Question about Emerson MW8102SS 1100 Watts Microwave Oven
Microwave does not heat
The clock runs, the lights come on, but the characteristic sound is absent and food does not heat.
  • Anonymous Mar 18, 2008
    Every thing works on the microwave, but just does not heat at all., nothing , and its not that old. Thanks if you can point me in the right direction, on how to fix it .Mrs. H.
  • Emerson Master
  • 9,098 Answers
Sounds like a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. You can find these files by searching at Yahoo.com (not Google) for this: microwave display safety.txt In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see from time to time, and we repair those nationwide, but it's usually a door switch. If you still have a problem, please write back with more detail. Be safe!
Posted on Nov 20, 2006
Does not heat anymore, power is going to unit, the clock, and fan work, light still works but it will not heat and makes a low growling sound when we try to run it. Help!
What you are describing is a problem with the magnetron and it has become faulty, that is the main part that heats the food, the growling sound indicates it is loading down the power transformer that energizes the magnetron. The repair cost will not justify the expense "costly" replacement of the microwave oven "cheaper" in the long run.
Jan 21, 2011 | Kenmore 80412 Microwave Oven
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
No heating
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 26, 2009 | Kenmore Microwave Ovens
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Was heating up food and all of a sudden nothing works on the microwave, nothing, clock, light, buttons, nothing..
sounds like your circuit breaker kicked or your fuse blew. go to your electrical panel and see.
Apr 21, 2009 | Whirlpool MH7140XF Microwave Oven
No heat
heating element stopped working
easiest thing is to get a new microwave
Dec 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Oct 09, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
No heating, no clock, no timer, otherwise fine!
One of your door interlock switches is defective . I would suggest having it repaired by a qualified repair tech in your area.
Oct 04, 2007 | Sharp R-1500 Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
2,202 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
