Question about RCA Televison & Video
No power to standby
I got this RCA L32WD22 from the company I work with because they replaced a customers on the complaint that it had got a surge of power. I cannot find a schematic or any trouble shooting on this, if you can help, it would be appreciated. I know a little about reading a schematic or tracing to problem. Thanks Pat
  • 1,447 Answers
Schematics are under proprietor ownership, what i can suggest is to check on manufactures ditributor for exploded diagram for this matter.
Hope this helps
Posted on Nov 15, 2008
Does this tv have an internal converter box
Here is a helpful link:
According to this link, no, it will not tune the over the air "ATSC" signals, it will tune what some cable company's have switched to refereed to as Clear QAM.
For a "cable company converter" it would need a cable card slot.
Aug 21, 2014 | RCA L32WD22 32 in. LCD HDTV
After a power outage my tv will not turn off and the screen is completly black
With a power outage - power surge - anything is possible. One or more board s could be bad. If you have insurence you might be able to get a servicer to say that it was a surge and your insurence compaony will replace your set.
Mar 15, 2013 | RCA L32WD22 32 in. LCD HDTV
When i turn my 32'' rca flat screen on the red light is flashing but it would not come on ,what is causing that to happen ?
Power Supply problem, had the same problem, could not find a Power Supply board replacement even on ebay. They had a capacitor replacement kit, here on ebay
Used that, and it worked.
Dec 11, 2011 | RCA L32WD22 32 in. LCD HDTV
Tv LCD RCA model L32WD22 what ic replacement can I use?
Close the the unit up as you had before opening. Take the unit to a service centre and have them fix it. They don't have manuals to repair so, when they say, "We can't fix this" you take the work order and call1877-297-8391 and they will get you a new tv
Mar 17, 2010 | RCA L32WD22 32 in. LCD HDTV
RCA L32WD22 with no picture.
The backlight has failed. May be the power supply for it, the inverter board or the lamps. Not something you can fix unless you are a tech.
Mar 10, 2010 | RCA L32WD22 32 in. LCD HDTV
My L32WD22 doesn't seem to be getting any power.
Pls take your tv to a tv service center and ask them to fix it. They won't be able to. So you make sure the make a workorder. When you get that order, you call 1-877-297-8391 and they will give you a tv
Feb 03, 2010 | RCA L32WD22 32 in. LCD HDTV
I have a rca l32wd22 screen weht black with no
Take your tv to a service center and ask them to fix it. If they cant...
Have them make out a work order and then you call 1-877-297-8391. The people at the other end ot the tele number will give another tv
Jan 09, 2010 | RCA L32WD22 32 in. LCD HDTV
My rca l32wd22 will not power up what do i do
First place to look is the main power supply module for simple thing like fuse, then look for 5V standby, you must have at least this standby voltage. This 5V (should always be there with the TV on or off) is supplied to the main board so when you turn on the TV, the main board will send the ON signal to the main power supply to supply voltages to other circuits.
Nov 03, 2009 | RCA L32WD22 32 in. LCD HDTV
Rca L32WD22 won't turn there a fuse? If
did you see the standby light? if no you have problem in main power section maybe the fuse is blown you can locate the fuse at the power main board, or if the standby light is light up the problem is the inverter power supply and this section is need to diagnose to find the defective parts...
Aug 02, 2009 | Hyundai HLT-3272 32 in. LCD Television
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
Televison & Video Logo
59 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
