Question about Kodak EasyShare C875 Digital Camera
C875 lens won't retract
Lens won't retract. when I turn it on, sound chimes, screen turns on, blue and green light flashes 9-10 times, len tries to retract, then camera turns off.
  • ebspring Nov 17, 2008
    Tried many new rechargable batteries but same problem. Lens sometimes comes out when turned on but will immediately retract if it even does come out.
  • whitneysher Nov 23, 2008
    I have the same problem. The lens is out and it won't go in. I have purchased new batteries, various batterys from digital camera batteries even Kodak brand. It doesn't work! My next plan is to see if maybe the camera needs to go on a charger or something. Let me know if you figure out something whitneysher@hotmail.com
Camera (with new rechargable batteries) won't let the lens come out or if it does it instantly retracts.
Posted on Nov 17, 2008
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
Turns on for 1/2 second and turns off
It sounds like the focus element inside the lens is stuck. This is usually either due to an impact knocking the elements out of alignment, or to sand/debris entering the focus motor's gear drive and preventing it from rotating. The buzzing sound you hear is the focus motor attempting to rotate, but buzzing up against some obstruction. When the lens extends, you hear a buzzing sound, and then the lens retracts - this is usually the cause of the issue. Unfortunately there is not much you can do externally to fix this problem. The camera will need to be taken apart and repaired by a professional or by the manufacturer. David Millier http://advancecamera.com/repair
Jun 05, 2007 | Casio EXILIM EX-Z1000 Digital Camera
Kodak easyshare dx4530 turns on then off
Hi there.
90 percent of the time when the lens malfunctions, it's due to grit or dirt in the lens mechanism. If you stored your camera in a camera bag, while you used the other camera, that could be your problem. Camera bags are great for holding dirt so it can get in your camera.
When the lens can't move, it may cause the camera to shut down. To fix this, use an air compressor. Put the nozzle to the camera and blow air into the space between the camera and the lens. Blow it out real good and try it again. You may have to repeat the process a couple of times. Hope this helps.
Rob
Mar 03, 2009 | Kodak EasyShare DX4530 Digital Camera
Camera won't turn on - makes strange sound
This is a very common issue with digital camera on either the lens gears have to be replaced or the lens barrel need replacing. I rebuild these lenses all the time for 75.00 plus shipping and the turn around is normally less then a week. if you still need help fell free to contact me at mike@digitalcamrepair.com
Feb 26, 2009 | Casio Exilim EX-S600 Digital Camera
Kodak Z1285 Won't Turn On?
HAd exactly the same issue! You turn on the camera, lense comes out then the screen goes black (turns off)
The blue light stays on and the only way to get it to turn off is to take out the batteries.
Next time you turn on the device, the blue light comes on and the green led flashes, sometimes it powers down and other times the blue light stays on but you have no screen still. The lense stays out.
I tried the "tap" it approach and it now works fine! My suggestion has always been, if it don't work, kick it!! why didn't I try this with this camera firstly instead of trying all sorts of different button combinations to see if there was some sort of hard reset for it?
Thanks for the advice everyone and happy snapping!! :)
Jul 28, 2008 | Kodak EASYSHARE Z1285 Digital Camera
NO LCD IMAGE / LENS STUCK
hi ban ive same problem bloody nusience lens wont retract what did u do with urs?
should i return it?
thanks leeanne
leeannehutchinson@btinternet.com
Feb 17, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Problem with i531
I had a Polaroid i531 that would beep 3 times then shut down & the lens wouldn't retract.
I fixed it like this:
  1. Inspect the lens from all angles and you'll see that the lens assembly is out of sync. (My was looking upward ever so slightly)
  2. Using gentle finger pressure, press in the opposite direction of the abnormal lens direction
  3. I heard a snap, then I powered the camera on.
  4. Camera now works.
Nov 18, 2007 | Polaroid i531 Digital Camera
System error
hi the problem that causing this is: there is some pressure to the lens did it fell? probebly there is a fault in the lens sorry cant help good luck
Mar 20, 2006 | Panasonic Lumix DMC-LC43 Digital Camera
Kodak EasyShare C875 Digital Camera Logo
344 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
