Question about Bosch HBN 560570B / 560550B Electric Single Oven
Can't locate the electric ;ead from the oven
Can't find the electric lead from the oven needed to conect to the mains.
do I need to take the back panel off?
  • Bosch Master
  • 3,463 Answers
Hi
Some ovens do not come with lead, so it is uo to you to provide one and connect it up.
Posted on Nov 23, 2008
Fan oven not getting warm
It is normally the element that has gone, located behind the fan. A long shot could be the thermostat. Have a look at the thermostat sensor. It will be located in the oven at the back somewhere. It should be clean and bright and not covered in dirt or grease etc. If it needs a clean, use a spray cleaner and do not treat it to harshly. The thin wire leading from it is quite fragile! However, if you decide to replace the heating element, I would suggest that you replace the thermostat as well because quite often the element blowing damages the thermostat, which could lead it to fail, it it hasn't already done so, at a later date.
Oct 31, 2011 | Stoves 720EF Electric Double Oven
My oven does not heat up when in fan oven mode, the inner element does not get hot, the outer element does, Both elements get hot when using the main oven full width grill. ...
From your descritpion and if you already replace elements there are two options.
One is that there is an open curcuit either by a loose contact from selector switch to the elements this can be check with a mutlimeter.
The second option the selector switch itself is mulfuction and this normal after long time use since it consist with power contacts they fail to conect after long and you will need to replace it. If your familiar with electric then you can check it with power on and multimeter to see if it conects the elements or not. This operation need extra extra safety and experience.
We have here one side just to see what part you need the cooker selector multifaction switch
Aug 25, 2011 | AEG D5701-4 Electric Double Oven
Where is the thermostat located in the main oven of my Creda Europa Solar oven. Thanks
Depends which thermostat you are referring to.
Thje main oven stat is on the control panel, and is marked with the temp, the sensor being located at the top rear of the oven compartment.
The other stats are located at the top of the oven outer casing under the the top cover. you need to remove oven from housing to access these.
Oct 29, 2010 | Creda Europa E010E Electric Single Oven
Whirlpool Model GBS307PB00 has error codes
HI. The reason for the PF code will be the result of the power cycling. When you switch the breaker to the off position, the main control board assumes that there has been a black out, thus, triggering the PF code. This is not your principal issue here. The F3-E0, which is your main issue, is the result of a failed oven temperature sensor. The control has sensed that the actual sensor circuit is stuck open(Not functioning or energized).
Your main control board is programed to shut off the entire unit, due to this apparent failure within the oven temp sensor. The necessary actions are to have the affected part replaced, asap. I would, also, advise to preform an electrical test. I will list the entire procedure below. Follow carefully, and with caution. Make sure that your units is unplugged before administrating the testing procedure.
Sensor testing procedure:
First,you will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Sensor location
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Apr 05, 2010 | Whirlpool GBS307PDS Electric Single Oven
I have an error msg F03..what does that mean?
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
Sensor location
Feb 22, 2010 | Bosch HBL 5036 Electric Single Oven
Baking temperature is not accurate.
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
Sensor location
Dec 27, 2009 | Jenn-Air W30400P Stainless Steel Electric...
Oven is giving an F2 code and not keeping heat
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
Sensor location
Dec 20, 2009 | GE 30" Built-In Single Electric Wall Oven...
No heat in main oven, fan is working ok as is top oven. main oven was working ok then power was lost due to circuit breaker tripping??
You need to replace the oven element.
This is located at the rear of the oven compartment, behind a removeable cover.
Dec 20, 2009 | Neff U1721 Double circotherm Electric Oven
Smeg oven ss336-5 not heating
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Jan 21, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Display doesn't work, but oven works
First turn the electricity off by locating the breaker to the oven and turn it off. Now wait for an hour or so and turn the breaker back on, if the display turned back on, you need a control board (other manufatures call it a clock, PCB or ECC but it's the main elctronic board with the diaplay built in). If it didn't come back on, turn the power off again and make sure all the wire harness's going to the board are connected good. Turn the power back on and it the display still doesn;t come back on you need to replace the main electronic control board. By the way double check the model number and brand because it might be wrong. Please post back.
Oct 04, 2006 | Whirlpool RBD275PD Electric Double Oven
Bosch HBN 560570B / 560550B Electric Single Oven Logo
73 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
