Question about Bosch WFMC 2100 Front Load Washer
E04 I have a Bosch wfmc2100uc washer. I am getting an E04 error and the drain hose is not stopped up and we did not use any detergent. The manual says to use less detergent clean the drain pipe and hose. I have done that and still get the error message. Help
Perhaps try opening the round panel on the front of the machine at the bottom and cleaning that hose...good luck because it might be messy.
Posted on Nov 22, 2007
What is error code e04 bosch front loader washer
The "E04" error code on your Bosch washer refers to a drainage problem as you may or may not already know. ( it can mean door lock error, but that is usually a by-product of it not draining )
What you may have is either a partially clogged pump, or a faulty pump...the later being the least likely
Nov 22, 2016 | Bosch Washing Machines
What is error code E04 on hoover washer
E:04" on the washing machine. Check to ensure there is no water in the tub. This is a common error often associated with too many suds blocking the pump. It is caused by using the wrong laundry detergent which is not designed for high-efficiency washers. You can adjust your use of detergent and reset the machine to eliminate the error code.
Read more : http://www.ehow.com/how_10038363_reset-bosch-washing-machine-error-e04.html How to Reset Bosch Washing Machine With Error 04 eHow
Jun 21, 2015 | Hoover Washing Machines
What does the E04 error code mean?
E04 means that you are not draining quick enough, if you are using HE detergant then your drain line is probably clogged. There is a round access panel on the lower right corner of your washer. If you stick a small screwdriver through the tiny little hole on this panel and twist the panel off you will see the drain pump catch. You can twist this cap off by hand and remove all the debris inside. WATCH OUT a lot of water will be coming through.
Dec 07, 2012 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Got an E04 messege (not the first). Set the washer to drain and it makes a horrible noise. Water won't drain out. Some E04's in the past have been accompanied by a rubber burning smell, but not...
The problem maybe the pressure switch if you have a multimeter check for any electrical issues if there is no reading your pressure switch needs to be replaced
Jun 30, 2011 | Bosch WFMC2100UC Nexxt Essence Washer
My Bosch washing machine model WFMC2100UC has been giving alarm code E04 and the indicator light "rinse" is lit. The manual suggests that the pump or the drain is blocked, this is not the case,...
This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 15, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
BOSCH WFMC3200 Washer - Receiving E04 error and manual indicates clearing drain hose and pipe. How do I remove the cover on lower front of machine?
there is small hole in the cover you need to push a small screwdriver or ice pick works in the hole and then turn clockwise till it comes off.
But there will be some water come out so if you have a wet dry shop vac then use it on the end of the drain hose to remove most of the water then keep it handy when you take the plug out there will still be some water come out and you should be able to clena out the trap area
Nov 30, 2010 | Bosch WFMC 3200 Front Load Washer
Error code E:13 on my 500 plus series washer
The E13 error code on your Bosch washer refer to a drainage problem or the pump time might have been exceeded
Either it might be due to a clogged pump, improper detergent being used, ( must use "HE" detergent ) hence suds not allowing a proper drain cycle. You should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. First run the short wash or refresh cycle without detergent and hopefully your lines will clear.
Thank you !!
May 25, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My washer has E:13 on the display. I called Bosch
According to the service manual, you should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. I would run the short wash or refresh cycle without detergent and hopefully your lines will clear. I have also read that if this persists, powder HE detergent is better to use instead of the liquid because of certain chemicals contained in the liquids that cause it to congeal in some front loader drainage pipes. I hope this helps.
Jul 03, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Washer stopped. E04 beeps but won't spin or continue any cycle. Have shut off machine but only makes a strange sound.
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I had the same problem. Error code E04 with a full load of laundry and water in the washer. Unplug the power to the washer. Take off the round cover plate in the front right. Mine did not turn clockwise or counter-clockwise, it was completely stuck. Used two flat tip screwdrivers to carefully pry it away, without damaging anything. The plate is a hard plastic but just pliable enough.
Once removed, you will see the pump (img_0001). Unscrew the pump cover slowly. There will be water coming out, so be prepared. In my case we had a LOT of water, so I drained it gradually into a couple of large garbage bags. Wrap the bag opening tightly against the pump surround to minimize spills (img_0002).
Once all the water is gone, remove the pump cover and clean out any items trapped in the pump and in the drain from the drum (img_0003). In my case it was some loose change and a small ColorCatcher sheet. Reassemble the pump and you're done.
Also helpful:
http://www.fixya.com/support/t1589624-bosch_nexxt_dlx_washer_open_round_panel
img_0001
img_0002
img_0003
May 16, 2009 | Bosch WFMC2100UC Nexxt Essence Washer
I have a bosch wfmc 2100 washer that doesn't drain
Have a look on the Bosch web site, they offer solutions to some problems, if not contact them via email
Jan 01, 2008 | Bosch WFMC 2100 Front Load Washer
Open Questions:
Bosch WFMC 2100 Front Load Washer Logo
867 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
