Question about Honda Quincy 17 - Gallon Air Compressor with 5.5 Hp - G15H17PC3B
Kicking overloads but not consistantly
Quincy air comp. 115600-j34.7.5 hp, 460 v 9.6 amps 200lbs tank.on at 70 lbs off at 92 lbs it takes approx. 2 min. to come back on.there are 2 cmpressors lead and lag.a,b, and c ph are real close to max. amps b and c on 1 comp. are 10 amps.I've tightened every screw in the electric box but nothing was out of the ordinary.thank you for your help
    President:
  • Honda Master
  • 1,388 Answers
First: Most all compessors use check valves at the tank and an unloader to allow the compressor to start without a load. Make sure that system is unloading and that check valve is not leaking causing head pressure at start. Second: Too frequent starts and stops will cause motor to overheat. Check Quincy manual for max starts per hour. enjoy
Posted on Nov 27, 2008
Why does the compressor starts off with short cycles then kicks on?
Could be a compressor start relay, overload and run capacitor. What is the model number of the fridge?
APPLIANCE 911
Dec 07, 2015 | Refrigerators
BREAKER IS KICKING OFF
Has this unit just been installed or has it been running. Just installed check wiring. If been running check wiring for tightness on starter. Check voltage and amps. Compare amp reading to overload heaters. They will have a # on them like E-58. Look in the starter box cover and there should be a chart showing the amp range for a E-58 or what ever size heater you have. If running amps are with in range shut down remove guard and belt. Rotate by hand the motor and pump. Any problems like looseness of shaft will indicate severe problems that may be causing the trip. Next if needed ohm out and meggar the motor. you should have found your problem by now!!
Dec 07, 2011 | Ingersoll Rand Type - 30 Reciprocating Air...
I HAVE A 2 HORSE POWER COMPRESSOR (QUINCY) WHEN I TURN ON THE UNIT THE AIR REACHES 80 LBS AND KICKS THE PRESSURE RELEASE VALUE IN OTHER WORDS THE COMPRESSOR WANTS TO RUN ALL THE TIME AND NOT SHUT OFF...
Replace the pressure release valve, Typically they are set to protect at above 130, depending on the specs for your machine. This is a safety device, intended to not normally release...
Always look for leaks when you are working on the unit.
Feb 25, 2011 | Computers & Internet
Charmglow propane patio heater class iiia2 25000 to 40000 btu;s pilot won't light
Ok, let's get the easy to check things out of the way first.
1) Is the tank empty? Take it out and weigh it on a bathroom scale. Most empty tanks weigh approx 18 lbs. The TW (tare weight) of your cylinder is stamped on the collar. If it weighs within a few lbs of your tare weight, then you simply need to refill it. Propane weighs 4.25 lbs/gal, so it would weigh approx 22 lbs with 1 gal of gas left.
2) Did you turn the tank valve on too fast? Close the tank valve, disconnect it and reconnect it. Then very slowly turn the tank valve back on. Try lighting the pilot and see if that helped. If not, try #3.
3) Your pilot orifice is dirty or has a spider web. Grab a can of compressed air (like you use to clean computer keyboards) and blow out the dust or web from the pilot assembly, which is where you light the pilot flame. Try lighting it and see if that solves it.
One of these 3 tricks should fix it. Douglas
Jun 09, 2010 | Grilling
When the comp. shuts off the air bleeds back out the intake. what needs done to stop this It is a quincy model 350 2 stage compressor
You have one or more valves broken in the head and need to be replaced, and Quincy compressors require a special tool to remove and install valves.
Apr 29, 2010 | Air Tools & Compressors
Need to know torque specs for rod and head bolts on a quincy model 350-11 air compresser
25-35 ft. lbs. Never saw any air compressor head bolts any other torque range If that number is a little squishy for you, call Quincy up tomorrow at
212-222-7700
Aug 21, 2009 | Air Tools & Compressors
COMPRESSOR ONLY GOES UP TO 65 LBS.
this unit should have a pressure switch that cuts the unit off and on with a adjustment to set the cut out .most switches have two adjustment screws.one of them tells the unit to kick on when the pressure is getting low.the other adjustment will raise the pressure to the desired amount.
Jun 16, 2009 | Northern Industrial 2 Hp Twin Tank...
Small production of ice? What should be the normal production of ice?
The way I understand how Hoshizaki machines work, the model number is usually what the unit will produce, in pounds of ice. Their manual states: "Approximate production/ 24 hours @ 70 degrees air/ 50 degrees water (incoming)" So, yours should be producing 450 pounds a day, approimately. Since I can not pin point your exact model, I found one that is close. It states: "Ice Production per cycle: 6.6 pounds, 360 pcs." Again, it is not you exact machine. Their web site does not show this model either. So this is the best info I can get for you. Hope this helps.
Jun 03, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Thermal dynamics cutmaster 50 2004 yr.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Sep 27, 2008 | Welding Tools
Honda Quincy 17 - Gallon  Air Compressor with 5.5 Hp - G15H17PC3B Logo
211 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
