Question about Epson Stylus CX3200 All-In-One InkJet Printer
SCRATCHY UNREADABLE PRINT
I HAVE CHANGED INK CARTS CLEANED THE PRINT HEAD( I THINK) AND STILL ACANT READ THE PRINT NEED HELP
  • derekmcl Nov 18, 2008
    despite repeated head cleaning and cartridge replacement printing is still very patchy and has lines. can i get in and physically clean print heads?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
No, usually you will need to replace the printheads.
Posted on Nov 21, 2008
What cause lose of new ink on aligning cartridges.
Unfortunately, the printer does not actually measure the ink in the carts, but measures how many droplets called for. The carts may actually be full, but the printer now thinks they're empty. Most likely the black ink needs to be "charged" because you've cleaned out the pipe. I don't know what to do to charge it, and you'll likely need new carts.
Sep 11, 2014 | HP Officejet Pro 8500 All-in-one -...
INK RESET IN CANON PIXMA MG3100
First off..Law has it that Printer Manufactures can not restrict their machines from using cartridges from other vendors. So you can purchase less expensive carts from the likes of www.inkjets.com. Why bother refilling when they are so cheap and the carts are actually new. Carts with print-heads built in are tested and work great. When line appear, the print head is plugged up. You may simply have a cartridge with ink that fits into a separate Print Head and locks into place. If so, that Print head is no good. It should be replaced, or run under very hot water for 10 minutes, both sides, until no ink is visible. Dry on a soft towel and do not touch the metal parts. Replace and do a printer test. That's it.
Feb 08, 2018 | Canon PIXMA Office Equipment & Supplies
Lines show up throughout print jobs
Your print heads most likely need to be cleaned.
When you don't use your ink carts for a while, when you get new ink carts that have been stored in warehouses for a number of months, or when you have refilled a slightly too dry ink cart, the print head nozzles on the bottom of the ink carts get clogged with dried ink. The printer head cleaner menu will not disolve the dried ink. Water will. Try this. Soak the bottom of the clogged ink cart in 1/2 inch of hot water for 15-30 minutes. Blot dry with clean paper towel(you should see the ink color on the towel). Retry.
Mar 07, 2011 | Dell 942 All-In-One InkJet Printer
Anything printed from our canon printer is showing a "striped" background. Have changed ink cartridges and have cleaned the printer head but still have the same problem
The stripes are generally caused by a blocked nozzle (or 2).
Remove the cartridges and then remove the print head from the printer.
Run the print head under some warm water for a few minutes - concentrating on the pit at the bottom where the ink comes out - all those coloured slots!. When the water runs clear. take some kitchen roll and dab the thing dry - don't rub. Make sure there is no water on the electrical contacts on the back and refit the print head into the printer and then the ink carts.
Try a couple of prints now. What happens?
Mar 18, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
3eBk will not print. Canon MP780
Replacing the printhead may work, but it could be a problem with the cleaning assembly. Take out the 3ebk and run a cleaning, if the ink goes away on the pad where the ink cart. goes, then clean assy. is OK, and you need a new printhead.
Jul 14, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Easyshare5300 wont print
Hi Grandma,
Sorry to hear of your trouble.
I would remove the ink carts, reseat the print head then reinstall the ink carts. Try printing again to see if things improve. If it does good. If not try the Kodak online team. 800 421 6699 They will help you get things working correctly.
Talk to you soon,
Ron Baird
The friendly Kodak guy
Oct 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Black ink is full but does not print.
Did you make sure that the cart was placed well and the plastic hook secures the cart on top?
If you have used Easy Jet carts, you can stop here and give the whole machine a push to the bin!
Easy Jet carts and some other generic ink carts clogg the fine filter in front of the nozzles which cant be cleaned anymore.
The ph as a spare part is more costly than a new mfc 240c at a price discount!
But you can try this at least:
Use a new original brother carts (BK/C/Y/M). place carts and secure them! (this procedure will consume some ink!)
press menu then start bk copy then fourtimes arrow-up button. machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink in tubes and ph
and will do some cleaning cycles. when finished press 7 then 6 then 3 then start bk copy to run a special power purge.
When finished press 9 then 9. After machine is back in normal state run a test print.
If you still cant see any bk the ph cant be fixed anymore.
Jan 05, 2008 | Brother MFC 420CN All-In-One InkJet...
Vertical lines
1. Took out the ink carts and cleaned the copper contacts of both the ink carts.
2. Clean the copper contacts on the ink carts slot in the printer and then insert the ink carts in the printer and then print out the page.
Dec 11, 2007 | Epson Stylus C60 InkJet Printer
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
56 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
