Question about Mitsubishi WS-55511 55" Rear Projection Television
Mitsubishi 55 inch-ws 55511
I have a 55 inch hdty projection and it keeps shutting off, sometimes it will stay on for a day and other times it will come on and shut back off in seconds. I have had 2 techs out and they want to play guessing games, I am get a code of 2 , 3. What does this mean? PLEASEEEEEEEEE HELP! 5 YEARS OLD- CONVERSION WENT BAD IN FEB REPLACED icm BOARD AND NOW IT WONT STAY ON.
  • smitmorgan Nov 23, 2008
    How do you fix a loss of horizontal deflection?
23 code means "loss of Horizontal Deflection"
Posted on Nov 19, 2008
MY MITSUBISHU WS 55511 WHEN POWER TURNED ON WILL
I have the same set doing the same thing. I will replace IC and fuses to see if that will fix it.
Jan 05, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Mitsubishi WS-55511 Manual Download
Download Mitsubishi WS-55511 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-55511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Have a Mitsubishi 55 rear projection WS55511
NEXT TIME IT SHUTS DOWN: when green light goes out on THE FRONT OF THE SET: press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and then release.
This is the self check this model has---power light should blink a two digit code---for example--two blinks, a pause and two blinks and the set will repeat the error code about 10 times.
1 blink and then 2 blinks is NO ERROR DETECTED
2 blink and then 2 blinks is short protect
ETC.....Let me know if you get an error code and I will tell you what the problem is---hope you find 2,2 that is the most common and the most easy to repair.
SD TECH
Oct 21, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 not responding to remote or front panel. Tried System Reset Button several times. No luck.
Sometimes the control panel switches on the front of the set go bad.
Try running your fingers across the buttons to see if it helps.
I ended up disconneting the front panel switch board and just use the remote now.
Oct 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mistubishi WS-55511 won't stay on
23 is a horizontal deflection error could be ho transistor flyback or high voltage splitter
Sep 17, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi ws-55511 does not turn on
Listen: you need to wait for the set to first shut off! then push on the TV(not the remote) Input and Menu both at the same time for 5 seconds and then release---the power light will then blink---this model has this feature--
Sep 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi ws-55511
I sent it out for repair. $700 bucks total, but now the color is bad and the HD isn't set properly. They'll be coming back out this week sometime to fix both.
Aug 16, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi Ws 55511
Good Day;
My opion is that the TV"s convergence Ic has failed > STK393-110 > 267P155010.
Good Luck, big IRISH.
Aug 10, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
238 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
