Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
MacBook laptop 3.1 keyboard issue, Leopard OSX
Yesterday I had used my laptop without any problems throughout the day, however later that night I had a very strange issue come up. I had shut down the laptop in order to take it to class that evening. When I started it up again @ class, the keyboard would not work. The caps lock light was lit and remained so after I tried to turn it off. The trackpad and the click button below it work, however when I tried to double click on the track pad (I have the feature enabled) it will not work, and only works on the click pad. I can run all programs just fine on the laptop, as well as the internet, however I can not type anything, anywhere. I have had the laptop for less than a year, and this is the first problem I've had. I can't be too upset for that reason, however without the keyboard, I can hardly do anything.
I have taken the battery out and let it rest/set for a good couple of hours, and then put it back in and turned it on. I have also removed the battery, pressed the power button for 15 secs and then put the battery back in and turned it on, only to reach no results. (The tech support guy suggested I try this...neither worked....)
I'm not sure if I had accidently turned on the num lock or pressed some keys to cause this to happen? Regardless, I called the tech center however my warranty did not include the tech phone support to try much else. I currently am no where near a repair center, otherwise I would take it in. However, I do need to use the comp asap. Any advice or help would be greatly appreciated!! Thank you So much!
  • Anonymous Dec 20, 2008
    This happens to me constantly.  It's been getting worse and worse.
I too have had Macs for years.  The one you have now I also have.  I have had no problems with it yet.  Whenever I have a problem I just take it to an apple store and the Genious will either fix it or be able to tell you what is wrong.  It doesn't matter if the warranty is valid or not, they will take care of the problem for you.
Sorry I have no other help for you.
fullard
Posted on Nov 14, 2008
I can not get my Apple Macbook laptop to recognize my Mp3 player or add music to it. Says device is unreadable and gives me option to "initialize", "eject," or "ignore" when I plug it in to my computer....
Before you blame your MacBook, make sure another MAC can read your player. If it can, then it's a hardware compatibility issue. Would suggest you back-up your data on the MAC and upgrade the OSx to the latest version. If you have Leopard, please update to Snow Leopard at least. The update disk costs very little and is very easy to do by simply inserting the CD and following the instructions. You will need to reimport your programs and data using the Time Machine program on your MacBook. Max out the memory in your MacBook while you are upgrading it. Crucial.com provides most of the memory for most mfrs, you can use their site configuration to determine the best memory for you MacBook.
Mar 12, 2015 | Eclipse Fit Clip Plus 8GB* MP3 Player
CAN I UPGRADE FROM OS X LEOPARD 10.5 TO MAVERICKS
Nope, yo can upgrade to osx lion (10.7 max),
Apple says you'll need a better graphics card if you want to use mavericks.
Your macbook has a Intel GMA x3100 which is unsupported.
Try osx lion if you hace 4gb of RAM. It's cool :)
Cheerio :)
Sep 20, 2014 | Apple MacBook 13 inch NW A1181 A1185 WHITE
Want to format my seagate freeagent go 320 gb external hard drive to a macbook laptop want it to be compatiable to the mac?
Format the external hard drive to a exFAT (OSX snow leopard or later), or FAT32 (all versions of OSX). It can be read and written for both mac and windows.
Nov 02, 2012 | Computers & Internet
Hi,I m using windows7 on macbook 3,1, but my webcam & blue tooth not found in system. there is apple builtin cam, i try to download the drivers but cant.help me plz
You should just need to insert your OSX disk maybe snow leopard, then install bootcamp drivers from it also run apple software update, from the start menu or programs. install the latest free updates and you should be good to go.
kev
Feb 21, 2011 | Apple 13.3 MacBook Intel Core 2 Duo...
Macbook black will not start beyond the initial 'bong'. Blue screen followed by endless spinning gear. PRAM, SMV reset, no go. Safe mode can't complete. With battery or on power adapter same result....
Hello yang2699tlk,
Try this instead of using your Leopard Disc.
  1. Immediately after the "bong" press and hold down "Command + S".
  2. Wait for blinking cursor and then type fsck -y (exactly like that).
  3. If you receive an "Appears to be OK" then type reboot and hit the return key.
  4. If you receive a "Disk has been modified" then repeat the fsck -y command until you get an "Appears to be OK" then type reboot and hit the return key.
This set of commands entered in "Single User Mode" will repair your disk. If this does not work remove the hard drive, plug it into another Mac and transfer your data to a different computer. Then install a new hard drive and reinstall Mac OS X.
Hope this helps, don't forget to vote. Thanks.
Feb 27, 2010 | Apple MacBook Pro Notebook
Would like a controller for a racing game to be used on a mac book
Any Logitech wheel should be detected by OSX Leopard or Snow Leopard - no drivers needed - in OSX, it's more the game that supports the controller than the OS itself that does.
Oct 20, 2009 | Apple aluminum 13-inch MacBook laptop-...
Web camera use in apple pc in windows xp
When youre running windows XP on a Macbook, you should install the Bootcamptools from the original Mac OSX Leopard DVD. This installs all the components of your Macbook including graphics, Bluetooth and of course the iSight =)
Jan 20, 2009 | Apple MacBook Pro Laptop Computer with...
Keyboard problem with MacBook 3.1 w/Leopard OSX
ok here's what you have to do goto https://selfsolve.apple.com/GetWarranty.do or call the at 1-800-my-apple (I can't believe they didn't explain this to you on the phone you should call back and talk to a manager) you are going to have to arrange for apple to repair this for you. This can be done online or on the phone but basically what will happen is apple will ship you a box with packing instructions and what not. You will then you send the computer to them using this box (they prepay the shipping) they make the necessary repairs and send it back it's pretty simple and relatively fast I personally have done it before and didn't have too many problems. Also the first 90 days of phone support is free and I think if you have purchased apple care the extend it but I'm not sure on that one.
Nov 13, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Problems with macbook after downloading windows to it
Was Windows loaded on another partition? i.e. was it configured as a dual boot or is Windows running in a virtual mode (Boot Mac then start Windows while logged on in Mac).?
Jan 06, 2008 | Apple MacBook PC Notebook
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
256 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
