Question about Whirlpool AWZ410 Front Load Washer/Dryer
How do you get the dryer to work on the combo
I can work the washing machine fine but I dont know how to dry my clothes. What buttons do you have to press
You need to have the half load / dry button depressed PLUS have indicated the number of minutes you want it to run for...
Posted on Nov 25, 2008
My awz410 does not heat up when its in the drying mode how do i fix this?
Posted on Dec 21, 2008
Thor washer/dryer combo not drying properly. What is capacity of machine?
Whilst 'combos' will 'wash' a full load of clothes, they are not so good at 'drying' a full load. Since there must be a 'tumbling space' inside of the drum, into which the clothes can fall during the drying cycle.
In a 'nutshell' one 'wash load' equals 'two drying loads',
That's the price you pay for having a space saving 'combo' machine instead of having a 'washing AND a drying machine.
Add to that the fact that most 'combos' are 'condenser driers', as opposed to 'free flow outlet driers',
The consequence is that it takes far longer to 'wash and dry' a load of clothes in a 'combi' as oppose to two separate machines
Aug 21, 2013 | Washing Machines
Clothes with pin holes are seen afetr washing/drying with He2 plus/He Washer dryer combination
Are you over loading the dryer? I know those combo machines can't dry a lot at once
Apr 28, 2012 | Kenmore HE2 Plus Front Load Washer
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
Dryer will not Dry!
A conventional dryer uses 240 volts to heat air, which passes through the tumbling laundry, picking up moisture, which is then vented to the building's exterior.
Your dryer uses 120 volts to warm air, which picks up moisture from the tumbling clothes, which then passes through a vent pipe in the back right corner of the dryer where a cold water spray causes the moisture to condense, run to the drain, and then is pumped out of the washer/dryer combo. There is no exterior vent to the outside of the building. Drying with your dryer will take at least twice as long as with a standard dryer. You can wash large loads, but can only dry small loads, and the clothes will not be as dry when dryer is finished as they will be with a standard dryer.
All that said, to make sure your dryer is performing as well as it can, you might like to take the back cover off and check the elbow at the very left bottom corner (when viewed from behind) to make sure nothing is obstructing the flow of water under the tub to the drain.
Aug 21, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Prolem drying clothes
I just contacted Samsung Tech Support for my wash/dryer combo WD-J1255C.
The reply.."it is not a full dryer ...and it is not sold as a full drier.. and don't expect it to be completely dry". I queried why it is advertised as a dryer and got the same reply.
Its a great washer but why did I pay extra for the dryer combo?
May 18, 2009 | Samsung Washing Machines
We have the Haier XQG50-11 Combo VENTLESS Washer / Dryer 120 Volt and the problem we are having is that the clothes are not drying. The dryer itself gets plenty hot but the clothes are wetter at the end...
make sure your drum is turning,open it quickly and see if it's turning,also make sure you have good ventilation behind the dryer,let me know what you find-mike
Oct 15, 2008 | Haier Washing Machines
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
Urotech EWC177 Combo
Same problem here and mines brand new. Seems the dryer consists of only a heating element. There's no circulation of dry air. You may as well hang your clothes inside a steam room.
Mar 10, 2008 | EuroTech EWC177 Front Load Washer / Dryer
How do you get the dryer to actually work?
That button with the 1/2 on it and then the time dial works and it sounds as if it is washing your clothes, but it is actually drying the clothes but heats up water in order to do it. It is kind of insane actually but it does work and that is the way to do it.
Do you know if there is a place to clean a lint filter? Is there a lint filter somewhere?
Sep 21, 2007 | Whirlpool AWZ410 Front Load Washer/Dryer
Whirlpool AWZ410 Front Load Washer/Dryer Logo
235 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
