Question about Keurig B60 Coffee Maker
Coffee isn't dispensing properly
When coffee comes out it is very weak, unsure how to solve this issue
  • mcnabdm Nov 29, 2008
    I am having a problem with weak water dispensing when I switch from my regular coffee to decaf. I don't know if the decaf coffee is too fine for the coffee filter? It only fills the bottom of the cup and then quits. can you help me figure out this problem. I bought this coffee maker at Costco, do you know if there have been any recalls?
    Problem Solver:
  • 14 Answers
You're using K-cups right?
Check if the funnel or exit needle is clogged up.
If you haven't de-scaled it for the last 4 months, try to de-scale it and rinse it with clear water and no K-cups.
Information here:
Posted on Dec 07, 2008
Coffee brewing very weak
possible ways to remedy this problem:
problem of weak beverage
1. Filter Type-BUNN paper filters must be used
for proper extraction.
2. Coffee Grind-A fine or drip grind must be used
3. Sprayhead-A six-hole stainless steel spray-
head must be used for proper
4. Funnel Loading-The BUNN paper filter must be centered in the funnel and the bed of ground leveled by gentle shaking.
5. Water Temperature- Place an empty funnel on an empty
dispenser beneath the sprayhead. Initiate a brew cycle and check the
water temperature immediately below the sprayhead with a ther-
mometer. The reading should not be less than 195F (91C). Adjust
the control thermostat to increase the water temperature. Replace if necessary.
Apr 11, 2013 | Bunn 392 Pourover Coffee Maker With 2...
Why does ground flow from the top of brewer instead of coming through the dispenser?
Buy a new K-cup holder from Its the black cone shaped holder.
Jan 11, 2013 | Keurig B70 Coffee Maker
My Coffee Gaggia Vision is grinding and the coffee is coming out very weak. The billet coming out is very wet and small. Any solutions or ideas?
see this matter causes:
Make sure there's water in the unit's water tank.
  • 2 Unscrew the shower disk from the top of the unit and rinse it. Dry the disk and screw it back in place.
  • 3 Replace the coffee grounds with properly ground beans. Coffee beans that are either too finely or too coarsely ground will adversely affect the flow of coffee from the machine.
  • 4 Make sure the coffee in the filter is not packed too firmly if the coffee isn't flowing at all. If the flow is too fast, tamp the coffee down a bit more with the tamper.
  • God bless you
    Jul 18, 2012 | Gaggia 90950 Platinum Vision Espresso...
    Won't perk properly
    Basing on personal experience (you can find more on Google probably), solutions are:
    On percolated (filter) coffee machines:
    Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
    Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
    Coffee blend not well distributed on filter basket.
    On Espresso machines:
    Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
    Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
    Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
    Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
    On the hob moka pots (espresso, Moka and Bialetti type):
    This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
    The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
    On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
    French and turkish cafetieres:
    Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
    Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
    Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
    Oct 21, 2008 | West Bend 13500 Coffee Maker
    Coffee is weak
    Check where the water comes out under the brew filter. It sounds like you may be missing the sprayhead. It is a round metal or plastic piece that is screwed on to the water dispense area and acts like a little showerhead forcing water evenly over the coffee grounds. If it is missing, the coffee will be weak. Check the water temperature. If it isn't hot enough, the coffee will be weak.
    Jul 11, 2008 | Bloomfield 8571 Coffee Maker
    Keurig B60 Coffee Maker Logo
    439 people viewed this question
    Top Keurig Coffee Makers & Espresso Machines Experts
    Oloyede Monsuru
    Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
