Question about E-Machines eMachines Desktop PC
Computer randomly fails to boot
The past two weeks my computer has randomly failed to boot up.
Typically the computer turns on, the monitor remains in a 'sleep mode' and does not receive a signal. I can see the DVD light flashing on my DVD drive but the hard drive light only flashes for a split second(doesn't appear to be booting to XP.) When I've had the case open on failed boot attempts the the psu fan, case fan, heat sink fan and PCI-Express card fans all come on instantly but the monitor doesn't receive a signal, nor does the hard drive light appear to be booting. On one occasion the PSU fan ran at an abnormally high speed and nothing else seemed to be working but I didn't have the case open to verify this conclusively.
The computer is an Emachine T-6412 about four years old. I have replaced the PSU as it was suggested to be the source of the problem. The hard drive uses IDE 'ribbon' cables which are the originals from the manufacturer. Yet I cannot figure out why the monitor doesn't provide a "no signal" error, or if it is the monitor/monitor cable why the hard drive light doesn't appear active/doesn't sound as if it fully boots. Is it the motherboard? Monitor cables, hard drive...? Any help would be greatly appreciated. TIA.
System Specs:
Motherboard: Board: MICRO-STAR MS-7184
BIOS: Phoenix Technologies, LTD 6.00 PG 08/19/2005
CPU/Speed: 2.20 gigahertz AMD Athlon 64
RAM: G.Skill 2GB(2 x 1GB) DDR 400(PC 3200)
200.05 Gigabytes Hard Drive(128.85 Gig Free Space)
Sound Card:SoundBlaster Live 24 Bit
NIC: Realtek RTL8139/810x
Power Supply: Corsair 450W
OS: Windows XP Home Edition Service Pack 3
  • 1 more comment
  • Axekick Nov 14, 2008
    One, the ATI Radeon X800 Pro, PCI-Express
  • Axekick Nov 15, 2008
    One video card, it is listed in the specs I posted. ATI Radeon X800 Pro (PCI-Express).
  • Anonymous Apr 27, 2009
    mine too its a t-5212.. what is wrong???
  • 3 Answers
How many video cards do you have installed?
Posted on Nov 14, 2008
4 Suggested Answers
SOURCE: Board: Foxconn 45GM/45CM Serial Number:
when you go into a computer store to buy a graphics card they know what kind of graphics card you need just take your motherboard info with you.
Posted on Nov 02, 2008
  • 15 Answers
SOURCE: I have a eMachines T2082 Inc. L7VMM2
This is the support page for the board. Scroll to bottom of page and download the manual which contains the location of the hard disk LED pins. Thanks Mike
Posted on Nov 29, 2009
  • 37 Answers
SOURCE: My BIOS info is Phoenix Technologies, LTD R01-B3,...
Im not sure but I dont think so open your bios and it shoud tell you if it is supported
Posted on Jun 01, 2010
My computer screen randomly turned white and won't
Your screen might be going bad. Try plugging an another monitor and see if it works or has the same problem. If the other monitor works, it's definitely your screen is bad. If the other monitor fails and does the same thing, then the video card in the computer is bad.
Mar 28, 2012 | HP Computers & Internet
Suddenly a very thin vertical yellow/white line appearing on my HP desktop monitor? pls help
Does it appear THE MOMENT you turn the unit on?
If it does, then you will have to run the monitor's self-test function by turning it on with the data cable (the one that does NOT connect to the power outlet) DISCONNECTED from the computer.
If the line still appears, then the monitor is faulty & cannot be "repaired". Usually, the entire LCD module is replaced.
If the line does not appear in the self-test mode, then check if it's connected to an ON-BOARD display adapter (typically found in the back of the machine, towards the middle area, towards where the ethernet cable and USB devices plug in) or a EXPANSION CARD (normally located towards the BOTTOM part in the back of the machine).
If it plugs in to the on-board slot, then the motherboard may be faulty. If it plugs in to an expansion card, then it's the card that may need to be replaced.
Of course, these are merely possibilities, but the most likely failing component here is the monitor itself. Busted display adapters very rarely, if at all, manifest these horizontal or vertical lines and STILL boot up. Regardless if it's on-board or expansion card, a failing display adapter would normally have either no display at all, or it would just simply stop booting up (screen remains dark: no lines).
Aug 12, 2011 | Computers & Internet
My monitor keeps randomly turning off.
You may have failing caps in power supply.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 19, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
No image -- monitor remains black
Without any instruments to check it with, substitution is the best test; in other words connect the monitor to another system for a minute or two and/or a different monitor to your system. (If you can do either, don't do 'hot' swaps, turn everything off and then back on again.)
If you've noticed it; you may have seen that the LED flashes if the monitor is left on and the system shut down. Removing the VGA cable from the back of your system (or the monitor if it is separable) should produce the same result; flashing LED. If this is the case, then your video source from the system (on-board of add-on) has failed. If the video chipset on the motherboard has failed, it can be disabled and replaced by an add-in board for a few dollars.
Oct 12, 2009 | Acer AL1916ASD (Silver) Monitor
Acer Aspire 5100 laptop's screen remains black at start-up
This is probably a hardware issue with the monitor. Just to make sure, uninstall, and reinstall the monitor's driver. If that doesn't fix it, it's a hardware issue.
You will have to either take it to a shop, or contact the manufacturer (your computer should be under warranty if you've had it for less than a year).
Sep 19, 2009 | Acer Aspire 5100 Notebook
Computer fails to start
First,Check the monitor on another computer,If it works we can go from there.
May 13, 2009 | Acer Computers & Internet
Iiyama Pro 452 clicking sound during start-up
Your CRT Monitor will fail soon. The clicking sound is coming from your CRT's power circuit.
Make plans now to replace it. This problem is known to be a fire hazard in some cases. So, better safe than sorry.
Sorry for the bad news.
Hope this was helpful.
May 21, 2008 | iiyama Vision Master Pro 454 19" CRT...
Acer Aspire 3100 Laptop Monitor will not turn on
1. Mainboard failed
2. Vga adapter failed
I wouldnt be suprised if the vga failed, my acer broke down on me 2 times, on the 3rd time it was too much and I sold the laptop.
Mar 23, 2008 | Acer Aspire 3100-1405 Notebook
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
E-Machines eMachines Desktop PC Logo
577 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
