 GE side by side fridge model GSS25XSRCSS. Any experience good... (More)
Answer
the samsung four door quattro refrigerator
Answer
how to use the fridge need operators manual
Answer
My model is Refrigidaire Galleria. It is suddenly not cooling. All the lights are on. The freezer on... (More)
Answer
What couses constant clicking of GE Profile bottom feezer Ref. Mod. No. PDS22MFSBCC
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repairmen
in , AR
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
