Question about Minolta Office Equipment & Supplies
Lost network connection - Minolta Office Equipment & Supplies
    Genius:
  • 1,913 Answers
Hello
pls rate my solution
if u need more help i give u remote support to.
with my team viewr soft
pls note my yahoo id is:kish.khatri@yahoo.co.i
access your pritner t ip
http://192.168.15.21 this ip is example replace it with it your printer ip
then go to printer setup check printer ip again .
also if u have setup disk then run setup again it detedcts autro matic netwoerk printer.
Posted on Nov 15, 2008
Can't restore network connection
check your network connection
register to your network automatically
disable roaming
and check data connection is on in network connection
Dec 29, 2013 | Kocaso M752 Dual Camera Android 4.0 ICS...
Acer AspireOne safe mode setup
You are posting a docking station for a laptop. You need to make sure you Network Connections are good before attempting to use the dock with network.
More than likely you simply lost the drivers for the Network Interface Card,
Jun 04, 2013 | Computers & Internet
Tobhiba Satellite M35-S320 - Downloaded Windows 7 - can not connect to internet - I use a wireless connection - appears I lost network adapter during download of 7
you lost your PC drivers, You must find driver for network adapter for windows7, after install it apdate you drivers for windows 7 from toshiba.com
May 28, 2011 | Toshiba PA3235U-3BTM Network Adapter
I am unable to connect to my Intranet. I have connected my laptop to the Intranet, but the Dell Optiplex 745 lost the connection.
There are a few tips i can give you to fix the problem: -Call your Network admin as ask for help -See if the network adapter is ON and running -Try a different network adapter -See if, somehow, you lost your adapter's configuration parameters.
I hope these tips help. have a nice day
Mar 08, 2011 | Dell OPTIPLEX 745 PC Desktop
Losing network connection on WD
if there you can connect via usb cable try to observe if detection lost, if connection still freeze the problem most likely in hdd. but if work fine may be in network connection related check for patch chord possible lost connection.
Apr 07, 2010 | Western Digital 500GB My Book World...
I have lost my wireless connection on my laptop
Delete the Existing wireless connections in the laptop and create another one
This should fix the issue
Jan 03, 2010 | 2wire 2700HG-B Router (2700HGB)
Lost internet connection,verizon guess was the card was bad
First thing are all the micro-filters installed and in the correct direction? If they are then it sounds like your DSL signal is borderline and when the phone rings it is getting knocked out. If that is the case you will need a tech to come out and test the line.
Sep 10, 2009 | D-Link DFE-530TX+ Fast Ethernet PCI...
Can't connect to netwoork
Just configure the wireless settings your laptop. Go to Network Connections > Right-click on Wireless Network > Properties. Go to Wireless Network tab and look for Preferred Networks. Just remove all of them and click OK.
Now, On the Network Connections, right-click on Wireless Network Connection > View Available Wireless Networks. Connect to your own wireless network and enter your wireless network key if it tells you to type it. That should fix your wireless connection. Now if your wireless network is not showing, you need to change the wireless channel of your router by accessing the router's setup page using your wired computer.
Apr 18, 2009 | NetGear WGR614 Wireless Router
Lost Wireless Network Adapter
check the driver status on device manager, if your wireless adapter is indicated there are not
Nov 10, 2008 | HP Compaq nx7300 Notebook
ok..try to recycle the power for the network modem and router..then turn on the router first, let it stabilize, then turn the modem back on.
Oct 22, 2008 | Linksys Computers & Internet
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
