Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
Coffee stopped coming out of nozzle
Coffee, or rinse cycle no longer properly comes out of the front nozzle.  Instead it is spraying inside the brew unit chamber and filling in the dreg drawer and drip tray.  I checked the brew unit motion and it is fine; I also lubricated the gasket ring and the guides.  A week or so before this problem started, I performed a descaling cycle.
The machine is also frequently "priming the machine" but this also does not properly exit from the front nozzles and instead sprays inside the machine.
Hot water dispenser works fine.
    Sergeant:
  • Saeco Expert
  • 223 Answers
The problem with your machine is the connection where the brew unit connects to the dispensing head is broken. This is why the machine is leaking into the dump box. I wish it was an easy fix, but it is not.
You will have to get the machine serviced.
If you would like to have your espresso machine serviced please visit the service page of our website:
http://cerinicoffee.com/Espresso_machine_service.asp
Cerini Coffee Services
Authorized Saeco Service Center
Posted on Nov 15, 2008
When brewing coffee about half the water comes out of the frothing nozzle instead of the coffee spout. The nozzle also leaks after the brewing cycle.
I would say that something has a hole in it, but if it doesn't it might have bad quality, and if it isn't that because the place where you bought it from sells good machines, then it still might have something that went wrong or something was misplaced. I'm not sure either, but that's what i think is the most likely reason. You could always try ask the place manager and ask him if there is anything wrong with your machine.
Hope it ind of helped!
May 30, 2015 | Jura Capresso Impressa E8 Espresso/Coffee...
The water coming out of the steam nozzle is clear but fromthe brew head it is milky looking. I have descaled
That's ok .
The water from the steam nozzle is straight from a boiler.
Where as the brew head is fed from another boiler via the brew unit,so you will still have some coffee in the system.
If you wanted to you can rinse the brew head by making preground coffee without coffee this will flush it clean.
Nov 28, 2009 | Gaggia Titanium Espresso Machine
Water not getting through
If you look under that white nozzle you will notice a small hole that leads to the drain tray, clean out hole and the area or small enclosure around the white nozzle (clogged with coffee grounds), and make sure that if you pour a little water in that enclosure it goes to the drain tray. That will solve the water under machine problem.
For the amount of water from the coffee nozzle, check brew unit, you will have to remove the shower screen and clean, make sure that the unit is not clogged in one of the tubes.
May 19, 2009 | Solis Master 5000 Espresso Machine
Water coming out of steam nozzle not coffee output when making coffee
Sounds to me there might be a blockage on the brew unit, and since the pressure is so high it is going through the bypass. Clean the screen and tubes on the brew unit.
May 12, 2009 | Gaggia Syncrony Compact Coffee...
Braun coffee maker starts brewing, then stops after a few seconds
ijustam1
I have the same machine, Braun KF180 12 Cup Coffee Maker. In normal operation the brew cycle is stopped when the water reservoir is empty. The only way the coffee maker knows if that is true is when the water-brewing heater gets too hot. Your brewing heater is probably encrusted with calcium deposits if you have been heavily using the coffee maker. Vinegar will work but it is weak and you will have to cycle this solution through many many times. You should instead use "Lime Away" or "CLR" and let it sit there in a brew cycle or multiple brew cycles for a while. NOTE: Remove the filter when cleaning this way and when the brew cycle is complete, rinse thoroughly -- your taste buds will let you know if the machine is not rinsed thoroughly. -- Good Luck!!
Jan 22, 2009 | Braun FlavorSelect KF 180 Coffee Maker
Braun Flavor Select will not brew coffee.
I assume You are talking about the water-brewing heater thereare two, the second is the heater that warms the coffee pot (I think!). When the water-heater is encrusted with calcium deposits it "thinks" that the water reservoir is emptyand ceases the brew cycle. water boils at 212 degF and the heater will go to a much higher temperature. I will leave you with the same solution as was posted to another problem that may have similar cause:
corvette2
Nov 16, 2008 | Braun FlavorSelect KF 180 Coffee Maker
Water no longer comes out of the fill spouts during a rinse.
try and do a heavy duty de scale of the machine , put some descale directly into the tank, heat up ( de scale works better at high temp) select rinse, clean or flush programme. the vast majorty of probs. are due to limescale in the narrow pipe work.
Feb 08, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
295 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
