Question about LG LSC121PMA Split System Air Conditioner
Panasonic inverter air con CS-E12DKEW not working properly
This unit is not heating properly. Over the period of about a week it has been giving out less and less heat. An identical one in another room is working properly, and if you set it at a much lower heat than this one ie 20 as opposed to 24, heats much more efficiently and to a higher temperature in that room.
  • slaveskil Jan 14, 2009
    My problem is Panasonic air condition CS-E12DKEW. When past work after few hour, startet timer blocked air cindition. After 1 day delete power air codition start again.
  • 147 Answers
SOURCE: LG MC07AHR and MA09AH1 do not heat!
What you have is two fans, one for the outdoors and one for the indoors.You indoor fan is not running and it is not a good idea to run your unit. There are several reasons for this fan not to be running, but the most common is that it is bad. AC mechanic or good electrician can check this out.
Posted on Nov 05, 2008
  • 833 Answers
SOURCE: HEAT PUMP/AIR CONDITIONER UNIT SMELLS ONLY WHEN AIR IS ON
Not sure what the smell...smells like.  My guess is dirt or dust near the heating elements.  These will cause a burning smell.  Sometimes insects even get into the act..building webs.
You will have to clean that area out...sometimes a large blower or vac can dislodge the dust.
Posted on Dec 04, 2008
crouchdash
  • 83 Answers
SOURCE: I HAVE MISLAID REMOTE CONTROL INSTRUCTIONS TO CHANGE FACILITY REQUIRED IE COOL, OR HEAT
You can download the owners manual; here is the link for it.
http://www.generalmanual.com/Air-Conditioners/LG-LA121CNP-Art-Cool-Air-Conditioner.htm
when you get to the page scroll down and you will see Download Now and under that "Owners Manual" just click on it.
I hope it helps.
Posted on May 27, 2009
  • 767 Answers
SOURCE: Should the LG LS-K-1830CL outdoor unit ice over on
Running the heat pump in low outside ambient temps. will definitely cause the coil to ice up. An ouside temperature senor or a wind baffle should be installed in climates that get below freezing. This would definitely cause the heat pump to operate at lowered efficency and maybe not at all. It should go into defrost mode if the sensor is working correctly when the coil ices up.
Posted on Dec 20, 2009
  • 534 Answers
SOURCE: My LG LWHD 7000 is not heating.
heater coil located behing the front evaporator coil has burnt out. To access the coil you need to remove the a/c from its sleeve and the coil is located between the evaporator coil and the fan motor. An appliance parts house will have the replacement coil if you do it yourself.
Good Luck on your repair hope this helped
Dave
Posted on Jan 08, 2010
I have a panasonic inverter air con. Model CU-E18LKR. it's not cooling properly. Seems to be blowing cold air out on th outside rather than inside.need instructions on troubleshooting
This is a reverse cycle (heating and cooling) model. It sounds like you have it in heating mode. Check the Panasonic website for an owners manual.
Jan 30, 2017 | Panasonic Heating & Cooling
Timer blinking.outdoor unit does not functioning. what was the error?
Looks like you said it, the outdoor unit is not working. Check for power to the outdoor unit or try cutting power to it, then after a minute restore power in attempt to reset it.
Apr 28, 2015 | Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall...
Panasonic CS-A12DKD Air conditioner does not
This could be an inoperative reversing valve or bad reversing valve solenoid coil.
Oct 31, 2013 | Panasonic Heating & Cooling
Cs-ye12mke. Panasonic Inverter A/C system How do i access the drainage tubes behind or within the wall unit. The unit appears to be sealed with little access to the internal parts. It leaks down the...
There is step by step instructions in the online manual. I found the 3/4 ton (1 size smaller than yours) manual very easily. I suggest you read this. But there is 2 screws located behind caps under the discharge air swing fin. I suggest 2 people if you plan on working on the tube behind the unit, you don't want to damage the copper tubing, located in the exact same location.
Jun 23, 2017 | Panasonic Heating & Cooling
Not Cool
Measure room and calculate btu's
Formula Length times Width times Height Times Eighteen divde by Five.
Example: 12 x 15 x 9 x 18 / 5 = 5832 BTU's
Jun 03, 2010 | Panasonic CS-A12C Air Conditioner
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
Split system not starting up for about 10 mins after turning on
Hi Wendy,
The manual for the unit is at this link. This should answer all your questions. http://panasonic.com.au/products/details.cfm?objectID=4601 then go to the bottom of the page and click on CS/CU-E18_21_24_28HKR Operation Manual
I take the time to answer you questions so please rate me
Thankyou
Mat
Jun 10, 2009 | Panasonic MCM INVERTER
Heating & Cooling Logo
1,014 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
